I would like to have a TIMER0 interrupt fire "around" 300 times a second. Here is my working out, please point out any misunderstandings 1. The uC is running at 8Mhz so FOSC/4 = 2MIPS 2. The TIMER0 interrupt will fire at 8 bit rollover (FF->00) or 16 bit rollover (FFFF->0000), depending on a clear\set of the relevant bit. 3. An increment of TIMER0 will take 1 instruction (or tick?), so 256 (or 65536) ticks later the interrupt will fire. 4. If my uC is running at 2MIPS the interrupt (without prescaling) would fire7,812 times a second (8 bit) or 30 times (16bit). If the above is correct I guess I would need to muck around with TIMER0's prescaler. Here goes:- Prescale set @ 1:2 TIMER0 interrupt will fire 3,906 times (8bit) or 15 times (16bit) a second. Prescale set @ 1:4 TIMER0 interrupt will fire 1,953 times (8bit) or 7 times (16bit) a second. Prescale set @ 1:8 TIMER0 interrupt will fire 976 times (8bit) or 3 times (16bit) a second. Prescale set @ 1:16 TIMER0 interrupt will fire 488 times (8bit) or Once (16bit) Prescale set @ 1:32 TIMER0 interrupt will fire 244 times a second (8bit) or every second (16bit) Prescale set @ 1:64 TIMER0 interrupt will fire 122 times a second (8bit) or once every 2 seconds (16bit) Prescale set @ 1:128 TIMER0 interrupt will fire 61 times a second (8bit) or once every 4 seconds (16bit) Prescale set @ 1:256 TIMER0 interrupt will fire 30 times a second (8bit) or once ever 8 seconds (16bit) These are very rough calculations as I don't know how to include the remainder element of prescaling. So looking back at my original requirement if I wanted to have the TIMER0 interrupt to fire 300 times, a prescaling value of 1:16 (488) comes closest to what I want? Is their a better way of doing this? Mark | |
your calc seems great, wanna something easier? grab PicMultiCalc, and use the Timer Helper. This will list you the best match for your requirement. this include Preload, Prescaller, the calculated value and error% for 8 and 16 bits timer. http://www.mister-e.org/pages/utilitiespag.html HTH
__________________ Steve | |
What processor are you using? What are you trying to do? Mike. | |
Thanks "Mister e" I'll have a look. Pommie - The uC is a 18F1320, the application is really to charlieplex 6 LEDs (yep I have a JuneBug). I suppose I could go for any setting that gives me something greater than 300 but I don't necessarily want to be stealing cycles from the main program. This is just an exercise really, I have no "real" application. | |
Mister e, You utility does the job very nicely, can you confirm my usage:- OSC = 8Mhz Reload = 7 (default) Interrupt\Frequency = 300hz Just a couple of questions as well I'm afraid 1. What is reload? 2. What is preload? Thanks for your help! Mark | |
| | #6 |
Reload : some call it fudge factor... it's the amount of clock cycle needed to reload the timer. If you don't know, use the default and compare your results. It's a kind of fine tuning. Preload : value to place in TMRxX register to ensure the correct timing by reducing the timer rollover. Let's say we use the defaults, and we use a 16Bit timer, Calc says: Preload=58876 => E5FC hex Prescaler= 1:1 This mean you need to 1) set the Timer prescaller to 1:1 2) Load TMRxH with E5 hex 3) Load TMRxL with FC hex Bad explanations i know... language barrier here... which programming language are you going to use?
__________________ Steve Last edited by mister_e; 14th December 2007 at 07:08 PM. | |
| | #7 |
Ahh, thanks Master E, your english is fine! I am using ASM. So at the end of my interrupt service before I set the relevant flag to set the timer going again I plug in values E5FC to TMR0H and TMR0L? Thanks | |
| | #8 |
try this one Code: LIST p=18F1320
include "P18F1320.inc"
CONFIG OSC = HS, FSCM = OFF, IESO = OFF, PWRT = OFF, BOR = OFF, WDT = OFF, LVP = OFF, WRTC = OFF
; Software constants
PreLoad = .58875 ; use to Preload Timer1 to generate 300Hz
; Software Vectors
org 0 ; Main Program
bra Init;
org 0X8 ; HiPri. INTs
TimerINT
; Timer1 ISR
; Here we will just toggle a LED
; at each INT events
; producing 150Hz frequency
BTG LATB,0 ; Toggle LED on PORTB,0
BCF T0CON, TMR0ON ; stop TIMER0 -- 1
MOVLW LOW(PreLoad) ; load lowbyte - 1
MOVWF TMR0L ; -------------- 1
MOVLW HIGH(PreLoad) ; load HighByte -1
MOVWF TMR0H ; -------------- 1
BSF T0CON, TMR0ON ; start TIMER0 - 1
; Reload = --- 6
BCF INTCON, TMR0IF ; clear INT flag
RETFIE FAST ; getout of here
; Main Program
Init ;
; Configure PIC registers
CLRF TRISB ; PORTB = output
CLRF LATB ; clear all PORTB I/Os
MOVLW 0XFF ;
MOVWF ADCON1 ; Disable ALL ADCs
BSF RCON,IPEN ; Enable priority levels on interrupts
MOVLW b'00100000' ; Enable
MOVWF INTCON ; TIMER0 int
BSF INTCON2,TMR0IP ; Set TMR0 to High priority
MOVLW b'00001000' ;
MOVWF T0CON ; Set TMR0 to
; off
; 16 bit
; clock source = internal
; no prescaller... 1:1
MOVLW LOW(PreLoad) ; Load Preload
MOVWF TMR0L ; value
MOVLW HIGH(PreLoad) ; into
MOVWF TMR0H ; TMR0
BSF INTCON, GIEH ; Enable Hi-Pri interupts
BSF T0CON, TMR0ON ; Start TIMER0
; Main loop
Main ;
; nothing fancy, just
; toggle another LED on PORTB,1
BTG LATB,1 ; Toggle LED on PORTB,1
bra Main ; do it again
end
HTH
__________________ Steve Last edited by mister_e; 14th December 2007 at 09:38 PM. | |
| | #9 |
Many thanks, I will take a look.
| timer0 |
| Timer0 Prescale | lord loh. | Micro Controllers | 10 | 8th October 2008 06:14 PM |
| Driving a servo motor- Timer0 | Wingmax | Robotics Chat | 14 | 26th November 2007 12:24 PM |
| 16F877 Timer0 Interrupt Affecting ADC | sebana | Micro Controllers | 13 | 12th September 2007 10:43 AM |
| Using the Timer0 module | wonbinbk | Micro Controllers | 2 | 14th September 2004 07:06 AM |
| Cant get timer0 to interrupt | 2camjohn | Micro Controllers | 5 | 16th June 2004 01:06 PM |
