hello,
i recently got an atmel micro-controller. i downloaded its datasheet from the internet...to my horror i found out that the pin configuration of each of the controller change with their package specifications. so i scanned my controller to find package number which was unsuccessful. the controller is 40 pin. the bullshit printed on my micro-controller is: on the top side: at89c51ed2 -im 0631-6f5912 at the bottom side: PH G6F5912 can somebody pls help me out identify which damn package is this n where could i find its pin configurations and its datasheet |
I'm not sure if this is what you want but it's Atmel's own flash based micro with an 8051 core. It's pin-compatible with everyone else's 8051 chips.
Try googling for at89c51 or if that doesn't get you a datasheet there's loads of stuff for general 8051 chips. Does this help or am I missing the point? |
nopes...the story is....
i built all the ckt which was tobe interfaced to my at89c51ed2 controller. for this i need to identify the pins(eg:the 3rd pin is port1.3). for this i reffered to the datasheet tat i downloaded frm the net. now the controller tat i have is a 40 pin one. all those shown in the datasheet are either 44-pin or 68 pin. Searching for this particular datasheet has almost convinced me that the controller that i got was created during the 'stone age'...can u pls help..... (only if i could stick some more pins to make it 44 ;-)..) |
They were usually 40 pin in the past and those are the ones I've used.
http://www.cpu-world.com/info/Pinouts/8051.html Try that one for standard 8051. All varieties are meant to be pin-compatible so that should be it. |
MOV THANKS,1000;
thanks a lot...;-) |
You should be happy as Atmel has stopped making them.
They are pin compatible with the 80C51 so you can use the pinout of 80c51 instead. Many people can only obtain them in 44-pin PLCC package and so were looking everywhere for 40-pin package version. Perhaps you can do them a favour by telling them where these 40-pin version is still sold.
L.Chung |
What you have is a 40 pin 8051 device with 64K flash memory, with dual data pointers and an ISP programming interface. (lots of other stuff too)
They are good devices! I use them all the time. The best thing is that the ISP programming interface uses the uart pins already wired to a Max 232 circuit on most boards. To program it you can use flip from atmel. This program works well in windows and also can be run by command line (batch files with cmd files) Do a search for FLIP (Flexible In System Programmer) on the atmel website. If you can't find the datasheet for that particular device, let me know I have it. You can also get the Temic T89C51RD2 datasheet which is very similar (not 100%, but the pinout is exactly the same) Last edited by johnsmith123; 18th January 2008 at 02:00 AM. |
I have revision F of the datasheet. It clearly shows the part with the IM suffix as a 40 pin DIP Package. The current revision on the datasheet is "I" so I guess unless you have a way of getting an older copy of the datasheet you'll just have to go with the previous suggestions.
We never have time to do it right; but we always have time to do it over. |
| Simple I2C interface chip? | oeginc | General Electronics Chat | 20 | 29th March 2008 12:52 AM |
| Digital to analog converter chip | vuchris | Electronic Projects Design/Ideas/Reviews | 6 | 16th October 2007 09:02 AM |
| WRT54G Power Supply Chip | ParkingLotLust | Datasheet/Parts Requests | 32 | 5th January 2007 09:26 PM |
| AVR Dragon: My first chip | HarveyH42 | Micro Controllers | 4 | 3rd December 2006 01:35 AM |
| What chip to detect RF signals? | Mr Red | Electronic Projects Design/Ideas/Reviews | 0 | 24th June 2003 03:45 AM |
