Hi all, I am new to electronics and micro pic's but have been playing around for the last few months and got a lcd working as i want it too, my problem is that i wanna make a project that i need alot of I/O from my 16f876a so i was wounding if it was possible to use spi on the pic to a 8 bit latch (74hc595n) to drive the lcd if i changed my code. I came across the 74hc595n when looking at other peoples projects and falt it mite work as i wanna use spi for something else on the project to. thanks for any help, sorry if this is a stupid question. | |
Well it's a circuit from Myke Predko not a true SPI device but just toggle the bits on any standard I/O pins. http://www.myke.com/lcd.htm | |
You could also use a slave PIC just to feed the LCD, and a single pin to transfer the data over a serial link - you can even buy serial LCD's that are just that.
use 74138 decoder if using that port some where else too and 8255 PPI. simpler and effective. can find alot of help around. best of luck | |
I'm working on a 1-pin serial interface concept that uses an 8-pin PIC but it's probably a long way from working, tested, and finished. Good luck. Mike | |
| | #6 | |
An 8255 is a pretty naff PIO chip anyway, and completely unsuitable for connecting to a PIC, which already far out performs it. Likewise, what has a 74138 got to do with it?, these are suggestions for an old Z80 system. | ||
| | #7 |
Mike, I saw this concept earlier, but I didn't have time to study the code and concept. If I read you correctly, 1. You are running an LCD that requires a minimum of six I/O pins with a PIC that only has six I/O pins. 2. GP3 is both the RS control and serial input. 3. You raise the E line to write to the LCD, which is normal. 4. You prefer MS Excel Pink for your color background. Explain the RS function more. I'm also confused by the data lines to the host PIC, that appear to by a parallel, 4 bit, input | |
| | #8 |
Hi jay543_uk, Check page 5-69 of attached pdf. LCD connected on PCF8574 I²C I/O expander to µC (ok it's a 8051 but principle is the same). If later on you need other functionalities, just "plug" them on the I²C bus | |
| | #9 |
Sorry dude you are right Infact i am a newbie and working with MCS 51 family only. no idea of PIC controllers. As far as 74138 is concerned i suggested it because (although i have written) if he wants to use the same port for other purpose then he could select the devices through it. thanx for my correction | |
| | #10 | |
1) Yes, I'm driving an LCD that requires 6 signals minimum from a PIC with only 5 outputs 2) Yes, the serial signal on GP3 provides the LCD with the 'RS' register select signal during the 'E' pulse. 3) Yes, qualified by the CX bit (b6) which when CX=1 doesn't produce the 'E' pulse and so doesn't write the LCD 4) Yes, pink is "in" (grin) The LCD 'RS' register select pin is used to select 'command' or 'data' LCD registers during an LCD write operation. This LCD interface design requires the Host to send each byte of data as two serial bytes which contain nybble data in b3:b0 and the 'RS' register select bit in b7; send '0000 nnnn' to write nybble 'nnnn' to LCD RS0 (LCD command register) send '1000 nnnn' to write nybble 'nnnn' to LCD RS1 (LCD data register) This means we need a small (12 word) low-level driver on the Host to send each byte as two serial nybble+rs bytes to the LCD interface; Code: ;******************************************************************
; Host low level LCD interface driver
PutCmd
clrf mask ; mask = '00000000' (RS=0) |B0
skpz ; |B0
PutDat
bsf mask,7 ; mask = '10000000' (RS=1) |B0
movwf Temp ; save data |B0
call PutNyb ; send right nybble + RS bit |B0
swapf Temp,W ; send left nybble + RS bit |B0
PutNyb
andlw 0x0F ; mask off left nybble |B0
iorwf mask,W ; copy RS bit into WREG bit 7 |B0
PutSer
btfss PIR1,TXIF ; UART transmit buffer empty? |B0
goto PutSer ; no, branch and wait, else |B0
movwf TXREG ; send it |B0
return ; |B0
Code: radix dec
; Host program example macro usage
Line1 equ 128 ;
Line2 equ 128+64 ;
Line3 equ 128+20 ;
Line4 equ 128+64+20 ;
PutLCD cmd,0x20 ; setup 4 bit interface
PutLCD cmd,0x0C ; display on, cursor off
PutLCD cmd,Line1+10 ; lcd line 1, htab 10
PutLCD str,"GMT" ;
PutLCD cmd,Line2+10 ; lcd line 2, htab 10
PutLCD dat,'?' ;
PutLCD cmd,0x10 ; cursor shift left
PutLCD cmd,0x0F ; cursor on (blink)
Code: ;--< macro definitions >-------------------------------------------
cmd equ 1 ; single byte command/control type
dat equ 2 ; single byte character/data type
str equ 3 ; multi-byte string character type
PutLCD macro ptype,pdata
if ptype == cmd ; generates 2 words
movlw pdata ;
call PutCmd ; send with RS=0
endif
if ptype == dat ; generates 2 words
movlw pdata ;
call PutDat ; send with RS=1
endif
if ptype == str ; generates 6 words + inline table
local string,done
movlw low(string) ;
movwf PtrL ;
movlw high(string) ;
movwf PtrH ;
call PutStr ;
goto done ;
string dt pdata,0 ; inline table, 0 terminated
done
endif
endm
send '0100 1110' to set column 0 active low send '0100 1101' to set column 1 active low send '0100 1011' to set column 2 active low send '0100 0111' to set column 3 active low You would need one Host switch input pin for every four switches or jumpers installed on the LCD interface board. I use interrupt-on-change to detect the start bit leading edge and trigger the (untested) ISR on the LCD interface PIC; Code: ;******************************************************************
;* Interrupt Vector *
org 0x0004
b0 uDelay (bTime/3) ; delay 1/3 bit time |B0
uDelay (bTime-3) ; delay bit time - 3 cycles |B0
bcf D4 ; clr LCD 'D4' pin (GP0) |B0
btfsc SerPin ; bit '0'? yes, skip, else |B0
bsf D4 ; set LCD 'D4' pin |B0
b1 uDelay (bTime-3) ; |B0
bcf D5 ; clr LCD 'D5' pin (GP1) |B0
bsf D5 ; set LCD 'D5' pin |B0
b2 uDelay (bTime-3) ; |B0
bcf D6 ; clr LCD 'D6' pin (GP2) |B0
bsf D6 ; set LCD 'D6' pin |B0
b3 uDelay (bTime-3) ; |B0
bcf D7 ; clr LCD 'D7' pin (GP4) |B0
bsf D7 ; set LCD 'D7' pin |B0
b4 uDelay (bTime) ; ignore bit 4 |B0
b5 uDelay (bTime) ; ignore bit 5 |B0
b6 uDelay (bTime-3) ; test CX bit (lcd or non-lcd) |B0
clrf Emask ; assume non-lcd latch byte |B0
btfss SerPin ; bit '1'? yes, skip, else |B0
bsf Emask,5 ; setup 'E' pulse bit |B0
b7 uDelay (bTime-3) ; pulse 'E' during 'RS' data bit |B0
movf Emask,W ; get mask 00000000 or 00100000 |B0
iorwf GPIO,F ; pulse 'E' (or not) |B0
xorwf GPIO,F ; force 'E' pin low |B0
st uDelay (bTime-3) ; within middle 1/3 of stop bit |B0
movf GPIO,W ; read GPIO port |B0
bcf INTCON,RAIF ; clr IOC interrupt flag bit |B0
retfie ; |B0
| | #11 |
I must be missing something with this circuit. How do you shift a 1 bit into the 174 without writing random data to the display? ![]() Mike. Edit, got it, you have to shift in all zeroes between nibbles. Last edited by Pommie; 7th November 2007 at 02:50 AM. | |
| | #12 |
The code is on Mykes site. I personally don't like glue chips anyway. | |
| | #13 | |
Mike | ||
| lcd |
| PIC to LCD wiring problem ? | pasanlaksiri | Micro Controllers | 28 | 4th October 2007 11:29 AM |
| PIC16F628A LCD problems. | HerbertMunch | Micro Controllers | 17 | 2nd October 2007 10:20 AM |
| Newbie needs help with LCD backlight dimming | Mongoose | General Electronics Chat | 6 | 22nd September 2007 12:23 AM |
| Nokia 7110 LCD + questions regarding code and behaviour of LCD. | MrNobody | Micro Controllers | 2 | 19th September 2007 08:50 AM |
| LCD Troubles | Kyle-s4h | Micro Controllers | 13 | 11th September 2007 01:30 PM |
