| The BS170 appears to be an excellent replacement for the 2N7000. | |
| (Priliminary step__ My DMM has been cross checked with another by measuring my PC's +5V. Both meters were reading 5.12V) 1. Oh God - I interchanged 2 transistors (Q1 and Q4)by mistake. Today I have restored them. 2.the resistor R17 has been increased to 680 ohms due to very high brightness and consumption too. 3. The consumption at 5V external feeding was measured at 130mA. After removing the 18F2550 it has come to 65mA. Now with 680 ohms, and transistors normalled , the current with f2550 in socket is 70mA with 5V supply. 4. the USB is still at 4.71V. 5. a) The trouble shooting procedure, the Vdd is indicated as if 4.5V. I don't Know where this measurement was taken. I presume it as measured at pin3 (TG_T) of 18f2550. 5. b) the Vpp is indicated as if, it is 11.9V. But actual measurement at collector of Q4 is only 10.99.V 6. The specific test of red color LED blinking, when powered while reset key pressed , is OK. Now I am sure until I manage this voltage to 12.5V , perhaps I can't use it. I propose to tamper the feed back ratio by reducing the R6 to get the required Voltage. I have used a 1% Tol resistor of 2K7 here. Please offer your valuable comments and help me . Meantime I am also trying to see how to improve the USB voltage of my PC. here I wan to attach a link to an Intel document PDF. If you google for this link you will land in usb.org link with a pdf suggested. perhaps it may be of help to us. "Power Delivery Design Issues for Hi-Speed USB on Motherboards" In my case the PC USB socket, the series resistor on 5V supply line is marked x15 ( I presume it to be 0.15 ohm. I would try to manipulate this to .075 by paralleling another. It might take time.
__________________ Regards, Sarma. Last edited by mvs sarma; 12th January 2008 at 03:30 PM. | |
| The 2N7000 and BS170 will both work, just depends on what part of the world you're in one will be more available than the other. Preprogrammed 18F2550 comes with the kit, the firmware will update itself if it's older when you use MPLAB or PICKit2 software. You can even downgrade to 1.x if need be so you can recalibrate PIC12F chips (feature was removed in 2.x PICkit2 software) DIY builders that have to supply their own 18F2550 will have to have access to a PIC programmer, sort of chicken before the egg problem. Here's a useful tip for the MOSFETs (as they can be tricky to figure out DS) * Use a multimeter to find the internal diode across D & S the Gate will be in the center. | |
| It was aimed like yours just to help anyone interest in building the Junebug or any other ICD type programmer. As for your USB it's not likely serviceable. A powered USB hub should work fine and are often not current limited. The VPP section is right out of the PICkit2 manual, it works perfectly using the values in the schematic. Last edited by blueroomelectronics; 12th January 2008 at 07:47 PM. | |
| I finally got my junebug working!!! (big thanks to 3v0, Bill for the board, looks awesome) Heres a pic: It is pretty "special", as in ride the short bus special. Reistors and caps too big, crystal too big, no DIP Switch but shorting blocks, Massive Toroid, Messed up Ferrite bead (found off old monitor board, it is all twisted up) and tiny switches. But hey at least it can recognize chips and work! Any comments on my junebug? Last edited by Krumlink; 28th January 2008 at 11:59 PM. | |
| Looks great Krumlink, I'll have to get you a smaller inductor that ones a beast. | |
| No, it makes mine that more special | |
Hey, as long as it works, no problem.
__________________ ========================= Futz's Microcontrollers & Robotics ========================= | ||
| Krumlink, what does DON'T PRESS mean? The button? | |
| While we were working on it Krumlink asked what the bootloader button was for. I told him that he would have to re-flash the chip if he hit it. Not exactly right but close enough, I did not want to get into bootloaders at the point. He promptly posted the danger sign on the unit.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| Hey bill how do I get the demo to work? Do i follow the directions on the Hello world poster but instead put in its code? | |
| Junebug kit ready, (PICkit2 & tutor) | blueroomelectronics | Micro Controllers | 37 | 28th October 2007 03:47 AM |
| Assembly? | Marks256 | Micro Controllers | 43 | 28th July 2006 04:45 PM |
| Assembly compiler | Thunderchild | Micro Controllers | 4 | 12th March 2006 02:25 PM |
| Learning Assembly Programming Language | Johnson777717 | Micro Controllers | 4 | 22nd March 2004 03:00 PM |
| Assembly Language Question | Jeggyman | General Electronics Chat | 6 | 30th January 2004 10:54 PM |
