| Hi to all I m facing problem of dumping the code in PIC18F452 i m using software winpic800 when i load the hex file in the code area and want to dump the software gives me error at start as in picture PLz help to solve the problem Thanks | |
| That means the PIC hasn't been programmed at all, 0xFFFF is what a completely blank device reads, or no PIC connected to the programmer. The most common reason is too little voltage to switch the PIC to programming mode - but you don't mention what programmer you're using?. | |
| Hi Goodwin Thanks for reply i m using the pic programmer on website(www.coolcircuit.com) and the program code is of 2.09KB the program is on website microchip.com with application note number AN843 plz help to solve problem Thanks | |
| That looks a fairly standard David Tait type clone, what are you using for the power supply?, the circuit doesn't seem to mention it?. | |
| I m using universal voltage dc adapter gives voltage up to 18v i think the problem is due to software because when i enter the code and disconnect my programmer and by pressing programall button the same error appears and when code is not entered and by pressing programall button no error appears thanks | |
| Is your supply regulated or unregulated?, an unregulated supply may (and often does) have too much ripple on it to work. You think wrong, those actions are exactly what I would expect. | |
| Greetings. A pic controlled traffic light circuit... | Wiley | Electronic Projects Design/Ideas/Reviews | 2 | 13th October 2007 05:46 PM |
| PIC to LCD wiring problem ? | pasanlaksiri | Micro Controllers | 28 | 4th October 2007 11:29 AM |
| JDM programmer problem | krvavizmaj | Micro Controllers | 3 | 2nd October 2007 09:36 AM |
| Four PIC with One LCD.. | meera83 | Micro Controllers | 13 | 20th September 2007 07:40 AM |
| URGENT!! 16F877 & USART & Interrupt & Recieve Problem | DaMieN | Micro Controllers | 0 | 18th September 2007 11:53 AM |
