Not strictly speaking at the exact same time, but I see no reason why you couldn't get close enough, if you had enough pins.
A dsPIC for example has multiple sample-holds for it's ADC. It can capture all the samples at the same time but only uses one SAC register to convert them. So it samples them all at the same time, but only converts (ie. reads them) them sequentially. THey are all sampled at the same point in time though. |
You don't need external ADC, just switching between two channels if time is allowed. Or if you want PIC18F2331 (or the same family) has two sample and hold which allow you to sample two channels simultaneously. But the conversion time channel by channel. It has 4 level FIFO so you don't have to worry about the data loss.
Depends on your sampling frequency, if you don't need that fast, just PIC16 will do by switching the channels.
Superman returns..
Well im going to have at least 10 samples/sec (maybe more) so it will probaly be enough with a PIC16..
Simplicity rules Good enought - its perfect ?? 2 Gig of free online backup space Are you a Chemist? |
So i can just use the one AD inside and plex my way from one to the other?
Yeah just switch to different channel as you want.
Superman returns..
| The Oscilloscope | ElectroMaster | Electronic Theory | 12 | 3rd February 2008 01:45 PM |
| 3 Inputs & 3 Outputs Coding problem | Suraj143 | Micro Controllers | 16 | 17th August 2007 04:19 AM |
| Hardwiring multiple switches to common inputs | Franknstein | Electronic Projects Design/Ideas/Reviews | 7 | 25th April 2007 11:02 AM |
| PIC A/D Sampling multiple inputs | NJ Roadmap | Micro Controllers | 10 | 21st February 2007 01:53 AM |
| Multiple Units Transmission Coding | Spasm | Micro Controllers | 4 | 18th March 2004 08:52 AM |
