| Well for anyone following an old thread here's someone who actually did the classic PIC LC meter using the internal comparators on a 16F628 http://ironbark.bendigo.latrobe.edu.au/~rice/lc/index2.html ![]() | |
| Thanks Bill, for the link to new version and definitely admire VK3BHR for the ingenuinity unlimited.. WOW!!
| Nice find Bill. I haven't been back to visit that site in some time so it's a nice surprise to find Mr. Rice has updated it with a single-chip LC Meter solution, something that you and I have been interested in for awhile now... | |
| BIll, I am going to play lazy and ask instead of looking. How does this compare to the LC method/circuit used on the mondo superprobe? | |
| The Mondo superprobe has some neat features but its L/C is very primitive. Using a larger PIC it would be possible to combine the features of both. Would you rather use a seven segment display or LCD display? | |
"When an inductor is connected from the tip to the ground lead, and button #1 is pushed, its value is displayed. Values from 0.1 to 999.9 millihenries are displayed. " it can resolve .1mH while the other one under concern can measure 10nH minimum-- while the original design of AADE.com can resolve .1nH
| I would rather see an LCD with 15 or 20 characters. It would allow real text instead of cryptic 7 segment labels Also you could display Hz KHz and MHz instead of: no decimal for Hz, flashing decimal for KHz, and solid decimal for MHz. Or maybe it was flashing for MHz... The processor would not have to mux the display. | |
| I'm engaged in building this LC meter..... But the 5V reed relay which is a low current type <30mA is nt easily available here...I think I've to get it from farnell india.......... But I think a 2N7000 moisfet can be used for the switching...can somebody tell me how to connect it.... | |
You could use the pin that drives the reed coil to drive a 2N7000 gate and connect a standard relay in the drain circuit.
| According to the FAQs by the designer, a 2N7000 mosfet can be used to switch the 1000PF capacitor. Here how it is connected:
__________________ L.Chung | |
| I have in my hand the same meter (more or less). Mine is old and I see there is a new version now. I also have a very big $$$ HP LCR meter that I do not use because this little meter is as good in most cases. It really works well at 1pF or to measure the inductance of 3" of wire. This meter will not work with BIG ele. capacitors. Almost All Digital Electronics | |
@ericgibbs We could use even a BC547 for relay drive. with a base current limiting resistor.
| Analog Meter | windozeuser | General Electronics Chat | 19 | 3rd October 2007 03:44 PM |
| How we can do it in Assembly..Help Needed | Ayne | Micro Controllers | 37 | 29th December 2006 06:49 PM |
| Panel meter, analog VS digital | Johnson777717 | General Electronics Chat | 7 | 23rd June 2004 12:33 AM |
| Work ID reader Track 2 problems with pic code. Need help! | egg0900 | Micro Controllers | 2 | 19th April 2004 07:58 AM |
| Got my p16Pro | Squintz | Micro Controllers | 20 | 29th November 2003 10:42 AM |
