What are you using to program the 18F2550?
I'm using a kit149 BE. I read the 18f2550 after programming and the hex looks exactly like the hex I was trying to put into it. Should there be any info in the EEPROM? I'm going to continue with my build and put a few pictures in a little while.
jeremy |
It uses the eeprom but I don't think having it unprogrammed is a problem. The PICkit 2 standalone software will let you calibrate and name your PK2 / Junebug.
Almost done with it. My clone is probably the ugliest programmer ever.
jeremy |
Well just for the record here's my prototype. I used a 18F4550 because I had one handy at the time. Still works too!
Parts List JUNEBUG Capacitors 1 C1 22uF 16V (must be at least 16V rated) 2 C2,3 22pF ceramic (18pF thru 22pF acceptable) (495-3298-1-ND) 2 C4,8 0.1uF 1 C5 100uF (47uF or greater acceptable) 1 C6 0.47uF (0.22uF thru 0.47uF acceptable) (445-3850-ND) 1 C7 22uF (4.7uF thru 47uF acceptable) Resistors ¼W 1 R1 10K x 5 SIP 10pin 5 independent resistors (4610X-2-103LF-ND) 1 R2 100 x 5 SIP 10pin 5 independent resistors (4610X-2-101LF-ND) 1 R3 4.7K x 5 SIP 10pin 5 independent resistors (4610X-2-472LF-ND) 1 R4,5,10 1K Brown, Black, Red, Gold 1 R6 2.7K Red, Yellow, Red, Gold 1 R7 100K Brown, Black, Yellow, Gold 4 R8,13,14,17 330 Orange, Orange, Brown, Gold 3 R9,11,12 100 Brown, Black, Brown, Gold 2 R15,16 22K Red, Red, Orange, Gold 2 VR1,VR2 10K 10K Trimmer potentiometers Semiconductors 2 D1,3 1N4148 Small Signal Diode 1 D2 1N5817 Schottky Diode (1N5817-TPCT-ND) 6 LED1,2,3,4,5,6 3mm or 5mm RED or GREEN LED 1 LED7 3mm GREEN LED 1 LED8 3mm YELLOW LED 1 LED9 3mm RED LED 1 IR1 TSOP34838 38KHz IR detector 1 Q1,3,6 2N3904 NPN (EBC) 1 Q4 2N3906 PNP (EBC) 1 Q5 2N7000 N-Channel 200ma MOSFET (2N7000FS-ND) 1 Q2 BS250P P-Channel 230ma MOSFET (BS250P-ND) 1 U1 PIC18F2550 (firmware) (PIC18F2550-I/SP-ND) 1 U2 PIC18F1320 (Tutor) (PIC18F1320-I/P-ND) 1 Y1 20MHz Crystal (631-111-ND) Switches 3 SW1,2,3 Pushbutton (450-1131-ND) 2 SW4,5 Small pushbutton (450-1173-ND ***Discontinued Part***) 1 SW6 DIP Switch 8 position (GH7176-ND) Connectors 1 CON1 RA USB B connector 1 CON2 ICD 2x5 PCB Male ICD2 (MHC10K-ND) 1 CON4 3pin machine socket RA3,RA4,GND 1 CON7 3pin header RB3,+5V,GND 1 CON8 8pin Molex connector +5V,RA1,RA2,RA3,RA4,RB1/TX,RB4/RX,GND 1 CON6 16pin header for 18F2550 (pins 11 thru 16 are PICkit2 compatible) (RE5,U5V,GND,RB7,RB6,RB1,RB0,RC7,RC6,RC2,VPP,+5V,GND,PGD,PGC,AUX) 1 SOCKET IC Socket 28POS (ED3328-ND) 1 SOCKET IC Socket 18POS (ED3318-ND) Miscellaneous 1 FB1 Ferrite Bead 1 L1 680uH inductor (M8047-ND) Optional Accessories 1 Enclosure Polyview LAB-EASY BT-04 Last edited by futz; 13th November 2007 at 03:32 AM. |
Thanks for pointing out Y1 was not in the BOM. |
I will use futz's (love that name) work to improve the Octopart list.
It is a bit awkard but they are working on improving the interface to allow us to sort/order the parts and do parameteric searches. If all goes well one should be able to generate an order for parts using one or more vendors from the Octopart interface. Last edited by 3v0; 13th November 2007 at 12:12 AM. |
futz f&ts v.i. To tinker experimentally; to change something just to see what it does. |
Mike. P.S. I'm going to populate my board tomorrow but I'm having the same problem of getting a p channel fet. Looks like I'll have to take a trip into the city. |
3v0 helped me out a ton today!
He helped me program the 18F1320 to just blink port RB2. He then taught me about the port bits and how to use them. I then kept experimenting with them, changing the timing, and then I ended up with a Binary counter! It counts all the way up to 9, then goes back to 0. I was wondering how I add more bits and ports, such as making the timing go past 9. I couldn't figure this out, and I know you know. Thanks I LOVE MICROCONTROLLERS! THERE I SAID IT! |
Impressive, you'll have to post some code.
The 18F1320 is an advanced 8bit PIC, I actually enjoy using them over the 16F chips. The original Junebug design was going to use another 16F88 but since you can still use the Firefly Tutor I chose to use the 18F1320 on Junebug. *the 18F1320 shows its age by having an open collector RA4* Very little bank switching, the LAT instruction, a proper subtract instruction, compare instructions, PUSH, POP, tables, free C compiler. The only drawback is you might not want to work with the 12bit or 14bit cores. Not officially announced but I'm testing a simple hardware mod to the Inchworm+ design for 3.3V programming. Basically changed the 330 ohm resistors to 2.4K on the PGC & PFD lines, remove the VDD switch and BS250 (will not power the target) and dropping VPP to 10V (jumper to VPP switch) Last edited by blueroomelectronics; 13th November 2007 at 04:14 AM. |
HEX! That was my problem.
Here is the code. The bottom portion was what I did: Code:
#include <p18f1320.h>
#include <delays.h>
#include <stdio.h>
#include <stdlib.h>
#pragma config WDT = OFF
#pragma config OSC = INTIO2
#pragma config LVP = OFF
#pragma config PWRT = ON
// define TESTS
#define byte unsigned char
#define int8 unsigned char
#define CMD 0x00
#define DATA 0x01
#define READ 0x01
#define WRITE 0x00
#define TRIS_ACT_LED TRISBbits.TRISB2
// TRISAbits.TRISA2
#define ACT_LED LATBbits.LATB2
// LATAbits.LATA2
void delay_10us(unsigned char t);
void delay_ms(long t);
void delay_10us(byte t)
int i;
for (i=0;i<t;i++)
Delay10TCYx(5);
void delay_ms(long t) // delays t millisecs
do
delay_10us(99); // not 100 to compensate for overhead
} while(--t);
void delay_us(long us)
long x = (us%1000)/10;
delay_ms(us/1000);
delay_10us(x);
void main (void)
int flip = 0;
long i,j;
// Set direction registers
//TRISA= 0x00;
//TRISB= 0x00;
TRIS_ACT_LED = 0; TRISA=0x00; TRISB=0x00;
//LAT0xA=0x00;
//LATB=0x00;
while (1)
//ACT_LED = 0;
//LATA= 0x00;
LATB= 0x01;
delay_ms(1);
//ACT_LED = 1;
//LATA= 0xFF;
LATB= 0x02;
delay_ms(1);
LATB= 0x03;
delay_ms(1);
LATB= 0x04;
delay_ms(1);
LATB= 0x05;
delay_ms(1);
LATB= 0x06;
delay_ms(1);
LATB= 0x07;
delay_ms(1);
LATB= 0x08;
delay_ms(1);
LATB= 0x09;
delay_ms(1);
LATB= 0x00;
delay_ms(1);
Jaw drop, are you the real Krumlink? in C wow. Which C did you use?
You should have no problem with the LED mux on Junebug. It's the same type of mux the PICkit 1 uses. Last edited by blueroomelectronics; 13th November 2007 at 04:18 AM. |
Krumlink is using MCC18 and an Inchworm+.
I provided a simple program that blinked the ACT_LED using while(1) { ACT_LED = 1; delay_ms(10); ACT_LED = 0; |
| Junebug kit ready, (PICkit2 & tutor) | blueroomelectronics | Micro Controllers | 37 | 28th October 2007 02:47 AM |
| Assembly? | Marks256 | Micro Controllers | 43 | 28th July 2006 03:44 PM |
| Assembly compiler | Thunderchild | Micro Controllers | 4 | 12th March 2006 01:25 PM |
| Learning Assembly Programming Language | Johnson777717 | Micro Controllers | 4 | 22nd March 2004 02:00 PM |
| Assembly Language Question | Jeggyman | General Electronics Chat | 6 | 30th January 2004 09:53 PM |
