Old 1st February 2008, 07:23 PM   (permalink)
I was able to isolate LED1 by changing the module on swordfish. When I did the same to isolate LED2, it again lights 3 and 5 instead of 2.
thekyguy11 is offline
Old 1st February 2008, 07:27 PM   (permalink)
These will determine the I/O on powerup, if they're not there the I/O could get wonky on the Junebugs Tutor. Try out the debugger and post your code.
CONFIG OSC = INTIO2
ADCON1 = %11110101
Bill
Smart Kits build Smart People
Old 1st February 2008, 11:56 PM   (permalink)
I changed the module in swordfish like this...
* Name : JUNEBUG.BAS *
* Author : William Richardson *
* Notice : Copyright (c) 2008 blueroomelectronics *
* : All Rights Reserved *
* Date : 2/1/2008 *
* Version : 0.91beta *
* Notes : *
Module Junebug
Device = 18F1320
Public Sub LED(x As Byte)
Select x
Case 2 // LED 2
TRISA.0 = 0
TRISA.6 = 0
TRISA.7 = 1
Low (PORTA.0)
High(PORTA.6)
Else // All LEDs Off
TRISA.0 = 1
TRISA.6 = 1
TRISA.7 = 1
End Select
End Sub
Config OSC = INTIO2, WDT = OFF, LVP = OFF
ADCON1 = %11110101
OSCCON = $62 // 4 MHz clock
to isolate LED2. With this code, instead of LED2 blinking, 3 and 5 do. I tried isolating it with MPLAB and was able to do so with the breakpoints, but I can't get any changes to work...
And I can't seem to get that last config code that you suggested to work without getting an error.
Old 2nd February 2008, 12:05 AM   (permalink)
Ahh got it, LED 2 is dead or not connected or in backwards, this would allow current to flow through LEDs 3&5 when LED2 is supposed to be on. I take it it's never lit up. If it has then it sounds like it's in backwards.
Bill
Old 2nd February 2008, 12:09 AM   (permalink)
ah ha! I knew it wasn't code related, LOL. This may be easy stuff for you, but the fact that I was able to do what I did makes me feel like a genius! 'twas such a great learning process!
I'll test the LED and let you know what I find. It's definitely not in backwards, unless they flattened the wrong side.
Old 2nd February 2008, 12:29 AM   (permalink)
Can I replace it with this one? http://www.radioshack.com/product/in...t&tab=features
Old 2nd February 2008, 12:37 AM   (permalink)
Originally Posted by thekyguy11
Oh!!! Brutal price! Ya, that'll do.
I bought 200 LEDs for that price. Nice markup, Radio Shack!
futz is online now
Old 2nd February 2008, 01:05 AM   (permalink)
Just email me with your mailing address I'll put one in the post. They are 5mm Red around 800mcd.
Hard to burn out an LED but a dud can sneak in there.
The radio shack one will work fine.
Bill
Old 2nd February 2008, 08:59 AM   (permalink)
Junebug from Hyderabad, India-- is HERE. I did make some changes in the 10pin connector type. it is a right angle type. Ipropose to put a pindetails as a sticker on top of it.
Thanks to Bill who readily agreed to send ,not only bare board, but the crtical resistor packs also, across the Globe.
Regards,
Sarma.
mvs sarma is offline
Old 3rd February 2008, 01:49 PM   (permalink)
OH! it is from an international supplier may be from China. I too got 7 atleast in a batch of 25.Some were showing break even-- I don't know whether to to call them Dumpers or call the landing country unlucky.
Rather unfortunate.
Regards,
Sarma.
Old 3rd February 2008, 02:57 PM   (permalink)
That's been a frequent issue with LEDs I've recently received! The wrong side of the package was flattened; however, the longest lead is the anode, exactly as one would expect.
eng1 is offline
Old 3rd February 2008, 03:08 PM   (permalink)
Just a thought, since the Junebugs display is charlieplexed the LED should have turned on at one point with the blinky demo even if it was in backwards. So it's either a cold solder joint, broken trace or dead LED.
Bill
Old 5th February 2008, 04:42 AM   (permalink)
Just thought I'd report that I finally got the Junebug working 100%! Couldn't have done it without everyone's help. Must've all been caused by a dud LED, then things got complicated when I removed the bad LED, but I got it all fixed and cleaned up now.
Next step: Learn how to write code!
Old 5th February 2008, 03:42 PM   (permalink)
For LED's, as a safe check I look inside the die to check the cathode and anode (cathode is the larger side)
Krumlink is offline
Old 6th February 2008, 04:12 AM   (permalink)
I test light the LED with a battery and resistor and if needed cut one lead short to maintain the accepted standard and thereafter follow lead length and don't look at flat surface.
Regards,
Sarma.
Junebug kit ready, (PICkit2 & tutor) blueroomelectronics Micro Controllers 37 28th October 2007 02:47 AM
Assembly? Marks256 Micro Controllers 43 28th July 2006 03:44 PM
Assembly compiler Thunderchild Micro Controllers 4 12th March 2006 01:25 PM
Learning Assembly Programming Language Johnson777717 Micro Controllers 4 22nd March 2004 02:00 PM
Assembly Language Question Jeggyman General Electronics Chat 6 30th January 2004 09:53 PM
