Old 2nd December 2007, 07:32 PM   (permalink)
Experienced Member
blueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to beholdblueroomelectronics is a splendid one to behold
Send a message via Skype™ to blueroomelectronics
Default LCD 2x16 Demo for the Unicorn (18F4550)
Here's working code that was designed for the Unicorn in LCD mode (it also works with Oshonsofts 18F & LCD simulator) It will be part of the Unicorn assembly manual.
PS anyone have any decent asm formatters for posting?
    list    p=18F4550
    include <p18F4550.inc>
        CONFIG  FOSC = INTOSC_HS, WDT = OFF, LVP = OFF, PBADEN = OFF
#define LCD_E   LATE,2
#define LCD_RS  LATE,0
#define LCD_RW  LATE,1
#define LCD_BL  LATB,3
delay    equ    0
temp    equ    1
        org     0x000
        movlw    HIGH LCD_CC    ; high byte
        movwf    TBLPTRH         ; pointer to table high order byte
        setf    ADCON1        ; all I/O digital
        bcf    TRISB, 3    ; LCD backlight control
        clrf    TRISD           ; LCD data output
        clrf    PORTE           ; LCD control
        clrf    TRISE
        clrf    LATE            ; zero output on E
        movlw   0x02        ; use internal osc
        movwf   OSCCON          ; 31.25KHz internal clock
; LCD soft reset (ignores/enables busy flag polling)
        movlw   .3              ; repeat sending 0x38 to reset LCD
        movwf    temp            ; loop counter
_init3  movlw   .131         ; 50ms delay
        movwf   delay           ; enter with delay in ms via W
        decfsz  delay
        bra     $-2
        bsf     LCD_E           ; LCD enable bit high
        movlw   0x38            ; send 0x38 four times
        movwf   LATD            ; LCD = 0x38 (8 bit mode x 2 line)
        bcf     LCD_E           ; latches on High to Low transition
        decfsz  temp
        bra     _init3          ; repeat 3 times
        bsf     LCD_BL          ; turn on backlight
; load special charaters into LCD RAM using LCD busy flag
        movlw   b'01000000'     ; set LCD CG address to 00
        rcall   LCD_Ins         ; relative call
        clrf    temp
        movlw   LOW LCD_CC    ; pointer to custom charater table
        movwf   TBLPTRL
_nextcc tblrd*+                 ; get in-line string character
        movf    TABLAT,W        ; last character
        rcall   LCD_Chr         ; send the character into LCD RAM
        incf    temp
        btfss   temp, 6         ; 64 bytes total
        bra     _nextcc
; clear & enable LCD DRAM, no visible cursor
        movlw   0x0C            ; display on, cursor off
        rcall   LCD_Ins
; display top 16 characters
        movlw   0x01            ; clear display, home cursor
        rcall   LCD_Ins
        movlw   .16
        movwf   temp
        movlw   LOW Text_    ; low byte pointer
        movwf   TBLPTRL        ; point to first line of text
_top    tblrd*+                 ; get in-line string character
        rcall   LCD_Chr
        decfsz  temp
        bra     _top
; display bottom 16 characters
    movlw   0xC0        ; set cursor to second line
        rcall   LCD_Ins
        movlw   .16
        movwf   temp
_bot    tblrd*+                 ; get in-line string character
        rcall   LCD_Chr
        decfsz  temp
        bra     _bot
        bra    $        ; endless loop done
; LCD entry routines watches busy flag
LCD_Chr bsf     LCD_RS          ; enable Charater mode
LCD_Ins bsf     LCD_E
        clrf    TRISD           ; make PORTD an output
        movwf   LATD        ; put data on LCD port
        bcf     LCD_E           ; latch byte to LCD
        bcf     LCD_RS
        setf       TRISD           ; make LCD port input
        bsf     LCD_RW          ; enter read mode
        bsf     LCD_E           ; enable LCD
_BusyFl btfsc   PORTD,7         ; wait for bit 7 to be pulled low
        bra     _BusyFl
        bcf     LCD_RW          ; return to Instruction mode
        return
; text to display
        org    0x0800
Text_   db      "blueroom      ",.0,.1
        db      "electronics   ",.2,.3
; *** 2x2 blueroomelectronics logo (house)
LCD_CC  db      .128,.128,.129,.131,.135,.143,.159,.159
        db      .128,.128,.128,.144,.152,.156,.158,.130
        db      .159,.159,.159,.145,.145,.145,.159,.128
        db      .130,.130,.158,.130,.130,.130,.158,.128
    END
Bill
Smart Kits build Smart People
Old 2nd December 2007, 08:28 PM   (permalink)
Experienced Member
Mike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to allMike, K8LH is a name known to all
Do you still have Just BASIC installed on your system? If so, I'll send you a "formatter" program I wrote that inputs an ASM file or a C file and outputs it to a console window with space characters in place of the tab characters. Just select and copy text from the console window and paste it between code tags in your posts.
Here's "before" and "after" examples;
;*  ScanPad, 4x4 Keypad              Mike McLaren, K8LH, Nov'07  *
;*      RB3 RB2 RB1 RB0         <> requires PORTB weak pull-ups      *
;*  RB4 [0] [1] [2] [3]         <> returns Z=0 for a "new" key only  *
;*  RB5 [4] [5] [6] [7]         <> returns Z=1 when no keys pressed  *
;*  RB6 [8] [9] [A] [b]         or if same key is still pressed   *
;*  RB7 [C] [D] [E] [F]         <> isochronous (77 cycles)          *
;*  the Keylat key state latch contains pressed key value 80..8F  *
;*  or 0 (no key pressed).  clear Keylat after getting a new key  *
;*  from ScanPad for "repeat key" operation (see example).      *
;*  26 words, 77 instruction cycles (isochronous)          *
ScanPad
    movlw    TRISB        ; address of TRISB in bank 1      |B0
    movwf    FSR        ; setup indirect access          |B0
    movlw    b'11110111'    ; setup column 0 (RB3) as output  |B0
    movwf    INDF        ; pseudo "movwf TRISB"          |B0
    clrf    Column        ; set keypad column offset = 0      |B0
    movlw    0        ; clear W              |B0
    setc            ; must shift 1 bits into TRISB      |B0
ScanPad
Mike, K8LH is online now   Reply With Quote
Old 2nd December 2007, 08:51 PM   (permalink)
Experienced Member
Here's the "Forum Code-Tag-Fix" program that I mentioned in the previous post for those who may be interested. It's written in Just BASIC, a free BASIC interpreter...
'  Forum Code-Tag-Fix v1.1 by Mike McLaren, K8LH
'  replaces <tab> characters with spaces (tabs = 8).  adds
'  an additional space character to lines beginning with a
'  space for Microchip Forum.  does not alter source file.
'  Instructions
'  1 - select your source file from the File Dialog
'  2 - select output text displayed in console window
'  3 - copy to clipboard using <ctrl-C> or <edit> <copy>
'  4 - paste between code tags in your Forum post
'  JustBASIC v1.01
   tabs = 8       ' 8 (assembly) or 4 (C)
   postmode = 0   ' 1, replace tabs, add leading space
                  ' 0, replace tabs only
   filedialog "Source File?", "*.asm", fileName$
   if fileName$ <> "" then
     open fileName$ for input as #f
     while eof(#f) > -1
       line input #f, aLine$ : hpos=1
       if postmode then
         if (left$(aLine$,1)=" ") then print " ";
         if (left$(aLine$,1)=chr$(9)) then print " ";
       end if
       for x = 1 to len(aLine$)
         if (mid$(aLine$,x,1)<>chr$(9)) then
           print mid$(aLine$,x,1); : hpos=hpos+1
         else
           while hpos MOD tabs <> 0
             print " "; : hpos=hpos+1
           wend
         end if
       next x
       print
     wend
     close #f
   end if
   end
Old 2nd December 2007, 09:19 PM   (permalink)
Experienced Member
futz is a name known to allfutz is a name known to allfutz is a name known to allfutz is a name known to allfutz is a name known to allfutz is a name known to all
Hey Bill. I wanna buy a second Unicorn (and some other stuff). How's Creatron's online order site coming along?
futz is offline   Reply With Quote
Old 2nd December 2007, 10:47 PM   (permalink)
Experienced Member
Thanks Mike, I still have JustBASIC.
I think I'll just open an ebay store.
Bill
Old 3rd December 2007, 01:02 AM   (permalink)
Experienced Member
Leftyretro has a spectacular aura about
Now your talkin', time to join the 21 century
Lefty
Measurement changes behavior
Leftyretro is offline   Reply With Quote
Old 3rd December 2007, 07:13 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Edit, I tried to upload a code tidier but I couldn't get the setup to work. Will try again later.
Pommie is offline   Reply With Quote
Old 19th February 2008, 10:00 AM   (permalink)
ThiSel is on a distinguished road
Send a message via ICQ to ThiSel Send a message via MSN to ThiSel Send a message via Yahoo to ThiSel
Hi Bill,
I have a unicorn kit with me which I use with the inchworm+. Both the kits are working fine together.
I got myself an LCD recently and wanted to interface with the unicorn kit.
I compiled the asm from this thread and tested the LCD. Only the backlight comes on and nothing got displayed on the LCD.
The LCD spec is here; http://www.hantronix.com/down/char-comm.pdf
How should I go about tracing the problem?
Thanks!
Regards,
Thiruselvam
ThiSel
Codito Ergo Sum
ThiSel is offline   Reply With Quote
Old 19th February 2008, 10:27 AM   (permalink)
Experienced Member
If it helps, here are pictures showing how mine is connected.
Edit, that data sheet hasn't got the pinout. I do have one display where the connector is at the bottom. It might be wise to use a battery and resistor to find the backlight.
Old 19th February 2008, 02:05 PM   (permalink)
Experienced Member
If you get the backlight that's a good start, make sure it's in the right way around as the + & gnd pins are mirrored so an upsidedown LCD will still light the backlight. Pin 1 on the LCD should have a #1 near.
Also you need the small jumper installed (J1) for your LCD, a GLCD you take off the jumper. Lastly try to adjust the contrast so you see a row of dark squares on the first display row.
Bill
Old 19th February 2008, 03:14 PM   (permalink)
Hi Mike, pommie,
The pinout is here: http://www.hantronix.com/down/20416ls.pdf
It's supposed to be compatible with the Hitachi HD44780.
Thanks!
ThiSel
Codito Ergo Sum
Old 19th February 2008, 03:22 PM   (permalink)
Experienced Member
That pinout is the same as mine and so you should place it the same. Have you checked the jumper as mentioned by Bill.
Old 19th February 2008, 04:14 PM   (permalink)
Experienced Member
That's a standard 20x4 LCD, you should adjust contrast till you see some dark squares on lines 1&2. You do need the jumper on J1.
Bill
Old 20th February 2008, 12:20 PM   (permalink)
I got it working!
I think it was because of the jumper and the contrast pot. Pot has to be fully turned clockwise.
Thanks guys!
ThiSel
Codito Ergo Sum
Old 4th April 2008, 11:28 AM   (permalink)
Experienced Member
petrv will become famous soon enough
Works also for me What I did after that: Replaced the PIC in Unicorn with 16F887 and modified the code to make it work again. (Configuration Junebug + Unicorn with PIC16F887 running on the 20MHz crystal). I can post the source if someone is interested.
What was tricky is the fact that when reading from the program memory on PIC16F887 it is necessary to insert 2 NOPs after setting the RD bit in EECON1 otherwise it does not work mysteriously but when debugging (single-stepping through the code) it does work correctly ...
Petr
petrv is offline   Reply With Quote
HD44780 lcd help jay543_uk Micro Controllers 12 8th November 2007 03:26 PM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 09:19 AM
LCD Troubles Kyle-s4h Micro Controllers 13 11th September 2007 12:30 PM
