hello all... is that any information of keypad using the mplab write one... i'm a newbie and no use this software before. can anyone show me some easy code for the keypad. because i don't know is that correct or not when i reseach from the website... thx for helping | |
hi, Look at this site: http://www.winpicprog.co.uk/ Or here: http://www.tundraware.com/Software/PIC/keypad/
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 12th November 2007 at 12:39 PM. | |
| | #3 | |
if i using the IC 74C922 is that i can save a lot of time for write software?? | ||
how about using the IC74C922 ?? is that any problem when using the IC74C922 send data to the PIC16f877?? | |
You can use the IC74C922 if you want. You don't need to because the PIC can do it all by itself as mentioned on the pages posted by Eric.
__________________ Inside every little problem, is a big problem trying to get out. | |
| | #6 | |
ya i know. but the thing i want is use the keypad combine with the PIC and get the output to control other thing. is that i can use IC74C922 combine with the PIC then get the output from PIC? | ||
| | #7 |
Yes, you can do it either way - it all depends on which you prefer (and on what keypad you have).
| | #8 | |
A 74C922 can simplify your program. Basically it scans a 4 * 4 keypad matrix, giving a output nibble 0 thru F [4bit] also a another bit goes high to say a key has been pressed, use that for the Interrupt. If you live in the UK, I'll send you one, FOC.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:22 PM. | ||
| | #9 |
It's available here but this is one of my favourite PIC Tip & Tricks (there are many more on the Microchip site in the app notes section. There's a section on a 4x4 keypad in there.
| | #10 |
I like the resistor keypad idea. Here the 74c922 costs more than the pic itself | |
| | #11 | |
| | #12 |
thx a lot for all helping me in here.....
| | #13 |
i have a quetion for the IC74C922.... is that i press the button '0' the output will become "PA=0,PB=0,PC=0,PD=0" then i press the output '1' will become "PA=0,PB=0,PC=0,PD=1" and so on..>?? or is other else? | |
| | #14 |
is this correct?? #include <p16f877.inc> PortB equ 06h out_put MACRO var movwf PortB bsf PortB, var bsc PortB, var movf h'0A', w out_put 4 movf h'0B', w out_put 3 movf h'0C', w out_put 2 movf h'0D', w out_put 1 ENDM END thx for helping | |
| | #15 | |
If you look at the TRUTH table as part of the 74C922 diagram I posted a few days ago, it will answer your question. Summary: the answer to this question is, for the #1 key, A=1,B=0,C=0,D=0,[you have reversed the pattern!], also a pin goes high on the 74C922, [Data Available], while a key is pressed, use this to interrupt the PIC program. If you 'OR' the 'A B C D' line input pattern with 30hex, it will give you ASCII '0', '1'... '9', :,:,<,=,>,?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 19th November 2007 at 09:35 AM. | ||
| keypad, newbie, pic |
| PIC pin to MOSFET gate problem | Futterama | Electronic Projects Design/Ideas/Reviews | 7 | 8th November 2007 06:31 PM |
| High ADC sampling rate PIC, 18F needed? | bananasiong | Micro Controllers | 24 | 28th October 2007 01:13 PM |
| Four PIC with One LCD.. | meera83 | Micro Controllers | 13 | 20th September 2007 07:40 AM |
| keypad encoder | Mel_noypi | Datasheet/Parts Requests | 5 | 22nd February 2006 03:01 PM |
| PicBasic Keypad program | Sora | Micro Controllers | 0 | 20th April 2004 08:02 PM |
