Old 28th November 2007, 08:15 PM   (permalink)
Default PIC Questions
Hello again, i was looking at this pic PIC16F628, is there a compatible pic that has an internal oscillator? I was looking at this programmer, is the serial connection male or female?
(R1 is 2.2k)
wmmullaney is offline
Old 28th November 2007, 08:40 PM   (permalink)
can I use 5k resistors?
Old 28th November 2007, 09:26 PM   (permalink)
The 16F628 has an internal oscillator, that's why I chose it for my tutorials, plus it was the replacement for the popular old 16F84.
Old 28th November 2007, 10:07 PM   (permalink)
Ok, must have missed it in the data sheets, were can I find your tutorials?
5k Resistors?
Old 29th November 2007, 01:21 AM   (permalink)
Found this.
http://www.jdm.homepage.dk/easypic.htm
Is "R" needed?
Old 29th November 2007, 03:53 AM   (permalink)
Your programmer will give you trouble in a small variation on your comport voltages & in your supply.In your programmers it needs external 5V.If the voltage exactly 5V you don't need the resister.Most JDM type uses 5.1 zenners.
Try making the JDM programmer here is the simple version of that working well.
No need external supply.
http://www.semis.demon.co.uk/uJDM/uJDMmain.htm
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 29th November 2007, 08:47 AM   (permalink)
In my signature at the bottom of all of my posts!.
5k Resistors?
It's a crude nasty 'programmer', and they tend to give lots of problems, and only work on some computers.
Old 29th November 2007, 06:51 PM   (permalink)
Ok, I'v seen the uJDM, kinda wanted something simpler just to start, after that I want to get a JDM programmer from Sparkfun.
So, 5k resistors will work.
I hope to have my projects up and running by Christmas.
Old 29th November 2007, 07:12 PM   (permalink)
The JDM is really too simple to be reliable, and is fussy about the particular machine it's connected to.
Old 29th November 2007, 07:33 PM   (permalink)
What do you suggest? I don't have 50+ dollars to spend. Or to many parts to build one with.
Old 29th November 2007, 07:35 PM   (permalink)
Is the PIC16F628 compatible with the PIC16f84?
Old 29th November 2007, 08:30 PM   (permalink)
Define "compatible" ? It's not the same part, but check the datasheets for pinout compatibility.
matc is offline
Old 29th November 2007, 08:53 PM   (permalink)
It replaced it last century, the 84 has effectively been obselete for a LONG time now. The 628 is cheaper, higher spec, and pin compatible with the 84, requiring only extremely minor changes to the source code to run.
Old 29th November 2007, 10:29 PM   (permalink)
I meant in a programmer.
Old 29th November 2007, 10:36 PM   (permalink)
On the "simplest programmer in the world" what does he mean when he says vdd not to be pulled higher than .5v?
Originally Posted by Jens Dyekjær Madsen
In fact, the clamp diodes to Vdd is not diodes, but transistors, and about 80% of the current flows into ground. Because of this, are Vdd not to be pulled higher than Vdd+0.5V, even all the inputs pulls high.
Does this mean R is needed? even if the 5v is regulated?
Quik PIC Programming kit Krumlink General Electronics Chat 5 28th January 2008 12:27 AM
Problems switchin relay with PIC Andy1845c General Electronics Chat 5 17th November 2007 07:14 PM
PIC pin to MOSFET gate problem Futterama Electronic Projects Design/Ideas/Reviews 7 8th November 2007 06:31 PM
High ADC sampling rate PIC, 18F needed? bananasiong Micro Controllers 24 28th October 2007 01:13 PM
Four PIC with One LCD.. meera83 Micro Controllers 13 20th September 2007 07:40 AM
