| Hello guy, i am new here. just finish reading a few posts and find this forum helpful Well, i faced a problem programming DS1302 with PIC16C745. my problem is: i have write in time for the RTC and after 2 mins from it start, it have to turn off my LED which is initially on. i got the program out already, but i don't know where i have went wrong that the program is unable to work. i really hope someone can provide me with help the following is my program. LIST P=16C745 #INCLUDE <P16C745.INC> #DEFINE CE PORTC,0 ;Define PORTC,0 as CE, so as to show the link between PIC16C745 and DS1302 #DEFINE SCLK PORTC,1 ; #DEFINE IO PORTC,2 ; errorlevel -302 ; suppress "register not in Bank 0, check page bits" message Bank0 udata REGWRITE RES 1 ;To define all the following label, use this method (XXXX RES 1) TIME_COUNT RES 1 TIME_TEMP RES 1 ;--------------------------------END OF DECLARATION------------------------------------- ORG 0 MAIN BCF STATUS,RP0 ;Activates Bank 0, because PORT(X) located in Bank 0 - See PIC16C745 memory table. CLRF PORTB ;Resets PORTB, Set B'00000000' into PORTB BSF STATUS,RP0 ;Activates Bank 1, because TRIS(X) located in Bank 1 MOVLW B'00000000' ;Set PORTB as output port MOVWF TRISB ;Send the previous binary to this exact location BCF STATUS,RP0 ;Activates Bank 0, because PORT(X) located in Bank 0 - See PIC16C745 memory table. BSF PORTB,6 ;Turns on LED BSF PORTB,7 ;Turns on LED ;------------------------DS1302 Real Time Counter------------------------------- Start CALL WRITE_EN ;Call this subroutine so as to start up the transmission between PIC and RTC MOVLW 0X8E ;Insert B'10001110' into REGWRITE, to point to the address - Control MOVWF REGWRITE ; CALL WRITE_RTC ;Call this subroutine whenever you are inputing the number into RTC MOVLW 0x00 ;Control register MOVWF REGWRITE ; CALL WRITE_RTC ;****************************************** CALL WRITE_EN MOVLW 0X80 ;Insert B'10000000' into REGWRITE, to point to the address - Sec MOVWF REGWRITE CALL WRITE_RTC MOVLW 0X00 ;Second will start at 0 MOVWF REGWRITE CALL WRITE_RTC ;****************************************** CALL WRITE_EN MOVLW 0X82 ;Insert B'10000010' into REGWRITE, to point to the address - Min MOVWF REGWRITE CALL WRITE_RTC MOVLW 0X03 ;Minute will start at 3 MOVWF REGWRITE CALL WRITE_RTC ;****************************************** CALL WRITE_EN MOVLW 0X84 ;Insert B'10000100' into REGWRITE, to point to the address - Hour MOVWF REGWRITE CALL WRITE_RTC MOVLW 0X15 ;Hour will start at 3pm MOVWF REGWRITE CALL WRITE_RTC ;****************************************** the code below is the part where i test whether is it 2 mins past, if yes, turn off the initially on LED, is there sth wrong? TURNOFF_LED CALL READ_MIN MOVF TIME_TEMP,W SUBLW 0X05 BTFSS STATUS,Z GOTO TURNOFF_LED BCF STATUS,C BCF PORTB,7 GOTO MAIN Until here.. ;****************************************** READ_MIN CALL WRITE_EN MOVLW 0X83 ;In order to read, you need to mention which address you want to read MOVWF REGWRITE CALL WRITE_RTC BSF STATUS,RP0 MOVLW B'00000100' MOVWF TRISC BCF STATUS,RP0 CALL READ_RTC NOP BCF CE NOP NOP RETURN ;----------------------------------Subroutines---------------------------------------- WRITE_EN CLRF PORTC ;Resets PORTC, Set Binary '00000000' into PORTC BSF STATUS,RP0 ;Activates Bank 1, because TRIS(X) located in Bank 1 MOVLW B'00000000' ;Using this line and the following line together means MOVWF TRISC ;to set binary '00000000' into PORTC, to set as output BCF STATUS,RP0 ;Activates Bank 0 BSF CE ;Input logic '1' to RST of DS1302, all communication sequences are intitiated by driving RST high RETURN ;****************************************** WRITE_RTC MOVLW 0X08 ;'0X' is use for hexadecimal, 08 is the hexadecimal number. MOVWF TIME_COUNT ;Move the hexadecimal into this TIME_COUNT label WRITE_LOOP BCF SCLK ;Disallow data movement BSF IO ;Set I/O pin to 'high' BTFSS REGWRITE,0 ;Ensure that bit 0 is a 0, so that it mean to write into the RTC BCF IO ;Set I/O pin to 'low' NOP ;No operation, coz' this command provide a timing break to the next command BSF SCLK ;Allow data movement since there is a need to write to RTC RRF REGWRITE,1 ;Rotates bit 1 in REGWRITE to the right, and put the result back in REGWRITE DECFSZ TIME_COUNT,1;Decrements a file register and if the result is zero, skips the next instruction and result will be put back into file register GOTO WRITE_LOOP ;Looping RETURN ;****************************************** READ_RTC CLRF TIME_TEMP MOVLW 0X08 ;'0X' is use for hexadecimal, 08 is the hexadecimal number. MOVWF TIME_COUNT ;Move the hexadecimal into this TIME_COUNT label READ_LOOP BSF SCLK BSF STATUS,C BTFSS IO BCF STATUS,C BCF SCLK RRF TIME_TEMP,1 DECFSZ TIME_COUNT,1;Delay GOTO READ_LOOP ;Looping MOVF TIME_TEMP,0 RETURN ;****************************************** ;------------------------------------------End of Subroutine------------------------------------- END | |
| Well my attention span isn't what it used to be, so I'm not going to try to debug your code. But, what I will say, is to seperate your code. From the sound of it, the only 'output' you have is that little LED. Not much indication of what is going on. I would first make sure that the RTC is working correctly. That is, write (or copy from your above code) a routine to program the DS1302. Then read it back. This will involves some form of 'SPI-like' interface....which you appear to have. Also, I believe the PIC16C745 has a UART? It may be beneficial to use it to communicate with a PC to see what is going on. Read the time from the RTC, and send it to the UART. You do'nt have to format it in anyway. It may be over-kill but it'll be helpfull...otherwise how would you know if you are writing/reading the RTC correctly? Or perhaps some LED's....maybe an LED flash routine after every write/read. So if your LED doesn't flash at all, you know it has got stuck somewhere. Step by step my friend, it may be a long process rather than just spotting the problem in your code...but its good practice. I assume you MUST use an RTC? if all you need to do is to turn off an LED 2 minutes after the microcontroller is powered....just use a delay routine. You know the clock frequency, so its just a matter of counting. Blueteeth Also, I just noticed a bit of your code After you have turned off the LED, simply have a loop that goes nowhere. OR....a delay so you can at least see the LED turn off.
__________________ Inconsistency is the key to flexibility! Last edited by Blueteeth; 14th January 2008 at 07:32 AM. | |
| Please use Code tags when posting code. Simply click on the # in the menu before pasting your code. By the way, you don't have to use uppercase for all your code. In my opinion that just makes it hard to read. Code tags make it look like this: Code: LIST P=16C745 #INCLUDE <P16C745.INC> #DEFINE CE PORTC,0 ;Define PORTC,0 as CE, so as to show the link between PIC16C745 and DS1302 #DEFINE SCLK PORTC,1 ; #DEFINE IO PORTC,2 ; errorlevel -302 ; suppress "register not in Bank 0, check page bits" message Bank0 udata REGWRITE RES 1 ;To define all the following label, use this method (XXXX RES 1) TIME_COUNT RES 1 TIME_TEMP RES 1 ;--------------------------------END OF DECLARATION------------------------------------- ORG 0 MAIN BCF STATUS,RP0 ;Activates Bank 0, because PORT(X) located in Bank 0 - See PIC16C745 memory table. CLRF PORTB ;Resets PORTB, Set B'00000000' into PORTB BSF STATUS,RP0 ;Activates Bank 1, because TRIS(X) located in Bank 1 MOVLW B'00000000' ;Set PORTB as output port MOVWF TRISB ;Send the previous binary to this exact location BCF STATUS,RP0 ;Activates Bank 0, because PORT(X) located in Bank 0 - See PIC16C745 memory table. BSF PORTB,6 ;Turns on LED BSF PORTB,7 ;Turns on LED ;------------------------DS1302 Real Time Counter------------------------------- Start CALL WRITE_EN ;Call this subroutine so as to start up the transmission between PIC and RTC MOVLW 0X8E ;Insert B'10001110' into REGWRITE, to point to the address - Control MOVWF REGWRITE ; CALL WRITE_RTC ;Call this subroutine whenever you are inputing the number into RTC MOVLW 0x00 ;Control register MOVWF REGWRITE ; CALL WRITE_RTC ;****************************************** CALL WRITE_EN MOVLW 0X80 ;Insert B'10000000' into REGWRITE, to point to the address - Sec MOVWF REGWRITE CALL WRITE_RTC MOVLW 0X00 ;Second will start at 0 MOVWF REGWRITE CALL WRITE_RTC ;****************************************** CALL WRITE_EN MOVLW 0X82 ;Insert B'10000010' into REGWRITE, to point to the address - Min MOVWF REGWRITE CALL WRITE_RTC MOVLW 0X03 ;Minute will start at 3 MOVWF REGWRITE CALL WRITE_RTC ;****************************************** CALL WRITE_EN MOVLW 0X84 ;Insert B'10000100' into REGWRITE, to point to the address - Hour MOVWF REGWRITE CALL WRITE_RTC MOVLW 0X15 ;Hour will start at 3pm MOVWF REGWRITE CALL WRITE_RTC ;****************************************** the code below is the part where i test whether is it 2 mins past, if yes, turn off the initially on LED, is there sth wrong? TURNOFF_LED CALL READ_MIN MOVF TIME_TEMP,W SUBLW 0X05 BTFSS STATUS,Z GOTO TURNOFF_LED BCF STATUS,C BCF PORTB,7 GOTO MAIN Until here.. ;****************************************** READ_MIN CALL WRITE_EN MOVLW 0X83 ;In order to read, you need to mention which address you want to read MOVWF REGWRITE CALL WRITE_RTC BSF STATUS,RP0 MOVLW B'00000100' MOVWF TRISC BCF STATUS,RP0 CALL READ_RTC NOP BCF CE NOP NOP RETURN ;----------------------------------Subroutines---------------------------------------- WRITE_EN CLRF PORTC ;Resets PORTC, Set Binary '00000000' into PORTC BSF STATUS,RP0 ;Activates Bank 1, because TRIS(X) located in Bank 1 MOVLW B'00000000' ;Using this line and the following line together means MOVWF TRISC ;to set binary '00000000' into PORTC, to set as output BCF STATUS,RP0 ;Activates Bank 0 BSF CE ;Input logic '1' to RST of DS1302, all communication sequences are intitiated by driving RST high RETURN ;****************************************** WRITE_RTC MOVLW 0X08 ;'0X' is use for hexadecimal, 08 is the hexadecimal number. MOVWF TIME_COUNT ;Move the hexadecimal into this TIME_COUNT label WRITE_LOOP BCF SCLK ;Disallow data movement BSF IO ;Set I/O pin to 'high' BTFSS REGWRITE,0 ;Ensure that bit 0 is a 0, so that it mean to write into the RTC BCF IO ;Set I/O pin to 'low' NOP ;No operation, coz' this command provide a timing break to the next command BSF SCLK ;Allow data movement since there is a need to write to RTC RRF REGWRITE,1 ;Rotates bit 1 in REGWRITE to the right, and put the result back in REGWRITE DECFSZ TIME_COUNT,1 ;Decrements a file register and if the result is zero, skips the next instruction and result will be put back into file register GOTO WRITE_LOOP ;Looping RETURN ;****************************************** READ_RTC CLRF TIME_TEMP MOVLW 0X08 ;'0X' is use for hexadecimal, 08 is the hexadecimal number. MOVWF TIME_COUNT ;Move the hexadecimal into this TIME_COUNT label READ_LOOP BSF SCLK BSF STATUS,C BTFSS IO BCF STATUS,C BCF SCLK RRF TIME_TEMP,1 DECFSZ TIME_COUNT,1 ;Delay GOTO READ_LOOP ;Looping MOVF TIME_TEMP,0 RETURN ;****************************************** ;------------------------------------------End of Subroutine------------------------------------- END
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | |
| One quick comment - why are you using an OTP device? - even assuming you have UV eraseable verions, it makes for a massively slow programming cycle!. Use one of the more modern EEPROM or FLASH based chips, it will be so much faster. | |
| thanks to those who reply and provide guides. =) i uses OTP because it's my school project, and my lecturer only want PIC16C745. so i have to use it. =) | |
| OTP devices? Thats a bit harsh! Your 'lecturer' can't expect all software to work flawlessly first time..unless its a course on using software emulators and debuggers Anyway, did you get it working?
__________________ Inconsistency is the key to flexibility! | |
| I assume he is using the JW version that has a window so it can be UV erased. A good eraser wipes them in a couple of minutes. If he isn't using a JW version then I would use a similar flash pic to get the I2C working and then get the USB working later. Mike. Last edited by Pommie; 15th January 2008 at 05:07 AM. | |
| No. i did not get it working. therefore i needed people here to help me. to blueteeth, talking about the 'goto main' that thing, i made adjustment already, however, the problem don't seem to be it. | |
| the previous problem about the LED turning off automatically after 2 minutes from the RTC clocking have already works. =) and for now, i added in a subroutine so that for whichever time that comes in from an external GUI, i am able to also turn off the LED after two minutes from that time set in the GUI. but my subroutine don't seemed to work. can anyone help me out in this? thanks Code: CALL SMS_TIME TURNOFF_LED CALL READ_MIN MOVF TIME_TEMP,W SUBWF smstime,0 BTFSS STATUS,Z GOTO TURNOFF_LED BCF PORTB,7 BCF STATUS,C Loop GOTO Loop SMS_TIME CALL READ_MIN MOVF TIME_TEMP,W ADDLW 0X04 MOVWF smstime RETURN | |
| Assuming that your Read_Min subroutine gets the minute value from the DS1302 then it will be in BCD format. You cannot just add 4. Think what happens when the minute value is 17, when you add 4 it becomes 1B which is not a valid time. What you need to do is bcd addition. Try, Code: CALL READ_MIN MOVF TIME_TEMP,W addlw 0x04 ;add 4 addlw 0x06 ;add 6 to test for overflow btfss STATUS,DC ;overflowed addlw 0x100-0x06 ;no so add -6 (sub 6) MOVWF smstime | |
| isn't there a flash version of the pic ? if so lay with that then change for the OTP device to keep your teacher happy
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) my site:www.simons-photography.com http://rushdenrotaract.org.uk | |
| thanks for the reply, prommie and thunderchild. To prommie, i tried out your codes, but i don't think the problem lies on the part you wrote in. but i think i will definitely need it too. =) i think the SMS_TIME subroutine seemed to have alittle problem. when my program goes like this: Code: CALL SMS_TIME TURNOFF_LED CALL READ_MIN MOVF TIME_TEMP,W SUBWF smstime,0 BTFSS STATUS,Z GOTO TURNOFF_LED BCF PORTB,7 BCF STATUS,C Loop GOTO Loop SMS_TIME CALL READ_MIN MOVF TIME_TEMP,W MOVLW OXOB MOVWF smstime RETURN | |
| The value you receive from the 1302 will never equal 0x0b and so the subtraction will never result in zero. The minutes value will go from 0x09 to 0x10 and therefore miss out 0x0b. Mike. | |
| oh but previously i tried a simple program using 0x0b, it works.. but most important is that, i not sure whether the program really goes into the subroutine (SMS_TIME). | |
| If it worked with 0x0b then you must have written that value to the 1302. The 1302 will never produce 0x0b during normal operation. You cannot have a value of 11 (0x0b) in the units digit, the next increment after 0x09 will be 0x10. Mike. | |
| DS1302 with PIC16f877 program | RasCreationKing | Micro Controllers | 28 | 3rd May 2007 01:03 PM |
| accuracy required in DS1302 based clock | elecfriend | General Electronics Chat | 10 | 13th August 2006 06:36 AM |
| DS1302 Two chips ? ( one of set time ) | 1Steveo | Micro Controllers | 4 | 8th May 2006 10:14 PM |
| General pic16C745 question? | gil | Micro Controllers | 7 | 17th November 2004 04:13 PM |
| Multiplexing analog lines over PIC16C745 and then USB | dario_alvarez | Micro Controllers | 0 | 16th February 2004 06:00 PM |
