Old 6th November 2007, 03:55 AM   #1
Exclamation Junebug Assembly Tips
For anybody almost done with their Junebug programmer or about to get one, I have a few important pointers for you. PS Bill: Check over your Assembly manual
The attached images are ones that I think that you may be confused with. One that You may overlook is R11 and R12, they go under the 18F2550 and are 100 ohm resistors.
R7 is a 100k resistor
Watch the MOSFET Pin out
The 2N3904 is substitutable with a 2N2222A
The 2N3906 is substitutable with a 2N2907A
I will keep this updated as I go. Also, watch how you put in those switches!
Junebug Assembly Tips-r7.jpg   Junebug Assembly Tips-1.jpg   Junebug Assembly Tips-mosfets.jpg   Junebug Assembly Tips-r11-r12.jpg
IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S
Krumlink is offline
Old 6th November 2007, 04:01 AM   #2
Very nice, and yes those transistors will work. The tricky ones are the FETs but both are optional (they allow VPP before VDD programming and shorted target VDD testing)
I'm working on the manual a wee bit everyday.
I don't think the switches will fit in the wrong way, they're rectangular.
The ferrite bead is recommended but you can use a wire link if you don't have one.
And you can stand little 1/8 watt resistors where the SIPs go.
Bill
Smart Kits build Smart People
Old 6th November 2007, 04:40 AM   #3
OR, you could stand up some 1/4 watts like I am going to.
Krumlink is offline
Old 6th November 2007, 04:56 AM   #4
Sure why not, just a little more cramped.
Bill
Old 6th November 2007, 04:59 AM   #5
I am going to get the rest of the parts very soon, I really would like to use this, as well as my inchworm+. That one C class will love a couple of these
The next idea for a kit should be some kind of robot kit programmer, besides your mongoose. Is that even available yet?
Krumlink is offline
Old 6th November 2007, 05:31 AM   #6
Next kit will be either an Ethernet I/O controller or an RS485 thermostat.
What do you mean by Robot kit programmer? Example?
Bill
Old 6th November 2007, 05:44 AM   #7
My Breakout board, that I was thinking of. Its under robotics. Maybe you or 3v0 could help me set up one that uses a 16F88. It would be really cool (further down the road, but still applicable).
Krumlink is offline
Old 7th November 2007, 02:44 AM   #8
As a substitute for a ferrite bead, you can also run a wire through a small toroid, which is what I did.
Krumlink is offline
Old 7th November 2007, 03:45 AM   #9
I am building the JuneBug in 3 steps.
1. Get the programmer's processor working/talking/USB-connected (done)
2. Add the analog parts (transistors etc) to finish the programmer
3. The tutor.
I built the processor section (1) of the JuneBug programmer and have it working. Had a bit of difficulty with the unrecognized USB device error. It worked after I changed C6 to a .22uf ceramic cap. The cap that did not work was Mylar. Could have been a defective part. .22uF is within the range that Bill indicated.
The USB software driver is a non issue with the PK2. It uses standard XP supplied drivers.
You need to program the PIC18F2550 processor with another programmer such as the inchworm. The procedure can be done on a protoboard with the inchworm connected to the 18F2550. You do not need a crystal but it is a good idea to use a .1uF bypass cap between pwr and gnd.
Download the ziped hex file PICkit 2 Firmware V2.10. (if you are reading this much later then NOV 07 check for an updated version here).
Unzip the file and place the file PK2V021000.hex in a location that you can easily find. ie: C:\abc\PK2V021000.hex
Start MPLAB. You will not be using a project.
Configure>Select_Device> PIC18F2550
File>Import ... then browse to C:\abc\PK2V021000.hex and click on it.
You do not need to set the fuse/configuration setting because they are included in the hex file.
Programmer>Select_Programmer>MPLAB_ICD2
Programmer>Connect
Programmer>Program
That should do it. If anyone sees an error in this I will be glad to edit this post.
Good luck.
3v0 is online now
Old 7th November 2007, 04:04 AM   #10
CUSB 220nf is the minimum recommend PIC18F2550 datasheet pg 376.
Glad you got the boards.
Here's the Junebug "Hello World"
 ;*** WDT reset toggles RA7
   list     p=18F1320
   include <p18F1320.inc>
   CONFIG   OSC=INTIO2, LVP=OFF, DEBUG = ON
   CONFIG   WDT=ON, WDTPS=128
   org      0
   movlw    b'00111111'
   movwf    TRISA
   btg      LATA, 7
   sleep
   end
Bill
Old 7th November 2007, 04:34 AM   #11
I forgot to thank you for them...
3v0 is online now
Old 7th November 2007, 11:47 AM   #12
In MPLAB 8.00 under %install_dir%\Microchip\MPLAB IDE\PICkit 2\ the latest version of firmware is PK2V022000.hex, PK2V021000.hex is also in there.
Interestingly in the PK2 section of the MPLAB 8.00 release notes it doesn't mention V2.2 but it is there.
Pete
picprojects.org.uk
geko is offline
Old 7th November 2007, 09:37 PM   #13
Bill, make sure you have the SIP resistor networks right, 3v0 and I just had trouble tracing a trace
It looks like the Entire R2A-E might need to be re-checked on your schematic. Make sure it is right.
Krumlink is offline
Old 7th November 2007, 09:40 PM   #14
Which trace? R19C which is labeled wrong in the instructions (fixing it I am)
Bill
Old 7th November 2007, 09:49 PM   #15
R2A (100 ohm, located directly above VR2 and D3 is left of it).
Krumlink is offline
assembly, junebug, tips
Junebug kit ready, (PICkit2 & tutor) blueroomelectronics Micro Controllers 37 28th October 2007 03:47 AM
Assembly? Marks256 Micro Controllers 43 28th July 2006 04:45 PM
Assembly compiler Thunderchild Micro Controllers 4 12th March 2006 02:25 PM
Learning Assembly Programming Language Johnson777717 Micro Controllers 4 22nd March 2004 03:00 PM
Assembly Language Question Jeggyman General Electronics Chat 6 30th January 2004 10:54 PM
