Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. |
I have used breadboards for many projects and as I stated in the breadboards thread,
Mike. |
ssylee,
Is the clock running. If so, is it running slow or fast. If you set a time and immediatly read it back, is it correct? Mike. |
Pommie:
Should the crystal's signal be a PWM or sine waveform? B/c when I measured the clock, I don't see anything. |
I'm getting a sine wave signal between pin 3 and ground at 32.7 kHz with a peak to peak voltage of 247 mV. I don't see anything between pin 2 and ground, only a constant voltage of 200 mV. Is this an indicator of anything?
Monitoring the crystal may stop it working. The data sheet suggests monitoring the second register in order to establish if the crystal is running. Have a read of the section "Checking For Oscillation" in the data sheet linked to earlier by Picasm.
Mike. |
Nothing thing aout breadboards and crystals.....of course they add all sort of parasitic stuff to it, but also, quite simply...watch crystals do not have very thick legs.....and breadboards need good pins to make contact
My two cents. Blueteeth
Inconsistency is the key to flexibility! |
I regularly check oscillators on micro-controllers, at x1 it stops pretty well all of them, at x10 it usually works perfectly fine on either end of the crystal. Now I would have expected (probably like most people here?) that the lower the crystal the less effect it would have - however, like I said before, I had occasion to scope a 32KHz crystal last week, and even on x10 it killed the oscillation on one end of it. I presume this is probably because it's a very low power circuit, so it can run off tiny batteries?. |
Nigel,
I was questioning your statement with regard to a x10 probe, you stated, Quote:
Mike. |
(permalink) | |||
From a Wikipedia article: Quote:
(permalink) | ||
Mike. |
One would think that by looking a the title of a thread you could guess at about how many posts it would take to put it to rest.
There are a few things that put this out of wack. Change of topic or hijack. Last edited by 3v0; 6th January 2008 at 02:28 PM. |
| Real Time FLIR Video Feed | digital0ne | Robotics Chat | 3 | 11th April 2004 06:21 PM |
| digital clock setting the time mode | Jay Duluguin | Electronic Projects Design/Ideas/Reviews | 0 | 19th February 2004 10:09 PM |
| real time clock | finst | Micro Controllers | 4 | 17th January 2004 12:11 AM |
| list of Real Time Clock | thendo | Micro Controllers | 2 | 8th November 2003 05:41 PM |
| time clock | gogo01 | Electronic Projects Design/Ideas/Reviews | 2 | 22nd August 2003 05:05 AM |
