| Like subject says really, I'm seeing if its Good... erm, Acceptable Design to power two EEPROM ics from a voltage divider (knowcked down to 3V) off of my 5V regulator ? I have two 8pin EEPROMs, one is 1.8-5V tolerant, the other has a maximum of 3V. If I split off a divider from my 5V regulator and these two chips are both writing at the same time I think the current should be around 20mA (writing both at the same time will never happen, but lets just say) There shouldn't be a problem with this correct ? Maybe I should set it up for a zener instead ? I think my only concern is making sure the resistors that make up the divider are relatively of low. I could add a 3V regulator, but I'm trying to keep costs down, these roms will rarely be read from, probably never written to (accept for initial programming) Just getting opinions, Thanks | |
| Sounds like a lot of effort, why not just replace the EEPROM with a 5V one. You need a regulator of some sort, the EEPROMs current varies with read an write modes and is just poor design practice. | |
The only concrete issue with using a divider is power wasted. Today they are down to 3mA max making the dual use load to 6mA. Not much waste if fueled from mains powered, auto powered, or some other source of renewing energy. I say who cares. EEPROMS are not IGBTS. Last edited by donniedj; 24th January 2008 at 04:52 AM. | ||
__________________ We never have time to do it right; but we always have time to do it over. | ||
| I would first ask how much current is being drawn and if this is a mission critical design or some back room hobby board that most likely is riddled with for more errors other than the believed to be taboo divider. Why would a person working for you need to even ask basic questions in the first place. I bet you would fire someone because they spend the money on the extra regulator. "If we have time to do it over, will it be done right or will we repeat this act for all eternity since we never have time to do it right? Or we doing it over because the act of doing it over is not equivalent to doing it right? Are repetition and correction even related? If we do it right after doing it over, does this not prove there is time enough at last." - by ACG, by Me | |
| The OP asked if it was "Acceptable Design to power two EEPROM ics from a voltage divider" the responsible answer is no. The IC is going to change its load unpredictably and its also really poor practice. Just like so many folks don't use decoupling caps for whatever reason. 3.3V regulators are cheap, use em. | |
| Why not just replace the bottom resistor in you divider with a 3.1V zener. Set the top resistor to drop 2v at whatever the max current is and you should be set. You should include decouplers as well. Mike. | |
| So, would I get talked to for suggesting a zener for regulation, assuming no power restrictions. Mike. | |
For the sake of a few pence I'd go with a dedicated 3.3v regulator | ||
| My 2 cents for the OP... Scenario 1... it's a high-volume kid's toy and the useful life of this product is a few minutes/hours to a few days, ie. a disposable product,... two resistors is just fine. Don't need to decouple it. Scenario 2... it's a kid's favorite toy and the useful life of this product is a few days to a weeks... resistor and zener diode will do. Have to decouple it too. Scenario 3... it's a commercial product or something people will use for months or years. A separate voltage regulator should be used here (or select a different chip that doesn't require any voltage conversion). Certainly have to decouple it too. Scenario 4... it's an industrial product. Other than a separate voltage regulator, should have a polymer/tantalum cap too (or select a different chip that doesn't require any voltage conversion). Certainly have to decouple it too. Scenario 5... it's medical grade. Remove some caps... low leakage
__________________ * | |
| How to make PC power supply with voltage control | Fachri | Electronic Projects Design/Ideas/Reviews | 1 | 10th January 2004 12:54 AM |
| Hi Voltage Power supply regulator | badflyer | Electronic Projects Design/Ideas/Reviews | 2 | 14th October 2003 11:48 AM |
| changing dc power supply output voltage??? | seaball | Electronic Projects Design/Ideas/Reviews | 3 | 6th August 2003 11:11 PM |
| Use Voltage Divider Instead of Transformer? | hamfiles | General Electronics Chat | 16 | 23rd July 2003 07:28 AM |
| Negative voltage divider? | hantto | General Electronics Chat | 1 | 23rd January 2003 05:54 PM |
