| Hello all, I', wondering wich voltage is concidered as "0" low in PIC inputs. "0" volt to...??? Thanks | |
| Why not try reading the datasheet?. | |
| It depends on the PIC family, and what voltage you're using for Vcc. | |
Some pins on the PIC have schmitt trigger characteristic and require higher input level than remaining pins.
__________________ L.Chung | ||
Search the datasheet.pdf for 'AC and DC characteristics' they are near the end of the datasheet, they tell you all you need to know.
| eblc is right though, it depends on the pin. Pin's used for various onboard peripherals can have different driving circuitry. So you need to consult the PDF's peripheral section when it's being used as a general IO pin.
| Does anybody know that a pin configured as digital input consumes less power if it's pulled up or down? | |
The conventional method is to use pull-ups, and MicroChip even provide switchable internal pull-ups on PortB. | ||
| No digital inputs should be left 'floating' as this creates problems with noise and current draw. As Nigel said, the PIC's have an option for weak pullup to solve this issue. | |
If you do have an unfounded fear of such a problem?, simply leave the pins open, but set them to be outputs - and again, setting them as outputs makes no difference to the current consumption (same old thread on the PICList). | ||
| Perhaps it's just an old habit then, it used to be good practice to 'keep digital inputs tidy' and NOT just on CMOS. By the way, TTL gate inputs tend to 'float' high and often data sheets stipulate 'tying unused inputs' high or low. | |
| Using Oscilloscopes | mechie | Electronic Theory | 9 | 29th November 2007 10:49 PM |
| Four PIC with One LCD.. | meera83 | Micro Controllers | 13 | 20th September 2007 07:40 AM |
| 4-20mA & 1-5V PIC input | mikesmixes | Micro Controllers | 12 | 13th September 2007 02:24 PM |
| Output = Input - Problems | adamthole | Micro Controllers | 20 | 24th April 2007 05:09 AM |
| uuffff how doess this stupid ting work lol | cyprio7 | General Electronics Chat | 7 | 9th October 2005 07:56 PM |
