| I want to make a lock which can be controlled by a 4x4 keypad for a 4 bit code. I want to use micro controller so that the code can be changed whenever the user wants. And also a LCD display to display whats typed. As a beginner to micro controller where should I start from? Which MC would be best?? PIC or others?? Programming in Assembly or C?? Any kind of help is appreciated. Just think of me as a beginner. | |
| Check my PIC tutorial, which has almost exactly what you need!. | |
| Someone Please check this tutorial: http://www.mstracey.btinternet.co.uk/pictutorial Does all the PICs have same instructions? I know C language (not for micro controller, only general purpose) but is it better to program PIC in assembly? | |
| ruzfactor, You have been given some good advice right here: Quote:
| Nigel's PIC Tutorial is excellent. But the problem is, it's for PIC16F628. But I didn't find any PIC16F628 in the shop.I have a PIC16F84A.That's why I asked! | |
| Also I don't know assembly language and I find it a bit hard. I'm completely new to this MCU field. | |
| I've just finished building the P16PRO40 programmer. I was wondering if it runs under a WIN98 based Laptop and also does it support F84A? | |
| Yes to both - but the 84 is an absolute antique, it was replaced by the 628 last century, but appears to have been re-introduced for all the idiots who keep buying them, and paying extra money for them!. The 628 isn't a new chip, but it's higher spec than the 84, and considerably cheaper. 628 uses the same 14 bit core, and the code requires very few changes to work - main problem is the lack of resources in the 84 - such as number of I/O pins. | |
| I have connected the P16PRO40 to my laptop. And when I connected it and turn on the laptop the red led turned on & when win98 was loaded the green led turned on. But when I tried to write PIC with the WINPICPROG 1.91 it gave an error: Program Verify failed at Program address 0x000, Programming Aborted! Any idea why i'm getting this error? | |
| The P16PRO40 is a typical JDM style programmer and may not run unless it's on a real RS232 port (No USB to RS232 adapters) They are also somewhat unreliable. | |
| I thought this would work! | |
__________________ ========================= Futz's Microcontrollers & Robotics ========================= Last edited by futz; 2nd January 2008 at 07:40 PM. | ||
| Ordering online requires CC and I don have a CC | |
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | ||
| P16PRO40 is a parallel port (Tait style) programmer, not a JDM style programmer. If assembled correctly it should work fine on a laptop. | |
| Questions from a beginner in electronics... | Shocks McTool | General Electronics Chat | 8 | 21st November 2005 03:01 AM |
| beginner please help | lordsathish | Micro Controllers | 8 | 15th June 2005 12:26 PM |
| beginner in microcontrollers | lordsathish | Micro Controllers | 13 | 6th June 2005 02:18 PM |
| Beginner Questions: AC, Impedence, Transistors, and Salving | budidharma | General Electronics Chat | 5 | 9th December 2004 09:43 PM |
| Any Good ARM chip set for beginner? | mikemikemike | Micro Controllers | 0 | 15th January 2004 04:37 PM |
