Hello everyone,
I've been trying to get an interrupt to occur when data is received via the serial comm. Everything seems to be working as far as sending and receiving data, however when I switch the code to use an interrupt the interrupt never occurs, so the received data is never put into the rec_byte variable. I tried putting in a tmr0 interrupt just so it'd continually trigger the interrupt function and then everything works, but it's the tmr0 interrupt that is triggering and not the RCIE/RCIF... Basically, RCIF is getting set, but an interrupt isn't being generated or there's something wrong with my interrupt function, can anyone help me out? Thanks in advance! BTW, I'm using Microchip's MPLAB IDE with PICC Code:
#include <pic.h>
#include <string.h>
#include "delay.h"
__CONFIG(HS & WDTDIS & MCLREN & PWRTDIS & BORDIS & LVPDIS & UNPROTECT);
unsigned char rec_byte = '0';
void interrupt isr(void) @ 0x04
unsigned char x;
if(RCIF) // serial rx interrupt?
if (OERR == 1) // overrun, reset UART
CREN = 0; // disable UART
CREN = 1; // re-enable UART
else if (FERR == 1) // framing error (break?)
x = RCREG; // read and discard byte
rec_byte = RCREG;
void init_pic16f628a()
PORTA = 0x00; // Initialize PORTA
PORTB = 0x00; // Initialize PORTB
CMCON = 0x07; // comparators off
TRISA = 0x00; // PORTA Outputs
TRISB = 0x00; // PORTB Outputs
void init_usart(void)
TRISB |= 0x02; // Make RX pin an input (RB1)
TRISB &= 0xFB; // Make TX pin an output (RB2)
SPBRG = 129; // BaudRate=9600 @ 20Mhz as Table
// +0.16% error at this BaudRate
// PIE1 : EEIE CMIE RCIE TXIE —--- CCP1IE TMR2IE TMR1IE
PIE1 = 0b00110000; // replaces stuff below
// TXIE = 1; // enable serial tx interrupt
// RCIE = 1; // enable serial rx interrupt
GIE = 1; // enable global interrupts
// TXSTA : CSRC TX9 TXEN SYNC —--- BRGH TRMT TX9D
TXSTA=0b00100100; // Asynch,8bits,tx enb
// RCSTA : SPEN RX9 SREN CREN ADEN FERR OERR RX9D
RCSTA=0b10010000; // Cont receive enb
// send a single char
void usart_write_char(unsigned char ucChar)
TXREG = ucChar;
while(TRMT==0); // Wait for TX to finish
void main()
init_pic16f628a();
init_usart();
while(1)
//while(!RCIF); // Wait until data recieved
//rec_byte=RCREG; // Store for later
usart_write_char(rec_byte); // Transmit
delay(200);
Oh, also I've found a post on this forum saying that PEIE has to be set for this. However, looking at the datasheet for the PIC16F628a I could not see this, specifically looking at section 12.2.2
So I went and set PEIE to see if it would help. With the code I have, setting PEIE seems to "hang" the PIC |
So it did come down to being PEIE, I set this but got a hang, so I cleared TXIE since I'm not using a TX interrupt at the moment and it got rid of the hang and got the program working normally...
It hangs because you are setting TXIE but you don't have any service code for it and so the interrupt is constantly retriggered. Change it back to just setting RCIE, PEIE and GIE. Also, both tris bits have to be set to input for the UART to function properly (see step 1 - page 82) .
Mike. |
| Problem in serial interrupt. | sarang1_in | Micro Controllers | 3 | 25th November 2004 03:09 AM |
| Problem about the Interrupt in PIC16F84A... pls pls~~ help!! | Gundam82 | Micro Controllers | 9 | 2nd October 2004 04:13 AM |
| quick interrupt question | evandude | Micro Controllers | 2 | 11th August 2004 08:59 PM |
| Interrupt on GP Change problem | Dan East | Micro Controllers | 2 | 22nd May 2004 05:12 PM |
| Interrupt problem | huanyong | Micro Controllers | 1 | 1st November 2003 01:25 AM |
