| A simple POV display for Junebug 18F1320. Quote:
The multiplexing could probably be fine tuned to make a brighter display. It's best to use a battery and wave the thing in a dark room, rather than risking damage with the Junebug on the USB cable. I used a 9V battery connected direct which is probably a very bad idea, but it hasn't cooked the Junebug yet. A fresh battery might be bad. Here's a pic of my font designing notes. The code has 12 letters at present. I wanted it to be able to display JUNEBUG and FUTZ. Make your own from there. Download source and hex file. Have fun! EDIT: Whoops! Was: Code: main movlw lettF call letter movlw lettU call letter movlw lettT call letter movlw lettZ call letter return Code: goto main Last edited by futz; 25th November 2007 at 12:19 PM. | ||
| That's awesome A $1 6V camera battery might be kinder to the PICs. Some NiMH 9V are only 7.2V and a simple 1N4001 diode would put it closer to slightly abused specs. Original PICs were designed for 7V the 1650 | |
| Futz have you ever worked with iButtons / 1Wire devices? | |
| That little connector under the reset button was designed with the DS18S20 in mind, even the pullup is there. Kyle-s4H did some iButton programming for the Firefly. Here's another interesting project that should be easy to do. http://www.jdm.homepage.dk/solarpic.htm Or this http://www.sixca.com/eng/articles/remote/index.html Note: the 12F629 doesn't need the crystal for this application. ![]() Last edited by blueroomelectronics; 26th November 2007 at 06:18 PM. | |
I've got both data sheets here and they look real similar. I need to get SPI working on the Junebug too, but that's almost as easy as asynchronous serial. I designed and built several 7-seg 4-digit LED displays a while back that use the MAX7219 chips. | ||
| There is no hardware SPI on the 18F1320 so it would be all bit banged. The DS18B20 and 18S20 are similar, I can't recall the differences off the top of my head. There is also a PAR version. Of course you could use a thermistor in the same socket. | |
| | (permalink) | ||
| I don't see a SSP or MSSP in the datasheet. There is a synchronus serial port but that's not SPI, that really fast serial. | |
| Junebug users - fun little diag program for ya | futz | Micro Controllers | 15 | 29th November 2007 03:29 AM |
| Uni Project Advice | 2-tone | Electronic Projects Design/Ideas/Reviews | 7 | 18th October 2007 01:11 AM |
| My professor screwed my final electronics project! | kungfusansu | Electronic Projects Design/Ideas/Reviews | 21 | 26th August 2007 10:57 PM |
| FINAL YEAR PROJECT! | erique82 | Electronic Projects Design/Ideas/Reviews | 18 | 15th April 2007 11:09 AM |
| A Microcontroller based Analogue Waveforms Analyzer Project | km | Electronic Projects Design/Ideas/Reviews | 76 | 30th June 2004 07:40 PM |
