| I've got my inchworm+ assembled and am trying to get it working to upload programs. When I got to the instructions about selecting the OS firmware file ICD01020701.HEX, the closest thing that came up with MPLab IDE v8 is ICD01020704.HEX. Is this a newer version of the same file? I'm anxious to get this thing in action and upload my first program. Thanks for all the help that you have supplied. I know it's been a trial dealing with many of my questions. Joe | |
| That's just the newest version. It'll work fine. It must be a 16F877-20 for that file, else use the one on my site for the 16F877A (MPLAB will still upload new firmware it just won't overwrite the bootloader) | |
| When downloading the ICD2 OS, I received the following errors after a few seconds during the download... ICDWarn0020: Invalid Target device id (expected=0x40, read=0x0) any ideas on what I need to do to correct this message? | |
| Sounds like your Inchworm works. 0x00 usually means it's not seeing a target device. Take a look and try building one of the Inchworm Quick Projects from the poster on my site. | |
| Is the ICD2 OS supposed to be uploaded to the PIC that come with the inchworm or to the end PIC I want to program? I understood it as being uploaded to the PIC supplied with the inchworm and I dont have the programmer hooked up to a "final target" PIC. That may be the problem was just the way I understood the instructions. The PIC that came with my inchworm+ is a PIC16F877-20/P. If it is the final pic with my code on it that needs the OS, will that file change depending on the final target PIC (ie a 16F628A)? | |
| The ICD2 firmware will be loaded automatically when needed. Your target PIC does not need any special firmware unless you use the debugger (not available in the 16F628A) and when you debug MPLAB will load it automatically When you do correctly connect a target PIC like the 16F628A (a good PIC) MPLAB will say it's OK. As for programming you can start with Nigels tutorials or for your very first one follow the advice in my last message. Also check out the links section on my site for lots and lots of PIC information including tutorials. | |
| Thanks for the help. I uploaded a program to a 16F628A and then read it back to see how some of the basic functions inside MPLab worked. I'm happy to report everything went smoothly. Again, I appreciate all the help. Joe | |
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | ||
Desoldering and replacing the socket is quite difficult too. None of this is impossible. Just kinda difficult. Too much abuse could kill your Inchworm+ board (lifted pads). Gotta be a bit careful.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 17th January 2008 at 07:23 AM. | ||
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 17th January 2008 at 07:32 AM. | ||
| You can carfully clip the 40pin socket ends off, and then it's easy to solder that underside connector. I'm happy to see you got it going. | |
| Quik PIC Programming kit | Krumlink | General Electronics Chat | 5 | 28th January 2008 12:27 AM |
| Capturing and reproducing audio with a PIC | Fred.Amoson | Micro Controllers | 14 | 14th December 2007 09:22 PM |
| Problems switchin relay with PIC | Andy1845c | General Electronics Chat | 5 | 17th November 2007 07:14 PM |
| High ADC sampling rate PIC, 18F needed? | bananasiong | Micro Controllers | 24 | 28th October 2007 01:13 PM |
| Four PIC with One LCD.. | meera83 | Micro Controllers | 13 | 20th September 2007 07:40 AM |
