Hi guys I have built the Mood Loop project published in EPE issue 2000.08. Got hold of all the components with no hassle and built the unit, downloaded the .asm file from epe.com (file attached). I have tried using MPLAB but I can not get it to compile a hex file successfully. I do not have any experience in programming. Other projects that I have built the hex code was already available. I don’t think the code is in error, must be my 10 thumbs with MPLAB. This is the error : Error[122] C:\DOCUMENTS AND SETTINGS\DANIE\DESKTOP\MOOD LOOP\UNTITLED.ASM 13 : Illegal opcode (.EQU) Should I use other software ? Has anyone els tried to compile the hex code for this project, successfully? Your advice will be much appreciated. Thanks Virus | |
I think that assembly language is for an older version of MPLAB Try without the . so it should read:- ctr0 EQU 0x0C The : after the labels aren't needed and they might cause a problem. so an example label should read:- dlytbl addwf pcl,f Also, if you put in #include p16f84.asm you can get rid of all the general equates. A PIC16F627A is cheaper and better than a PIC16F84. All you need to do is change the program specific includes to start at 0x20 | |
A lot of the older EPE projects don't use MPLAB/MPASM, they use a shareware assembler configured for PIC (MASM). If you download the EPE PIC Toolkit it has options for converting the source to work with MicroChip assemblers.
There was a couple of things that would stop the file working in MPLAB. Things like assuming the radix would be decimal and having no code at location 0. Anyway, this should now compile. Mike. Code: ;Moodloop Frequency Generator
;Andy Flind 1/12/99
;For PIC16F84 or PIC16C84
;For 4.00MHz xtal
;Configuration
;Oscillator XT
;Watchdog timer NO
;Power-up timer YES
radix dec
#DEFINE page0 BCF status,5
#DEFINE page1 BSF status,5
status EQU 0x03 ;general equates
portA EQU 0x05
trisA EQU 0x05
portB EQU 0x06
trisB EQU 0x06
pcl EQU 0x02
rtcc EQU 0x01
;option EQU 0x01
intcon EQU 0x0B
f EQU 0x01
w EQU 0x00
z EQU 0x02
ctr0 EQU 0x0C ;program specific equates
ctr1 EQU 0x0D
ptr EQU 0x0E
freq EQU 0x1F
org 0x0000
goto start
org 0x0004 ;interrupt vector
; org 0x0005 ;start of program
; goto start
dlytbl addwf pcl,f
goto dly0
goto dly1
goto dly2
goto dly3
goto dly4
goto dly5
goto dly6
goto dly7
goto dly8
goto dly9
goto dly10
goto dly11
goto dly12
goto dly13
goto dly14
goto dly15
start clrf portA ;initialise for operation
clrf portB
page1
movlw b'11111111'
movwf trisA ;portA all input
clrf trisB ;portB all output
page0
clrf portA
clrf portB
comf portA,w ;get the switch pattern
andlw 15 ;check validity
movwf ptr ;put it into ptr
cycle bsf portB,0 ;output sequence step 1
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 2
nop ;2 nops compensate for
bsf portB,1 ;the "return" before step 1
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 3
nop
bsf portB,2
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 4
nop
bsf portB,3
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 5
nop
bsf portB,4
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 6
nop
bsf portB,5
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 7
nop
bsf portB,6
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 8
nop
bsf portB,7
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 9
nop
bcf portB,7
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 10
nop
bcf portB,6
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 11
nop
bcf portB,5
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 12
nop
bcf portB,4
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 13
nop
bcf portB,3
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 14
nop
bcf portB,2
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 15
nop
bcf portB,1
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
nop ;output sequence step 16
nop
bcf portB,0
comf portA,w
andlw 15
xorwf ptr,w
btfss status,z
goto start
movf ptr,w
call dlytbl
goto cycle ;and do sequence again
dly0 movlw 176 ;1st frequency
movwf ctr1
t0a movlw 117
movwf ctr0
t0 decfsz ctr0,f
goto t0
decfsz ctr1,f
goto t0a
nop
nop
nop
return ;for 1.0Hz
dly1 movlw 57 ;2nd frequency
movwf ctr1
t1a movlw 227
movwf ctr0
t1 decfsz ctr0,f
goto t1
decfsz ctr1,f
goto t1a
nop
return ;for 1.6Hz
dly2 movlw 78 ;3rd frequency
movwf ctr1
t2a movlw 120
movwf ctr0
t2 decfsz ctr0,f
goto t2
decfsz ctr1,f
goto t2a
return ;for 2.2Hz
dly3 movlw 48 ;4th frequency
movwf ctr1
t3a movlw 95
movwf ctr0
t3 decfsz ctr0,f
goto t3
decfsz ctr1,f
goto t3a
return ;for 4.5Hz
dly4 movlw 186 ;5th frequency
movwf ctr1
t4a movlw 19
movwf ctr0
t4 decfsz ctr0,f
goto t4
decfsz ctr1,f
goto t4a
nop
return ;for 5.5Hz
dly5 movlw 21 ;6th frequency
movwf ctr1
t5a movlw 151
movwf ctr0
t5 decfsz ctr0,f
goto t5
decfsz ctr1,f
goto t5a
nop
return ;for 6.5Hz
dly6 movlw 27 ;7th frequency
movwf ctr1
t6a movlw 97
movwf ctr0
t6 decfsz ctr0,f
goto t6
decfsz ctr1,f
goto t6a
return ;for 7.83Hz (schumann res.)
dly7 movlw 23 ;8th frequency
movwf ctr1
t7a movlw 89
movwf ctr0
t7 decfsz ctr0,f
goto t7
decfsz ctr1,f
goto t7a
return ;for 10.0Hz
dly8 movlw 149 ;9th frequency
movwf ctr1
t8a movlw 11
movwf ctr0
t8 decfsz ctr0,f
goto t8
decfsz ctr1,f
goto t8a
nop
return ;for 11.3Hz
dly9 movlw 33 ;10th frequency
movwf ctr1
t9a movlw 49
movwf ctr0
t9 decfsz ctr0,f
goto t9
decfsz ctr1,f
goto t9a
return ;for 12.5Hz
dly10 movlw 21 ;11th frequency
movwf ctr1
t10a movlw 48
movwf ctr0
t10 decfsz ctr0,f
goto t10
decfsz ctr1,f
goto t10a
return ;for 20.0Hz
dly11 movlw 4 ;12th frequency
movwf ctr1
t11a movlw 234
movwf ctr0
t11 decfsz ctr0,f
goto t11
decfsz ctr1,f
goto t11a
return ;for 22.0Hz
dly12 movlw 209 ;13th frequency (test)
movwf ctr1
t12a movlw 198
movwf ctr0
t12 decfsz ctr0,f
goto t12
decfsz ctr1,f
goto t12a
nop
return ;for 0.5Hz
dly13 movlw 14 ;14th frequency (test)
movwf ctr1
t13a movlw 28
movwf ctr0
t13 decfsz ctr0,f
goto t13
decfsz ctr1,f
goto t13a
nop
return ;for 50.0Hz
dly14 movlw 255 ;15th frequency (test, all high)
movwf portB
comf portA,w
andlw 15
xorwf ptr,w
btfsc status,z
goto dly14 ;repeat until switches change
return
dly15 clrf portB ;16th frequency (test, all low)
comf portA,w
andlw 15
xorwf ptr,w
btfsc status,z
goto dly15 ;repeat until switches change
return
END
Thanks for the help, Guys Pommie, the code compiled ok. Now in laymen terms, how do I get a HEX file out of this ? Should it not generate the hex file when you compile it? Thanks again Virus | |
| | #6 |
Not only should it, it does!. However, if it reports an error, the HEX file won't be created.
| | #7 |
Thanx Nigel It complied with 0 errors ? So, t is not necessary to tel MPLAB that you want a HEX file it does it automatically Virus | |
| | #8 |
Don't know?, I never use MPLAB, I just use the assemble MPASM directly.
| | #9 |
Nigel Thanx Virus Last edited by Virus; 11th December 2007 at 12:10 PM. | |
| | #10 |
Try searching your drive for 'Untitled.hex'. Although looking at that it doesn't mention a hex file?, but on MPASMWIN there's no option NOT to generate one. Try running MPASMWIN on it's own, browse to the ASM file, and click 'Assemble', see what happens. | |
| | #11 | |
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| | #12 |
Thanx Guys Got it, made the HEX file, will program the chip tonight, and give feed back. Thanx Virus | |
| | #13 |
Guys Thanx for all the help, programmed the chip, and it seems to run OK. A blessed Christmas to you all. Virus | |
| | #14 | |
| | #15 | |
| asm, hex, mplab, needed |
| PIC16F84A - ASM to HEX | Mihindu_gajaba | Micro Controllers | 3 | 22nd November 2007 05:30 PM |
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
| PIC16F877A TX data to PC via serial cable | derrick826 | Micro Controllers | 21 | 8th October 2007 02:28 PM |
| Need help badly on Inchworm and MPLAB | thushy | Micro Controllers | 14 | 11th March 2007 07:05 PM |
| 16F88 and MPLAB Help needed | GRC | Micro Controllers | 28 | 28th December 2006 01:24 AM |
