Old 18th December 2007, 10:11 AM   (permalink)
Default in trouble with LCD (JHD162A)
Hello, recently doing a project using LCD-JHD162A with PIC 16F877. Everything was done, but the LCD cannot display any character. It really frustrated. Hopefully, somebody can kindly give some comment. The coding is shown as below: (SCHEMATIC DIAGRAM AT http://www.cytron.com.my/Images/project/schematicPR3.gif)
LIST P=16F877
#INCLUDE <P16F877.INC>
__CONFIG 0X3F32
;========================MACRO ===========================
BANK0 MACRO
BCF STATUS,RP0
BCF
ENDM
BANK1 MACRO
BSF STATUS,RP0
BCF STATUS,RP1
ENDM
CLOCK_E MACRO
BSF PORTD,3
CALL DELAY2
BCF PORTD,3
ENDM
;========== VARIABLE ======================================
D1 EQU 0X20
D2 EQU 0X21
D3 EQU 0X22
D4 EQU 0X23
D5 EQU 0X24
D6 EQU 0X25
;========== MAIN PROGRAMME ===============================
ORG 0X000
GOTO START
STOP ORG 0X004
GOTO STOP
START BANK0
CLRF PORTA
CLRF PORTB
CLRF PORTC
CLRF PORTD
CLRF PORTE
BANK1
MOVLW 0x06
MOVWF ADCON1
CLRF TRISA
CLRF TRISB
CLRF TRISC
CLRF TRISD
CLRF TRISE
BANK0
CLRF PORTB
;*****************LCD INITIALIZED****************************
CALL DELAY1
BCF PORTD,2
MOVLW B'00110000'
MOVWF PORTB
CLOCK_E
CALL DELAY2
MOVLW B'00001101'
MOVWF PORTB
CLOCK_E
CALL DELAY3
MOVLW B'00111000'
MOVWF PORTB
CLOCK_E
MOVLW B'00000001'
MOVWF PORTB
CLOCK_E
MOVLW B'00000110'
MOVWF PORTB
CLOCK_E
;****************MESSAGES DISPLAY IN LINE 1 ******************
BSF PORTD,2
MOVLW H'59'
MOVWF PORTB ;DISPLAY "YES"
CLOCK_E
MOVLW H'45'
MOVWF PORTB
CLOCK_E
MOVLW H'53'
MOVWF PORTB
CLOCK_E
;****************SET LCD TO SECOND LINE**********************
BCF PORTD,2
MOVLW B'11000000'
MOVWF PORTB
CLOCK_E
;****************MESSAGES DISPLAY IN LINE 2******************
BSF PORTD,2
MOVLW H'31'
MOVWF PORTB ;DISPLAY123
CLOCK_E
MOVLW H'32'
MOVWF PORTB
CLOCK_E
MOVLW H'33'
MOVWF PORTB
CLOCK_E
GOTO $-1
;========== SUBROUTINE FOR DELAY ===========================
DELAY1 MOVLW D'65' ;DELAY 50ms
MOVWF D2
MOVLW D'238'
MOVWF D1
LOOP1 DECFSZ D1,1
GOTO LOOP1
DECFSZ D2,1
GOTO LOOP1
RETURN
DELAY2 MOVLW D'13' ;DELAY 10ms
MOVWF D4
MOVLW D'251'
MOVWF D3
LOOP2 DECFSZ D3,1
GOTO LOOP2
DECFSZ D4,1
GOTO LOOP2
RETURN
DELAY3 MOVLW D'1' ;DELAY 100us
MOVWF D6
MOVLW D'31'
MOVWF D5
LOOP3 DECFSZ D5,1
GOTO LOOP3
DECFSZ D6,1
GOTO LOOP3
RETURN
END
seems the coding I typed in is hard to see, I've been attached.
smileguitar is offline   Reply With Quote
Old 18th December 2007, 02:33 PM   (permalink)
I've simulated the LCD coding by simulation software, but it cannot apply to my LCD circuit. I've check my connection, there is no problem as well. Also, I tried with the LED blinking, it can work, just cannot display on the LCD. I've totally lost......
Old 18th December 2007, 03:08 PM   (permalink)
Tried running your code on my simulator, it looks as though the LCD controller is the Hitachi HD44780.
All I get on the LCD is '23' on the second line.
Where are the RS and R/W lines connected?
I dont see any reference to these control lines in your program.
Also you have enclosed your web link in 'brackets' I cannot call it!.
EDIT:
Managed to get the gif, see that RS is on RD2 and R/W is low.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 18th December 2007, 03:19 PM   (permalink)
Your program output on the simulator.
Do you have square pixel blocks on the LCD when you adjust the Contrast pot?
Eric
PIC tutorials:
Old 18th December 2007, 03:44 PM   (permalink)
First, I feel very grateful about ur help.... THANKS
Yes, I set the RS line on RD2 and I connect the R/W to ground.
erm....what do you mean by square pixel blocks?
Old 18th December 2007, 04:14 PM   (permalink)
The contrast pot to VEE, when adjusted to a given value should cause the LCD to display black squares at the positions where the characters should normally appear.
If you cannot adjust the contrast pot to show these blocks, then check the wiring to the LCD [ the power +5V and 0V and the VEE contrast, also check the voltages on these pins]
Eric
PIC tutorials:
Old 18th December 2007, 04:27 PM   (permalink)
Yes, I've double check each connection pin of LCD, and the contrast pot. I'm using 4.7kohm variable resister. But I've no idea why the LCD still cannot display any character even a cursor. At first, I set the variable resister around 4.2kohm, so I think it was high ohm to cause the problem. I reseted it lower, LCD still doesn't work as what have been expected.
Old 18th December 2007, 05:05 PM   (permalink)
Try the attached modified program, the changes are marked with '++++'
Eric
PIC tutorials:
Old 19th December 2007, 03:31 AM   (permalink)
Hi, I have simulated the modified program, there is error occurred on my simulator software. Is there ok if I test it in LCD circuit directly?
Actually I'm wondering why my program cannot apply to the LCD, while it is correct. The connection pins also connect to proper way. Is that my program doesn't suit to the circuit?
The LCD schematic diagram is attached:
Old 19th December 2007, 08:32 AM   (permalink)
I will rewire my test board to suit your PIC pinouts to the LCD, then load your program into a 16F877 and give it a run.
Do you have a datasheet for the LCD module, just in case there are any differences between the Hitachi and your LCD controller.?
To be sure your PIC setup is OK, write a simple LED ON/OFF program, this will check that your PIC16F877 is actually working.
Eric
PIC tutorials:
Old 19th December 2007, 10:18 AM   (permalink)
Downloaded the datasheet, they are the same.
Modified my project board to suit your wiring.
Programmed a PIC 16F877 with your program.
The Delays are too short, as you are not testing Dbit7 for BUSY, the LCD controller is not initialising correctly.
As a quick check increased your program delays by a factor of 3 [ called the delays 3 times each].
The LCD works OK.
Displays my test data:
Yes
Hello
With no problems.
Did you manage to see any pixel blocks while adjusting the contrast pot, its MOST important that the blocks can be made visible!!
EDITED: added a simple LCD asm program, it should display on LCD line no1:
"Line1"
Its the compiled output asm from the Oshonsoft Basic compiler.
Its been loaded into a PIC16F877 and it works, so if you cannot get a display, the problem is most likely your hardware.
Eric
PIC tutorials:
Old 22nd December 2007, 03:27 PM   (permalink)
The LCD works OK.
Yes
Hello
With no problems.
"Line1"
Hi, sorry for late reply.
what do you mean by Dbit7 for busy?
I was using 4.7kohm variable resister to adjust the contrast pot. when I was adjusting, there is nothing come out from LCD. The LCD only on the light.
Today, I tested the LCD hardware with your edidted program. But failed. At first, some pixel blocks came out, but gone after few minutes, LCD light still on....Is that my LCD or connection problem?I was connect the Vee to ground, could I connect by this way? Is it correct?
I'll attach the LCD datasheet that I'm using, and could you explain why my delay time and initialising of LCD is not correct since I follow the datasheet. I'm sorry, my knowledge about PIC microcontroller is limited. Hopefully I can gain some knowledge from you. Thanks!
Old 22nd December 2007, 03:54 PM   (permalink)
You don't need the PIC to test if your LCD module is ok.
After removing the PIC from its socket and giving power to the LCD, you should see a row of black rectangular boxes, as already pointed out. If the LCD passes this test, you can use it in your circuit and write the firmware.
Perhaps the backlight is causing troubles? In the schematic you posted I don't see a current limiting resistor between pin 15 and Vdd of the LCD module and it might be drawing too much current and behaving unpredictably? Just an idea though... since you say that you've double-checked the wiring and I trust Eric as far as the program is concernerd
Happy Holidays
eng1 is offline   Reply With Quote
Old 22nd December 2007, 04:03 PM   (permalink)
Happy Holidays
erm.... What do you mean by the backlight is causing troubles?
So, I've to connect a resister between pin 15? What about the value of resister? Is between 1kohm to 10kohm?
Thanks for your suggestion!
Old 22nd December 2007, 04:18 PM   (permalink)
The value depends on the LEDs' current, that is usually specified in the datasheet of the LCD module. If you're assembling this circuit on a breadboard, just leave pins 15 and 16 of the LCD floating (no backlight) and see what happens.
LCD 2x16 Demo for the Unicorn (18F4550) blueroomelectronics Micro Controllers 20 11th April 2008 08:08 PM
PIC16F88, PIC simulator lcd trouble superbrew Micro Controllers 11 17th October 2007 02:17 AM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 09:19 AM
Newbie needs help with LCD backlight dimming Mongoose General Electronics Chat 6 21st September 2007 11:23 PM
LCD Troubles Kyle-s4h Micro Controllers 13 11th September 2007 12:30 PM
