Old 11th May 2008, 09:54 PM   (permalink)
LOL, just watch out for the BS250K.
Bill
Smart Kits build Smart People
Old 11th May 2008, 10:53 PM   (permalink)
Originally Posted by parts-man73
Thank you for verifying my suspicions. I'd hate to have it soldered together to find out it was the other way round.
I did that on a programmer I built recently. Got confused with the pinout differences between BS and 2N transistors. There were 4 transistors in the kit, a combination of proper 2N's and substituted BS's. I soldered every one backwards. Clipped em out (sort of one or two at a time as I found the problems) and replaced with new ones and still got 2 backwards. I was kicking myself by then ("Oh man! I've wrecked it!). Finally got them all the right way and it works perfect now.
So if you get one backwards it won't usually hurt anything. It's just the annoyance and time factor. You just have to clip off and throw away the backward transistor, carefully suck the solder and old wire out of the hole and install a new transistor. They're cheap!
futz is offline
Old 12th May 2008, 12:14 AM   (permalink)
The problem with the BS250 is the modified TO-92 case on some versions. I'm trying to source only the BS250K in the future (Goes in the same way as the 2N7000)
Hmm might be a fun project on the Junebug. Don't solder in the BS250 till the end and I wonder if I could make a tester for it using the three pin socket under the reset button...
(Preprogrammed 18F1320)
Bill
Old 12th May 2008, 03:22 AM   (permalink)
why not try to capture the pinout of various makes and publish a small png to indicate maker wise pinout (top view of course.)It might help many others instead of asking them to get only bs250K version?
Regards,
Sarma.
mvs sarma is online now
Old 12th May 2008, 04:17 AM   (permalink)
I did I've drawn them up in the current Junebug Assembly Manual.
Bill
Old 12th May 2008, 05:09 PM   (permalink)
Wow, Thanks Bill. In fact I am yet to see the new manual, Sir.
Regards,
Sarma.
Old 12th May 2008, 11:14 PM   (permalink)
It's free for the download, I update it whenever I have the time.
Bill
Old 18th May 2008, 03:19 AM   (permalink)
Success! I finally got a chance to sit down with my soldering iron (busy time of year with kids in sports) I have to commend you Bill, this is a nice kit! The documentation was easy to follow and it worked immediately when plugged into my USB port, MPLAB recognized it and I was able to program the onboard 18F1320.
I attached a photo of my completed Junebug.
Time to play!
Brian
parts-man73 is offline
Junebug kit ready, (PICkit2 & tutor) blueroomelectronics Micro Controllers 37 28th October 2007 02:47 AM
Assembly? Marks256 Micro Controllers 43 28th July 2006 03:44 PM
Assembly compiler Thunderchild Micro Controllers 4 12th March 2006 01:25 PM
Learning Assembly Programming Language Johnson777717 Micro Controllers 4 22nd March 2004 02:00 PM
Assembly Language Question Jeggyman General Electronics Chat 6 30th January 2004 09:53 PM
