+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 19
Thread: Binary counter
  1. #1
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    Default Binary counter
    I am hoping for a little guidance , I may be taking on a project a little beyond that of a beginner to microcontrolers but let me outline what I am trying to do.
    I have a CB radio I am modifying for 10 meter ham use. what I want to do is remove the 40 position channel selector and program the PLL directly off a PIC set up to run as a binary counter , that seems to be the easy part , where it gets complicated is I want to interpret the binary count being delivered to the PLL and display the coresponding frequency on a display , either LCD or LED , the PLL is programed via 8 bit binary and I need the count to run n:101 - n:255 (1100101 -111111 ) and reset , be selectable as a down counter or up and be able to halt the count when the desired frequncy is reached.
    I was originaly going to do this with a bank of 74192's on the pll end a a bank of 74192's and 74247's drining a 7 segment display but I think the microprocessor woud do the job better
    any help would be greatly appreciated , I am eager to learn and not unfamiliar with electronic theory , just new to PICs
  2. #2
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    So, basically what you want is a counter that can count upwards from 101 to 255 or backwards from 255 to 101, and wrap back. And the current value needs to be displayed? Do i understand it correctly or not ?
  3. #3
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    Yes , exactly , however , I want the display to show the true operating frequency , 101 being equivalent to 27.995 the 2 and 5 are hardwired and 7.99 are the only displays being changed , 7.99 , 7.98 , 7.97 etc...
  4. #4
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    I also am aware that I will probably have to use 2 pics for this project , one for the display and 1 for the counter , but it will still be alot better than using 10 TTL chips LOL
  5. #5
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    Nope 1 pic can handle it with ease... writing a litte example as we speak...
    But if you know absolutely nothing about pics it might be worthwhile to take a look around on the net to get to know the basics.
  6. #6
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    Doing that as you type Exo , I am quite excited about learning the ins and outs , I am a Ham Radio operator and have been an Electronics hobbiest for a long time , I am totaly new to Microprocessors but have been looking at the basic ASM code , it doesnt look too bad , should be able to pick it up , even if I am an old Dog learning new tricks LOL , I havent picked up a soldering iron for 10 yrs and the last project I built was a tube RF amplifier , just a little diffrent than what I am attempting now
  7. #7
    motion Newbie
    Join Date
    Jul 2003
    Location
    Quezon City.PH
    Posts
    560
    What is the frequency of the PLL divider will have to handle? If you plan to use the PIC's internal counters, you will be limited by the maximum frequency it can handle. Otherwise, a single PIC will handle the task easy.
  8. #8
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    here you go; i tried to add some understandable comment, but like i said
    if you're a complete newbie to pics it still may be hard to understand
  9. #9
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    PLL frequency wont be an issue , I am just trying to apply binary programming to the divide counters , it is currently handled by 8 binary inputs connected to a mechanical 40 position switch
  10. #10
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    Open it with wordpad... notepad screws up the format
  11. #11
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    P8 is held low throughout the full required range , hence I need only 8 bit binary
  12. #12
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    Awesome , I think I would preffer to use an LCD display but LED would work for me too , the display was actually an after thought but I felt it would really finish the project off well
  13. #13
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    Question Exo, PORTA is a 4 bit port and being used currently for the up switch and down switch on RA0 and RA1 , PORTB will be dedicated for the programming inputs of the PLL02a, so I am left assuming that if I were to include a display on this pic it would be serial LCD on port RA2 or RA3 ?, I have been looking at the code you sent , I think I am going to enjoy working with pics , very elegant aproach to alot of projects I didnt want to take on , thanks
  14. #14
    Exo
    Exo is offline
    Exo Newbie
    Join Date
    Sep 2003
    Location
    Belgium
    Posts
    1,884
    PortA is a 5 bit port RA0 to RA4
    So there are 3 pins left on this port
    I already succeeded in driving 4 7segment displays using only 3 lines by using a 4094 serial shift register and an 4028 to multiplex them
    You only need 3 7segment displays (because the 2 and the 5 can be hard-wired) so its certainly possible...
    Another possibility is buying a pic16f628 instead of a 16F84
    Bacause it has an internal 4Mhz osc. the 2 pins normally used by the crystal become available as I/O; giving you up to 5 free I/O lines (4 lines in combination with a 4094 is enough to drive a HD44780 LCD module)
    best of all... the 16F628 is cheaper then the F84 (here in belgium anyway)
  15. #15
    Slashdot Newbie
    Join Date
    Sep 2003
    Location
    Canada
    Posts
    15
    LOL , just ordered 6 16f84a's will work with them for a bit , got the data sheets as well and I think I am understanding the programing more every time I read it
+ Reply to Thread
Page 1 of 2
1 2 Last
Tags for this Thread
