View Poll Results: How much are people willing to pay for a PIC programmer and tester board?
Dont want one! 4 26.67%
£0 to £5 4 26.67%
£5 to £10 3 20.00%
£10 to £15 3 20.00%
£15 to £20 1 6.67%
Voters: 15. You may not vote on this poll
Old 27th September 2003, 10:07 AM   (permalink)
Default PIC programmer and tester (POLL)
this is a preliminary survay for my college project, wourking out how popular a cheap pic programmer and tester board would be. here are what the board featuires will be:
Programms all pic chips
tests all pic chips
set of switches for each port
set of LED's for each port
Anaglogue inputs (undecided amount)
a 38Khz TX and RX (for use with testing)
Expansion facility
Parrallel port programming
andy.davies is offline   Reply With Quote
Old 27th September 2003, 01:31 PM   (permalink)
Before polling, I would like you to clarify one thing. Will the programmer have a universal ZIF socket in which all PICs will be programmed or a different socket/adapter for each new PIC one can imagine. I just hate adapters.
And one more thing, why have you chosen parallel port? That's other thing I don't like to use because of very short cable length that it supports inspite of using buffers. RS232 rules over 15m radius and RS485 over 1.2 km. This doesn't mean that I wish to place my programmer hundreds of meters away from my PC, but the above figures reveals the noise immunity of parallel port. Its very very poor. I have spent months debugging one of my programmer circuit and finally found that the 3m parallel scanner cable that I was using was the cause of trouble. Reducing it to 1.5m solved it.
Old 27th September 2003, 07:00 PM   (permalink)
yes, universal ZIF socket was the idea, i should have made this clear. and i chose parallel, because of very fast programming times <1 second 90% of the time
Old 3rd October 2003, 02:27 PM   (permalink)
A PIC programmer is useless unless it has good software supporting it.
A parallel programmer does not support any 8 pin chips or memories.
So:
I would like to see a serial programmer that supports ICSP (including doing the rb4 bit to ground), and, most importantly, decent software that supports it and ALL the latest pics.
The problem is that on my present application, I spent more time arsing around trying to figure out how to configure the programmer for a new PIC type than on the application itself.
Mark K.
MarkK is offline   Reply With Quote
Old 4th October 2003, 09:06 AM   (permalink)
the software that i use doews allow for 8 pin chips, and i belive it has some memory capabilitys, to get the software goto http://www.picallw.com
There are 10 types of people, Those who understand binary and those who dont!
www.casiofortissimo.co.nr
http://aful.org/images/patent_button.gif
Old 4th October 2003, 09:22 PM   (permalink)
Exo
P16Pro40 is a parallel programmer with support for 8pin chips ....
Exo is offline   Reply With Quote
Old 4th October 2003, 09:25 PM   (permalink)
at least someone agrees with me, where can i get P16PRO40 from, i use PICALL v0.10d
Old 5th October 2003, 09:52 AM   (permalink)
Yes, what I mean is that a PURELY parallel programmer design wouldn't support 8pin chips....
Mark K.
Old 5th October 2003, 01:28 PM   (permalink)
Exo
The design for p16pro40 can be found on
http://www.lpilsley.co.uk/pdf/p16pro40.pdf
it should work with picallw
Other good software wich I use is winpicprog ( www.winpicprog.co.uk )
Old 6th October 2003, 08:03 AM   (permalink)
sorry, little bit of confusion there, i thought that P19PRO40 was a piece of software, not hardware,this is good, i already have it . and i am going to try using winpicprog aswell
