Old 19th January 2008, 10:27 AM   (permalink)
Don't know.. This is my advanced reply page all the while. I use typing for quote, code, bold and even smileys. colon D
Superman returns..
bananasiong is online now
Old 19th January 2008, 10:28 AM   (permalink)
Go to your CP and edit options -> miscenllaneous options (editor interface).
Switch to WYSIWYG
eng1 is offline
Old 19th January 2008, 10:32 AM   (permalink)
Oh, hm: is also here.. usually I type colon ohm colon..
Superman returns..
Old 19th January 2008, 10:33 AM   (permalink)
Looks like you've got something disabled either in your profile or in your browser. All the normal menus are missing!
futz is online now
Old 19th January 2008, 03:51 PM   (permalink)
Here's the steps, in case you don't know:
1. Select Project/Project Wizard
2. Step One: Select your device from the list.
3. Step Two: Select a language toolsuite. For assembler, the Active Toolsuite should be "Microchip MPASM Toolsuite". Don't change anything else on that page. Hit Next.
4. Step Three: Create New Project File. Browse to where you want your project stored. Create a directory for it if you want. If you do, move into the directory before naming the project so the project is created inside the directory. You would end up with a line like this example project named "bong" in a directory named "flop":
C:\MCU\16F84A\flop\bongName the project and hit Next.
5. Step Four: Add existing files to your project. If you have any asm source files already in the directory that you want added to the project, add them now. Hit Next.
6. Finish
Now select your programmer. If you haven't added a source file yet go Project/Add New File to Project and name your new empty xxxx.asm file.
That's it. You probably already knew all that, but maybe not. Impossible to tell from here.
thank you for helping
but i made all this and i still have the problem
please if you can hgelp me more , i would be grateful
m_saeed_soliman is offline
Old 19th January 2008, 04:02 PM   (permalink)
Which version of MPLAB are you using?
Superman returns..
Old 19th January 2008, 04:17 PM   (permalink)
version 8.00
i downloaded it 2 weeks ago
Old 19th January 2008, 04:47 PM   (permalink)
As I said earlier, why don't you use MAPASMWIN for now? It would allow you to assemble the code and get a working hex file. Meanwhile you can investigate what the problem with MPLAB is. Fors sure it's not the code, as it's been assembled with no errors (just the two irrelevant warnings about bank switching)
eng1 is offline
Old 19th January 2008, 04:53 PM   (permalink)
BCF    STATUS,RP0
or
BSF    STATUS,RP0
Regards,
William Mullaney
"HOPE for the best, EXPECT the worst, ACCEPT whatever comes."
http://wiliamsville.myminicity.com/
http://wiliamsville.myminicity.com/ind/
http://wiliamsville.myminicity.com/tra/
http://wiliamsville.myminicity.com/sec/
wmmullaney is offline
Old 19th January 2008, 04:57 PM   (permalink)
i have tried this but i faced a problem
when i come to assembling it says " program length may not exceed 62 charachters"
what is the solution
Old 19th January 2008, 05:02 PM   (permalink)
It cannot handle long filenames. Place the asm file in C:\leds\ for example and it will work.
eng1 is offline
Old 19th January 2008, 05:13 PM   (permalink)
yes, it worked. thank you
if you can more help me , please tell me what to do about Mplab
thanks
another thig please
Here in Egypt , We do not have Official Microchip prgrammer
so can MPlab program a PIC using a hand-made programmer of serial type or i will have to use winpic
thanks after all
Old 19th January 2008, 05:41 PM   (permalink)
Just got my MPLAB v8.0 installed, it works well. I was using v7.6.
Have you tried reinstalling it? Any third party software with programmer will work well
Superman returns..
Old 19th January 2008, 06:05 PM   (permalink)
Will v8 run on windows 98?
Regards,
William Mullaney
Old 19th January 2008, 06:11 PM   (permalink)
Why are you running that antique? That's like 50 years ago in computer-years!
futz is online now
PIC16F690 EEPROM counter issue pgenereu Micro Controllers 4 1st July 2007 02:21 AM
PIC programming!!! Styx General Electronics Chat 10 24th April 2006 06:23 PM
PIC 12 and 14 bits instruction sets Joel Rainville Micro Controllers 4 20th September 2005 09:15 AM
Question about bank selection, 16F628A, Nigel's tutorial kcn Micro Controllers 4 13th March 2005 07:23 AM
Processor Instruction Format mus3na Micro Controllers 1 19th January 2004 07:13 PM
