LCD4 Optimized LCD Module Last edited by wschroeder; 19th November 2007 at 06:21 AM. | ||
Besides more RAM/FLASH and a more comprehensive and cohesive instruction set there's direct access to the top-of-stack as well as stack push and pop operations. Very exciting empowering stuff; Code: ;
; jump table example (completely 256 byte boundary tolerant)
rcall Jump ; WREG = index 0..3
table goto Func_0 ; index 0 function
goto Func_1 ; index 1 function
goto Func_2 ; index 2 function
goto Func_3 ; index 3 function Code: ;
; Jump function
Jump rlncf WREG,W ; WREG *= 2
addwf TOSL,F ; add to return address Lo
movlw 0 ;
addwfc TOSH,F ; propogate Carry
addwfc TOSU,F ; propogate Carry
return ; return to table + WREG*2 Code: ;
; PutString macro usage
PutStr "Az-El Rotor Maintenance/n/n/r"
PutStr "1 - Calibrate Az rotor/n/r"
PutStr "2 - Calibrate El rotor/n/r"
PutStr "3 - Return to Main Menu/n/r"
; Code: ;
; the PutString macro
PutStr macro pStr
rcall PutString ;
db pStr,0 ; null terminated inline string table
endm
; Code: ;******************************************************************
; PutString - print in-line string via Stack and TBLPTR
; string must be terminated with a 0 byte and does not need
; to be word aligned
PutString
movff TOSL,TBLPTRL ; copy return address into TBLPTR
movff TOSH,TBLPTRH ;
clrf TBLPTRU ; assume PIC with < 64-KB
PutNext
tblrd *+ ; get in-line string character
movf TABLAT,W ; last character (00)?
bz PutExit ; yes, exit, else
rcall Put232 ; print character
bra PutNext ; and do another
PutExit
btfsc TBLPTRL,0 ; odd address? no, skip, else
tblrd *+ ; make it even (fix Program Counter)
movf TBLPTRH,W ; setup new return address
movwf TOSH ;
movf TBLPTRL,W ;
movwf TOSL ;
return ; to 1st instruction following string table | ||
I like assembler very much. | ||
| Peter, I hope you don't give up on Assembler completely. While it's hard to beat the built-in high level language library functions, creating your own Assembler functions isn't difficult. And macros can often be used effectively to create very readable and intuitive code. Take Warren's (wschroeder's) excellent BASIC LCD functions for example. I suspect they're similar to what I use in Assembler; Code: radix dec
; Host program example macro usage
Line1 equ 128 ;
Line2 equ 128+64 ;
Line3 equ 128+20 ;
Line4 equ 128+64+20 ;
PutLCD cmd,0x0C ; display on, cursor off
PutLCD cmd,Line1+10 ; lcd line 1, htab 10
PutLCD str,"GMT" ; print "GMT" string
PutLCD cmd,Line2+10 ; lcd line 2, htab 10
PutLCD dat,'?' ; print "?" character
PutLCD cmd,0x10 ; cursor shift left
PutLCD cmd,0x0F ; cursor on (blink) Code: ;--< macro definitions >-------------------------------------------
cmd equ 1 ; single byte command/control type
dat equ 2 ; single byte character/data type
dec equ 3 ; single byte variable 0..9
str equ 4 ; multi-byte string character type
PutLCD macro ptype,pdata
if ptype == cmd ; creates 2 instructions
movlw pdata ;
call PutCmd ; low level driver, RS=0
endif
if ptype == dat ; creates 2 instructions
movlw pdata ;
call PutDat ; low level driver, RS=1
endif
if ptype == dec ; creates 3 instructions
movf pdata,W ; Wreg = variable
iorlw '0' ; 0..9 -> ASCII "0..9"
endif
if ptype == str ; creates 1 instruction + inline table
call PutString ; (18F version)
db pdata,0 ; null terminated inline table
endif
endm Last edited by Mike, K8LH; 19th November 2007 at 12:03 PM. | |
| I understand why those who are already familiar with PIC assembler might want to continue using it, especially if they are not familiar with C. I can also understand that you may be used to trying to squeeze every ounce of performance, or space in RAM/ROM out of a PIC if you've been using the 16 series. The 18 series are *fast*... much faster than the 16F84 or 628a's most of the current crop of PIC affectionados have been using. The flash ROM has also expanded significantly giving you more room to move. The prices seem so reasonable that it's hard to imagine wanting to continue to use the 16 series except in the most price-sensitive applications. For me, as an engineer wanting to design his first PIC-based product, using the 18 series and C meant that my productivity was *very* quickly to the point where I was writing useful code, without needing to learn PIC assembler which is quite frankly baroque. C is C is C... the wrinkles involved in 8-bit vs 16 or 32-bit *are* part of C, so moving from a 6809 to a 68000 to a PIC18, PIC24 etc. is straightforward. In fact moving to the new PIC32 series is *much* easier if you know C... the assembler is so totally different that most PIC assembler fans are going to find the learning curve very steep and therefore simply decide to ignore them. I have found learning the PIC architecture and I/O capabilities to be a great deal of fun :-) Using C I've got a lot further in my design in the time I've spent than I would have had I learned the assembler (and I'm a *very* good assembler programmer.) So... *please* give some thought to learning C. You're a computer scientist, programmer or engineer, and learning *new* languages, concepts, etc. is part of your vocation or hobby as the case may be. </rant off> P. PS: I re-wrote all of the library routines I used in my prototype... they are fine for a first stab as and as a basis for learning, but near useless for serious applications. Last edited by aussiepoof; 19th November 2007 at 12:48 PM. | |
| All very valid points. C also seems pretty much the defacto 'standard' for professional/commercial development. Mike | |
| I agree with all that has been said about C but do find that often mc code written in C is inefficient due to a lack of understanding of the underlying hardware. So, I would add to the discussion, learn to read data sheets at the same time as you learn C or if you know C, take time to read the relevant sections in the data sheet. Mike. | |
| I should have mentioned I enjoy programming in C18, BASIC, and Assembler and I recognize strengths and weaknesses in each. I agree it does take more time to write a program in Assembler than it would to write the same program in C18 or BASIC. I really shouldn't encourage or discourage the use of one language over another. I can write tight, simple, elegant code in each. I can also write loose, sloppy, unintelligent code in each. Mike | |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| USB Time Delay Fan Control | Karaethon | Micro Controllers | 53 | 14th March 2006 10:36 PM |
| With limited time, what ways to increase qualifications? | sram | Chit-Chat | 1 | 8th January 2006 09:18 PM |
| Drawing Waveforms or how to draw waveforms | walters | General Electronics Chat | 105 | 11th December 2005 12:24 PM |
| to set accurate time on laptop for visual satallite tracking | John walker | Electronic Projects Design/Ideas/Reviews | 4 | 12th October 2005 05:30 PM |
