Old 1st December 2007, 02:21 PM   (permalink)
Question 60 Hz PWM for RC Servo using postscaler?
I would really like to use the 16F628A hardware PWM to run an RC servo at 60 Hz. My program is busy getting input and can’t be interrupted 60 times per second to send output. I could use a second PIC for output but would rather not. This note is in the Mid-Range MCU Family Reference Manual.
Note: The Timer2 postscaler is not used in the determination of the PWM frequency. The postscaler could be used to have a servo update rate at a different frequency than the PWM output.
Googling found a lot of complaints quoting that note and saying that the postscaler has no effect.
I am still looking but has anyone had success with this or is it misinformation?
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline
Old 1st December 2007, 03:19 PM   (permalink)
The Timer 2 postscaler is not used for determining the period when running the CCP module in PWM mode.
One method for overcoming low frequency period limitations is to break up the PWM period into smaller/faster PWM "frames" and use a small bit of interrupt code to set the duty cycle for each "frame". The algorithm and code are relatively simple, have reasonably low processor overhead, and can be used to generate a 0% to 100% duty cycle output on the CCP1 pin for very long periods;
;  //  setup 250-usec PWM frames using PR2 = 249 and prescaler
;  //  1 (4 MHz) or 4 (16 MHz) for 1 usec pulse width resolution
;  int servo = 1500;            // duty cycle in 1 usec ticks
;  int pulse = 0;               // ISR work variable
;  int frame = 1;               // frame number, 0..80
;  void ISR()
;  { PIR1bits.TMR2IF = 0;       // clear Timer 2 interrupt flag
;    if (--frame == 0)          // if end of 20 msec period
;    { frame = 80;              // 80 frames = 20 msec period
;      pulse = servo;           // setup work variable
;    if(pulse > 250)            // if pulse > 250-usecs
;    { CCPR1L = 250;            // do a 100% duty cycle frame
;      pulse -= 250;            // subtract 250-usecs
;    else                       // do a variable or 0% frame
;    { CCPR1L = (pulse);        // 0..250
;      pulse = 0;               // remaining frames are %0
isrproc
;  save main program context
        movwf   W_ISR           ; save W-reg                      |B?
        swapf   STATUS,W        ; doesn't change STATUS bits      |B?
        movwf   S_ISR           ; save STATUS reg                 |B?
        clrf    STATUS          ; force bank 0                    |B0
        bcf     PIR1,TMR2IF     ; clear Timer 2 interrupt flag    |B0
;  check for start of new 20 msec servo period
        decfsz  frame,F         ; end of 20 msec period?          |B0
        goto    doframe         ; no, branch, else                |B0
        movlw   d'80'           ; reset pwm frame number          |B0
        movwf   frame           ;                                 |B0
        movf    servo,W         ; setup 'pulse' work variable     |B0
        movwf   pulse           ; for new 20 msec servo period    |B0
        movf    servo+1,W       ;                                 |B0
        movwf   pulse+1         ;                                 |B0
;  setup CCP1 PWM duty cycle for next 250 usec PWM "frame"
doframe
        movlw   d'250'          ; pulse = pulse - 250             |B0
        subwf   pulse,F         ;                                 |B0
        bc      setduty         ;                                 |B0
        movlw   1               ;                                 |B0
        subwf   pulse+1,F       ;                                 |B0
        movlw   d'250'          ; assume 100% duty cycle frame    |B0
        bc      setduty         ; borrow? no, branch, else        |B0
        addwf   pulse,W         ; WREG = last portion of pulse    |B0
        clrf    pulse           ; force 0% duty cycle for the     |B0
        clrf    pulse+1         ; remaining pwm frames            |B0
setduty
        movwf   CCPR1L          ; set duty cycle for next frame   |B0
;  restore main program context
        swapf   S_ISR,W         ;                                 |B0
        movwf   STATUS          ; restore STATUS                  |B?
        swapf   W_ISR,f         ; don't screw up STATUS           |B?
        swapf   W_ISR,W         ; restore W-reg                   |B?
        retfie                  ; return from interrupt           |B?
Mike, K8LH is offline
Old 1st December 2007, 03:23 PM   (permalink)
Another method for generating a servo output uses the CCP module "compare" mode. This method would require just two interrupts per 20 msec cycle for a single Servo channel output and so might be better tolerated by your timing sensitive program.
Regards, Mike
Old 1st December 2007, 03:49 PM   (permalink)
Hi Mike
I was just reading your posts on this thread
http://forum.microchip.com/tm.aspx?m...2&mpage=1&key=
I will have to read it a few more times.
That does look like the only way to do it.
Thanks Mike.
C:\WHUT ?
Old 1st December 2007, 06:16 PM   (permalink)
I can think of two methods of using the PWM module to control a RC servo. With this I am assuming you have 10 bits of available resolution.
The first has the PWM on all the time and only a small fraction of the period is available to control the pulse width of the servo because 90% is needed to maintain the space between pulses (18-19mS at 50Hz refresh rate). Even if you refresh at 100Hz you still spend 80% on space and 10% on mark regardless of the pulse value. This may be adequate if you only need to control one or two servos in the background and don't want to deal with (more) interrupts.
The other one involves and interrupt just before the PWM period resets. At that time load a (new) value in the PWM duty register which will take care of the pulse itself. This will allow half of the available resolution for the actual value. Then immediately after the PWM begins it's new cycle, clear the register and wait for the next interrupt in another 20mS. Once the cycle is complete the PWM will maintain a low output until a non-zero value is loaded again.
ldanielrosa is offline
Old 2nd December 2007, 03:24 AM   (permalink)
Here is some real sloppy code for the 628A that runs a Hitec servo. Note, it uses about 90Hz, not 60 Hz as that was pretty much the limit of the prescaler. The servo code is in the first section. The sections having to do with LED's are for other controls. Bascially, the servo is used as a latch. There are two positons, high and low. You could define whatever positon(s) you want. I have had no problems running analog servos up to about 140 Hz.
Is there an easy way to provide just snippets of code with annotations? I have seen it done, but am not sure how to do it. John
jpanhalt is offline
Old 2nd December 2007, 04:15 AM   (permalink)
Thanks John
That looks interesting. I have kind of been thinking along those lines. I am glad to hear that I have more tolerance on the frequency.
C:\WHUT ?
Old 2nd December 2007, 02:18 PM   (permalink)
Originally Posted by ClydeCrashKop
Thanks John
You have lot's of tolerance on the frequency, it's basically the pulse width that matters, not the repetition rate - the repetition rate is mainly responsible for how fast it responds.
Old 2nd December 2007, 03:38 PM   (permalink)
You enclose the code in code tags, that is you put [ code] at the beginning of the section and [ /code] at the end. Note, I had to insert spaces into the tags to stop them working.
Pommie is online now
Old 2nd December 2007, 10:14 PM   (permalink)
I couldn’t use CCP because timer1 is busy being a very stable frequency counter for a dual tachometer. (2 engines) I will pull out the stops on the servo for continuous rotation. It will have a tiny model boat propeller on it, mounted inside a gauge to indicate synchronization. It will rotate at varying speeds to indicate which engine is slower and by how much. When the prop stops, it is in sync.
You guys got me thinking in the right direction. Thanks a lot.
If you see any way to make the interrupts shorter or faster, please let me know. Any other refinements are welcome.
;This program uses Timer0 interrupts and prescalers to send RC servo compatible PWM at 55Hz
;to 57Hz depending on the length of your high pulse. At 4 mhz and 1:64 prescale, timer0 will
;roll over and interrupt at about 61 Hz for the low part of the pulse. The high pulse uses a
; 1:8 prescale which would roll over every 2048us. You want a range from 1000us to 2000us so
;preload timer1 with a value that will let it roll over sooner to get the pulse width you want.
;2000 / 8 =250 counts for the longest pulse. 256-250=6 so if you preload timer1 with 6, it
; will roll over after 250 counts. 1000 / 8 = 125 counts for the shortest pulse. 256-125=131
; so if you  preload timer1 with 131, it will roll over after 125 counts.
; Center is approx. 68 so if you put 68 +/- up to 62 in the variable “Position”, you should
; get a full range of motion or speed. This is low resolution. You only get 125 positions or
;62 speeds left and right but it only interrupts your program about 20us, 120 times per minute.
;Thanks to Nigel Goodwin and his tutorials for delays and initializing Timer0 and interrupts.
;Clyde Crashkop
	LIST	p=16F628A		;tell assembler what chip we are using
	include "P16F628A.inc"		;include the defaults for the chip
	ERRORLEVEL	0,	-302	;suppress bank selection messages
	__config 0x3D18			;sets the configuration settings (oscillator type etc.)
		cblock	0x20		;start of general purpose registers
			count			;used in looping routines
			count1			;used in delay routine
			counta			;used in delay routine
			countb			;used in delay routine
			toggle			;flag to alternate between PWM high & low
			Position		;Center is 68 +/- 62 for extremes
			W_TEMP
			STATUS_TEMP
		endc
		org	0x0000
		goto	Start
; Timer0 interrupt.
            	ORG     0x0004
            	MOVWF W_TEMP
            	SWAPF STATUS,W
            	MOVWF STATUS_TEMP
            	BCF     INTCON,		T0IF
            	MOVF	toggle,	f	;Move it back to its self for zero flag
            	SKPNZ
            	GOTO	LowOut
				clrf	toggle			;To toggle for next interrupt.
				MOVF	Position,	w	;Get Position for length of high pulse
				MOVWF	TMR0			;Center is 68 +/- 60 for extremes
				bsf 	STATUS,		RP0	;select bank 1
				MOVLW   b'00000010'		;prescaler = 1:8 for high time
		       	MOVWF   OPTION_REG
				bcf 	STATUS,		RP0	;select bank 0
            	BSF		PORTB,	3	;Physically farthest from B6 T1CKI frequency input.
            	SWAPF STATUS_TEMP,W
            	MOVWF STATUS
            	SWAPF W_TEMP,F
            	SWAPF W_TEMP,W
               	RETFIE
	LowOut
				BSF		toggle,		0	;To toggle for next interrupt.
				MOVLW   b'00000101'		;prescaler = 1:64 for low time
		       	MOVWF   OPTION_REG
            	BCF		PORTB,	3	;Physically farthest from B6 T1CKI frequency input.
            	SWAPF STATUS_TEMP,W
            	MOVWF STATUS
            	SWAPF W_TEMP,F
            	SWAPF W_TEMP,W
            	RETFIE
Start	movlw	0x07
		movwf	CMCON			;turn comparators off (make it like a 16F84)
Initialise
		clrf	count
		clrf	PORTA
		clrf	PORTB
SetPorts
		movlw	0x00			;make all pins outputs
		movwf	TRISA
		movwf	TRISB
       	MOVWF   OPTION_REG
		CLRF	INTCON
        BSF     INTCON    , T0IE	;enable timer interrupts
        clrf    TMR0
        bcf     INTCON, 	T0IF	;start timer
        bsf     INTCON, 	GIE	;start interrupts
Main	;Everything from here on is just to exercise the servo
		MOVLW	d'68'	;Center
		MOVWF	Position
		CALL	Delay255
		CALL	Delay255
		CALL	Delay255
		CALL	Delay255
		MOVLW	d'6'	;Long pulse
		MOVWF	Position
		CALL	Delay255
		CALL	Delay255
		CALL	Delay255
		CALL	Delay255
		MOVLW	d'125'	;Short pulse
		MOVWF	Position
		CALL	Delay255
		CALL	Delay255
		CALL	Delay255
		CALL	Delay255
		goto	Main			;loop for ever
;Delay routines
Delay255	movlw	0xff		;delay 255 mS
		goto	d0
Delay100	movlw	d'100'		;delay 100mS
		goto	d0
Delay50		movlw	d'50'		;delay 50mS
		goto	d0
Delay20		movlw	d'20'		;delay 20mS
		goto	d0
Delay5		movlw	0x05		;delay 5.000 ms (4 MHz clock)
d0		movwf	count1
d1		movlw	0xC7			;delay 1mS
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		retlw	0x00
;end of Delay routines
		end
C:\WHUT ?
Old 2nd December 2007, 10:28 PM   (permalink)
That is hard to read so here is asm file.
C:\WHUT ?
Old 2nd December 2007, 11:48 PM   (permalink)
[/code]
It's called a "synchroscope" in full-scale, twin-engine aircraft. Please let us know how it works. John
jpanhalt is offline
Old 3rd December 2007, 01:53 AM   (permalink)
From a post here on Oct 3 2006
My best customer wants an indicator to help manually synchronize the RPMs on his 2 boat engines. He has an airplane with a sync gauge that has a propeller that spins one way or the other and stops when the engines are in sync. He really likes that and I thought I could put it on his boat. I can’t seem to find it or any others online.
The Yanmar diesels put out a hall effect tach signal at about 200 pulses per rev from the flywheel ring gear.
That is the main reason I got started with PICs. While just trying to make a whirly gig, I now have a perfect dual digital tach on a 4 X 40 LCD with the difference in RPM, port or stbd. I almost had it working with a gear reduced motor, a DPDT relay and PWM at about 2 kHz but the output was messing up the tach input. This was just before they took the boats to the Bahamas for 2 months. I did manage make and install a 10 LED bar graph before they left. It serves the purpose for now and I told him the prop version was in progress. I learned a whole lot in the process and there is no way I could charge him for all the time spent so I told him “No charge. Merry Christmas”. Besides, a little Karma goes a long way. Now I am on vacation for 2 months. (hehehe)
C:\WHUT ?
Old 3rd December 2007, 02:15 AM   (permalink)
Well, Timer 0 works extremely well as a frequency counter too. Actually, it works better because there's an anomoly when Timer 1 is used as a counter that throws away the first count. Anyway, that would free up Timer 1.
I can't quite figure out what you're doing from your brief description and code but I suspect you could reallocate PIC resources to come up with a simpler cleaner tighter solution than what you have now.
Good luck with your project.
Mike
Old 3rd December 2007, 02:23 AM   (permalink)
Tell us how you're implementing the Timer 1 frequency counter? How long and how often are you counting the hall effect signal on each motor? How to you switch the T1CKI counter input pin between motors?
Driving a servo motor Wingmax Robotics Chat 26 11th February 2008 09:56 PM
Servo problems bananasiong Micro Controllers 0 16th September 2007 02:15 AM
Servo Controll... In reverse? savage Micro Controllers 9 1st December 2006 03:10 PM
Replacing RC Servo w/ Custom PCB (Open Servo) dknguyen Electronic Projects Design/Ideas/Reviews 3 29th May 2006 02:48 AM
Help required with servo motor controller mayhem Robotics Chat 3 26th May 2006 04:21 PM
