Hi, Refering to PIC18F2620 datasheet, section 26.3 on DC characteristics, it says that the input high voltage is only 2V for VDD between 4.5V and 5.5V. BTW I am doing a project using PIC18F2620 and ENC28J60 and i was wondering, if the input high voltage is only 2V, then why would i still need additional CMOS chip to act as voltage level translator/shifter for ENC28J60's output pin SO, CLKOUT and INT. I mean, shouldn't the output voltage of 3.3V be sufficient to change the PIC pin from a LOW state to a HIGH state..? Any thoughts.. Thanks.. | |
You shouldn't have any problem if the signal is greater than the one stated in the datasheet. But why not running the whole board @3.3V?
__________________ Steve | |
| | #3 | |
__________________ Inside every little problem, is a big problem trying to get out. | ||
mister_e: I thought about that but i was afraid i might face some problems later when interface with other peripherals such as LCD display.. kchriste: Oh yeah, those pins have schmitt level inputs.. Thanks for pointing that out.. | |
| high, input, pic, voltage |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Low voltage vs high voltage programming | bananasiong | Micro Controllers | 4 | 20th July 2007 01:00 AM |
| High Voltage Indicator?? | ZIGGY_DAN | General Electronics Chat | 4 | 20th June 2006 01:13 PM |
| High voltage... | jrz126 | General Electronics Chat | 1 | 12th March 2005 10:00 PM |
| Having problems with pic16f872 | cjgalway1000 | Micro Controllers | 0 | 7th April 2004 03:39 PM |
