| Hi, I have revisited a simple ADC project using 12f675. I've set GPIO,0 as analogue in, & GPIO,1 & 2 as outputs connected to two led's used to indicate input level < or> depending on value set in ADC reading (e.g. 2volts) I set a DC value between 0v (Vss & 5v = Vdd) using a 10k pott. ADC set up for ext ref 5v vdd. The circuit works_accept as I advance the pott in either direction the led's alternatively switch on and off as the voltage increases or decreases at several intervals. The adc voltage value = 102 (2 volts) for 8 bit convertion. One led should be lit only when > 2v & the other lit < 2v. I'm using the pott only to prove my circuit, and eventually use either a temp sensor (resistive) or an LDR device with one of the GPIO's to switch a relay. This is the first time I've used this PIC and come accross this problem. I have included the asm listing. Note very new to programming_most gratefull again for any assistance. [ ;************************************************* ********************* ; * ; Filename: xxx.asm * ; Date: * ; File Version: * ; * ; Author: * ; * ; * ; * ;************************************************* ********************* ; * ; Files required: * ; 12F675.lkr * ; * ; * ;************************************************* ********************* ; * ; Notes: * ; * ; * ; * ; * ;************************************************* ********************* list p=12f675 ; list directive to define processor #include <p12f675.inc> ; processor specific variable definitions errorlevel -302 ; suppress message 302 from list file __CONFIG _CP_OFF & _CPD_OFF & _BODEN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT ; '__CONFIG' directive is used to embed configuration word within .asm file. ; The lables following the directive are located in the respective .inc file. ; See data sheet for additional information on configuration word settings. ;***** VARIABLE DEFINITIONS (examples) ; example of using Shared Uninitialized Data Section INT_VAR UDATA_SHR 0x20 w_temp RES 1 ; variable used for context saving status_temp RES 1 ; variable used for context saving ;************************************************* ********************* RESET_VECTOR CODE 0x000 ; processor reset vector goto main ; go to beginning of program INT_VECTOR CODE 0x004 ; interrupt vector location movwf w_temp ; save off current W register contents movf STATUS,w ; move status register into W register movwf status_temp ; save off contents of STATUS register ; isr code can go here or be located as a call subroutine elsewhere movf status_temp,w ; retrieve copy of STATUS register movwf STATUS ; restore pre-isr STATUS register contents swapf w_temp,f swapf w_temp,w ; restore pre-isr W register contents retfie ; return from interrupt ; these first 4 instructions are not required if the internal oscillator is not used call 0x3FF ; retrieve factory calibration value bsf STATUS,RP0 ; set file register bank to 1 movwf OSCCAL ; update register with factory cal value ; set file register bank to 0 ; ======================= DELAY ================================= DELAY1 CLRF TMR0 ; START TMR0 LOOPBB MOVF TMR0,W ; READ TMR0 INTO W SUBLW .200 ; TIME -W BTFSS STATUS,Z ; CHECK TIME W = 0 GOTO LOOPBB RETLW 0 ; RETURN AFTER TMR0 = 100 main bsf STATUS,RP0 ; select bank 0 movlw .9 ;B'00001001' ; SET BIT 0 as input ; movwf TRISIO movlw B'00000111' movwf OPTION_REG movlw B'00010001' ;set bit 0 as analogue input movwf ANSEL bcf STATUS,RP0 movlw B'00000111' movwf CMCON bcf STATUS,RP0 movlw B'00000001' ; left justified (bit7=0) /255 movwf ADCON0 clrf GPIO ;======================== START OF PROGRAM ============================ BEGIN bsf ADCON0,GO WAIT btfsc ADCON0,GO goto WAIT bsf STATUS,RP0 movf ADRESL,W sublw .102 ; 8 bit ADC convertion = 255/5 x 2v = 102 ; == 10 BIT ADC CONVERTION _ 2volts btfsc STATUS,C ; 1,023 / 5volt vdd = 204.6 x voltage in goto LED1 ; e.g_ 2volts x 204.6 = 409 goto LED2 LED1 bcf STATUS,RP0 bsf GPIO,1 bcf GPIO,2 goto BEGIN LED2 bcf STATUS,RP0 bsf GPIO,2 bcf GPIO,1 goto BEGIN END ] | |
| Check out the thread called "ADC in assembly" Today january 15, 2008 it is still on the second page of the forum. I put a code and a circuit diagram that work really well and are a good starting point for newbie ADC. Tonight I'll post another code with how to move a servo based on ADC. I hope this helps you in the right dirrection.
__________________ jeremy | |
I have been an electronics eng for over 50 years, and must admit it's easy using Micro's_but only if you can program them! Cheers Folks. | ||
| Cheers Mike, solved it_ see my reply. Kind Regards Merv | |
| Circuit Help | skeeterb | Electronic Projects Design/Ideas/Reviews | 7 | 5th May 2008 07:10 PM |
| Analog circuit works until a I hook to Adc. | jnnewton | Electronic Projects Design/Ideas/Reviews | 2 | 7th January 2008 11:50 AM |
| Help! Adc On A Pic12f675 | UrabnBadger | Micro Controllers | 13 | 25th November 2007 09:36 PM |
| Circuit auto OFF feature after no events design | Uman | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2004 06:34 AM |
| Circuit functioning very strange. Why? | Cyclone | Electronic Projects Design/Ideas/Reviews | 12 | 4th November 2003 01:31 AM |
