| | LinkBack (1) | Thread Tools | Display Modes |
| I used a trick to get the serial working. I only check the serial if the count has bit 2 set. This gives a worst case scenario between serial checks of 3*4*8 = 96 cycles where each servo is 3 periods apart. Here's the ISR code for the 8 cycle routine. It's not well commented but you should be able to follow it. Note, this hasn't even been assembled and definitely not tested! Code: movlw ServoBuffer movwf FSR movlw 0xff movwf PORTA ;0 set all on. Wait btfsc INDF,2 ;1/2 it set then we have 32 cycles to read serial and test for exit goto DoSerial ;3 exit on 3 incf FSR,F ;3 movfw INDF ;4 prefetch port value decf FSR,F ;5 Enter decfsz INDF,F ;6/7 goto Wait ;8 movwf PORTA ;8 movlw 3 ;0 addwf FSR,F ;1 point to next port value movfw INDF ;2 prefetch incase time = 1 decf FSR,F ;3 back to time count goto Enter ;5 DoSerial movfw FSR ;4 save the pointer movwf FSRtemp ;5 decf FSR,F ;6 point to last port value movfw INDF ;7 get it btfsc STATUS,Z ;8/9 if it was zero, were done goto Done ; exit on 10 btfss PIR1,RCIF ;10/11 goto NoSerial ; exit on 12 incf FifoStart,W ;14 get fifostart + 1 andlw FifoLength-1 ;15 make it circular movwf FifoStart ;16 addlw FifoBuffer ;17 add start of buffer movwf FSR ;18 put in indirect pointer movfw RCREG ;19 get the received byte movwf INDF ;20 put it in fifo movfw FSRtemp ;21 restore the pointer movwf FSR ;22 decf INDF,F ;23 - 8 = 15 reclaim 8 cycles decf INDF,F ;15 - 8 = 7 and again decf INDF,F ;7 - 8 = 2 and again nop ;3 goto Enter ;5 NoSerial movfw FSRtemp ;11 restore pointer movwf FSR ;12 decf INDF,F ;13 - 8 = 5 reclaim 8 cycles goto $+1 ;7 goto $+1 ;9 decf INDF,F ;9 - 8 = 1 and again goto $+1 ;3 goto Enter ;5 Merry Christmas. Edit, it also doesn't have the initial delay etc. Last edited by Pommie; 16th December 2007 at 12:20 PM. | |
| So then, that must be the 8 MHz code with 4 usec 'step' size. Oh boy, I'm looking forward to studying it. At first glance it seems we're trying similar methods using counters... That 16 MHz 1 usec 'step' code I was contemplating was an "unrolled" loop but I forgot about caching serial data. Oh well... Code: T1 movf Val_01,W ;
decfsz Tmr_01,F ;
goto T1 ;
xorwf PORTB,F ;
T2 movf Val_02,W ;
decfsz Tmr_02,F ;
goto T2 ;
xorwf PORTB,F ;
T3 movf Val_03,W ;
decfsz Tmr_03,F ;
goto T3 ;
xorwf PORTB,F ;
T4 movf Val_04,W ;
decfsz Tmr_04,F ;
goto T4 ;
xorwf PORTB,F ; Last edited by Mike, K8LH; 16th December 2007 at 05:43 PM. | |
| Since Mike K8LH has helped me think a little differently in my approach to code problems by judiciously using the abundance of PIC18 RAM to great advantage in developing his hirez servo positions, I think it's time to push the envelope with ROM when it comes to PIC16. Also note that controlling 33 servos from a PIC16 might only be possible from something like the new 16F887 running with its internal oscillator, which maxes at 8 MHz. Here's my conceptual approach without having done any work yet on the problem, and it may provide some fodder for good minds. I once considered puttting a RETURN instruction at the last address of ROM and then calling various ROM addresses a given number of addresses before the RETURN instruction to create virtual delays, that is, delays that did not require any code or code loops. This is because when a PIC's ROM is cleared it becomes a nice series of NOP's, or single cycle instructions. This should work as long as you know how much ROM is left at the end of your MCU. Imagine putting a RETURN instruction at the last address of the '887, or least at a known address. Since the servo period of 0 to 2500us is essentially a delay, it should be possible to make a Call to an address the number of addresses before the RETURN to create the necessary time delay. A PIC16 will only allow 8 Calls since this is the maximum of the Stack. But over 20ms all 33 servos might get handled. What do you think? Last edited by wschroeder; 17th December 2007 at 03:41 AM. | |
| That's certainly a good concept for a delay routine but I'm not sure how you'd use it for a 16F' servo controller where we're really trying to do a lot in just a few cycles (over and over again). Regards, Happy Holidays, Mike | |
| How about a Servo-64 solution using a 28 pin 18F2620 and eight 74HC238 decoder IC's? It's an off-shoot from the 2.5 Kb buffer K8LH Soft-32 controller 'method'. It just won't support digital "on/off" outputs but I'm brain-storming a way to fix that using a latch or flip-flop IC instead of the decoder IC. Happy Holidays everyone... | |
| Hi Mike, Yes, you're probably right... it was an idea that popped into my head.... not necessarily a good one. Last edited by wschroeder; 18th December 2007 at 04:32 PM. | |
| I have not been treated more badly by any other forum administrator/moderator than this one...whoever it is doing this. In fact, I have never been banned from any forum, save this one. Passing notes publicly in the signature of my postings is possibly the worst form of decorum for someone in charge. I have email. | |
| OK, quite simple answer - I responded in the same way you did - you made your point, I made mine in exactly the same way. If you had contacted me privately then I'd have responded privately. I'll repeat again for you - if you want to advertise your commercial site please contact the administrator about advertising rates!. | |
| Nigel, I must say I'm shocked to think that someone could possibly try and rationalize attaching those messages to someone elses posts. That must be the tackiest thing I've witnessed here. May I ask if there's an authority, other than you, with whom I could lodge a complaint? Sincerely, Michael McLaren, K8LH | |
| I also think that Warren's treatment is a little harsh. Considering he has only 55 posts, his contributions are very informative. Mike. | |
| Is there a nice simple circuit for the 18f4550 that I can use with schroeders code? This is perfect as I need to drive 20 servos...... any suggestions would be great... thanks. | |
| Dear wschroeder, You wrote an awesome code for 18F452.I am thinking of making a servo controller for my project.Could you please post the circuit diagram and the control protocol for controlling the servos from th serial port.I have experience in programming AVR but I am totally new to PIC. Hoping for a positive reply. | |
| ok, I don't get it... why aren't you just using a counter, interrupt driven serial routine (three byte min block - table addy, byte count, data ), and an endless loop? | |
| No, just a very quick scan of the posts. With and interrupt routine repsonding UART to update the desired PWM values, a simple endless loop looks up the value and compares it to a time counter to reset it's pin and they all get set on the overflow interrupt. It stalls briefly on serial reception, but that is easier to deal with than having to make time for 30 bytes regularly... | |
| LinkBack to this Thread: http://www.electro-tech-online.com/micro-controllers/34390-drive-33-servos-one-pic-usart.html | ||||
| Posted By | For | Type | Date | |
| PIC Servo Driver Tutorials? - RC Groups | This thread | Refback | 16th May 2008 11:43 PM | |
| Problems switchin relay with PIC | Andy1845c | General Electronics Chat | 5 | 17th November 2007 07:14 PM |
| RF receive using PIC USART | col_implant | Electronic Projects Design/Ideas/Reviews | 11 | 15th November 2007 05:06 PM |
| High ADC sampling rate PIC, 18F needed? | bananasiong | Micro Controllers | 24 | 28th October 2007 01:13 PM |
| Controlling servos with PIC16F84A | Ostekjeks | Robotics Chat | 3 | 25th February 2005 11:06 AM |
| electric car drive | franklin2 | Electronic Projects Design/Ideas/Reviews | 8 | 18th October 2004 03:30 PM |
