Old 24th October 2009, 12:12 PM   #31
No, I am affraid that he is longer here.
I myself am working in the range 200-900Watts. This works quite well with a toroid transformer and phase cutting.
ronald_jansen is offline
Old 24th October 2009, 11:32 PM   #32
Default 16kw heated platen, pid regulation
Thank you all for your ideas. I'll use 12mm alu plate plus reinforcement because of the all pressure from vacuum. So there will be some mass to heat for sure. The slower control loop i will try for sure. For the first test I make a smaller model with 1/10 of the power/mass and test the stability first. This is a 3 phase system, So each phase is about 5.3kw only. The SSR crydom says switching at zero crossing in the datasheet. So basicly I have K type thermocouple (thinking about 2-4! to average the reading in alpha PLC software/hardware and make it somewhat bulet proof, sensors will be burried in the platen not too close to the incoloy elements,and from various sources i will add a second overheat protective system. In case of the SSR manfunction they stay conducting i was told. So I guess it is really a must to add some kind of temperature limit switch in case something fails. Will keep you informed but this is a projet for more than 1 or 2 months so don't expect many posts any time soon, I'm also a happy father now.
nemo50 is offline
control, phase, triac
Variable capacitor circuits walters General Electronics Chat 92 7th February 2009 08:08 PM
AC Phase controlling by Triac for AC motor speed control chanoknun108 Electronic Projects Design/Ideas/Reviews 3 23rd August 2008 03:31 PM
Phase control dimming Adam Micro Controllers 0 20th April 2004 08:18 PM
Pic 16f84 triac AC phase control Drei Micro Controllers 2 3rd September 2003 04:21 PM
