Old 22nd December 2007, 01:00 PM   (permalink)
Will do you 1 better, find attached
Thanx
Virus
Virus is offline
Old 22nd December 2007, 01:25 PM   (permalink)
Mike
What I am working to is to build a project that uses a keypad to enter frequencies into it and then generate a positive of-set square pulse. Possibly with some memory that will store a couple of frequencies sets.
Is this a difficult project ?, I am looking for a circuit diagram, or something similar that I can maybe adapt, have you come across something similar ?
Thanx
Theunis
Virus is offline
Old 22nd December 2007, 01:37 PM   (permalink)
Any one wanting to build the PIC-Gen, please make sure you get the components first, some are outdated ex.(MAX038 got the last 3 from a supplier, etc).
Virus
PS: Also1 off the 0v pins on connector TB1 in Fig.2. need to be connected to LCD pin 5 or the R/W pin. The other to PIN 1 VSS.
Virus is offline
Old 22nd December 2007, 02:24 PM   (permalink)
Originally Posted by Virus
Mike
Thanx
Theunis
This doesn't sound like something that will be readily available and I think you will have to write the code yourself. It looks like you could have a steep learning curve ahead. Have you done any other programming before?
Pommie is offline
Old 22nd December 2007, 03:16 PM   (permalink)
No programming experience at all, not even electronics, I have read a lot and have built some projects etc pic-gen most advanced for me until now, believe I will get their some time. (All though time it self might catch up with me first.)
I intend to start learning programming asap, how fast, I doubt that I will ever be able to reach that high my self. I have master Proteus and can make PCB’s from exiting schematics, can make my own films (have a image setter and processor) for making the PCB, etching an all the necessary.
Therefore the pic-gen closest to what I intend and could maybe do for now.
Back to the positive-offset on the square wave, any suggestions.
Virus
Virus is offline
Old 22nd December 2007, 03:25 PM   (permalink)
What frequency range are you wanting?, and what resolution? - presumably you are wanting simple 0-5V(ish) logic level pulse?.
Old 22nd December 2007, 05:12 PM   (permalink)
I wanted to use the pic-gen but as mentioned it generates as pos and negative value, I need to get a positive dc offset square puls, from between 0.1 Hz to ± 4Mhz. Wanted to use the pic-gen to drive a 555 or something similar that will give a positive puls, and in turn then drive a Mosfet or two that will puls a air coil at about 24vDC at 5 -10 amps.
Won’t it work to just drive the mosfets directly, because they can only be on or off. The spec on the Pic-gen says it can give +5v, is that enough to drive the mosfets full out.
Thanx
Virus
Virus is offline
Old 22nd December 2007, 05:33 PM   (permalink)
I don't see why you would need a 555?, and why would you need anything like 4MHz?.
Old 23rd December 2007, 10:38 AM   (permalink)
What do I need to change it to have a positive offset ?
Virus
Virus is offline
Old 26th December 2007, 04:30 PM   (permalink)
I found this circuit, can I use the square wave output from the Pic-Gen to drive this circuit.
I only have IRF540’s can I use them instead of the HUF75337P9 mosfets.
Virus
Virus is offline
PIC16F84A - ASM to HEX Mihindu_gajaba Micro Controllers 3 22nd November 2007 05:30 PM
Question about Inchworm+ Quan Micro Controllers 54 28th October 2007 01:21 AM
PIC16F877A TX data to PC via serial cable derrick826 Micro Controllers 21 8th October 2007 02:28 PM
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 07:05 PM
16F88 and MPLAB Help needed GRC Micro Controllers 28 28th December 2006 01:24 AM
