Old 2nd November 2007, 02:48 PM   (permalink)
Default Lcd Display Help
I can diplay characters on lcd a,b c,d,... by using commands
mov A,#'A'
acall ,display
in 89c2051
but i can't diplay the contents of "timer register" time captured by an event event in decimal.
is any conversion required?
adnan012 is offline
Old 2nd November 2007, 02:52 PM   (permalink)
mov A,#'A'
acall ,display
in 89c2051
Yes, a binary to bcd/ascii conversion routine is required.
>> time captured by an event event in decimal. .....do you mean decimal?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 2nd November 2007, 02:56 PM   (permalink)
Hmm if I understand your problem, you have an alphanumeric 'character' LCD display. This uses ascii characters.
The 'value' for your timer....you say 'decimal', but really whether its binary, decimal or hex depends on how you display it
What you need to do is convert the 'single' number from your timer, into binary coded decimal. For example, say your timer value is '172', you must send 3 charaters to the LCD. '1', '7', and '2'.
After you have three bytes with the values 1,7 and 2...you must convert this to ASCII. From memory, I think you just have to add '30' (decimal) to the value.
Hope that helps, if not, explain your problem in more detail.
Blueteeth
Edit: Oh you're too quick for me eric...
Inconsistency is the key to flexibility!
Blueteeth is offline
Old 2nd November 2007, 03:03 PM   (permalink)
Default help
i am using 'jhd 162a' lcd
i want to display the pulse width "by an external source measured by the controller) on LCD.
I NEED THE COVERSION METHOD
adnan012 is offline
Old 2nd November 2007, 03:08 PM   (permalink)
Ok, so I assume your microcontroller has already measured the pulse width and has a value stored in a register? Doesthis value relate to a time-base in anyway? like 'ms' ?
The 'CONVERSION METHOD' you need is 'binary to decimal conversion'. Either 8 bit for a single byte (0-255) or 16 bit.
Google really is a wonderful thing. Just search for 'BCD' and your microcontrollers part number and I'm sure you will come up with something.
BT
Old 2nd November 2007, 03:14 PM   (permalink)
Whats the maximum value of the number you wish to convert fron binary to bcd/ascii? is it 8bits or 16bits?
[I have slowed down blueteeth, let you play catch up ]
Eric
PIC tutorials:
Old 2nd November 2007, 03:22 PM   (permalink)
Default Help
My Controller May Contain From 03e8 (1000) To 07d0(2000)
adnan012 is offline
Old 2nd November 2007, 03:23 PM   (permalink)
From 1000 Micro Seconds To 2000 Micro Seconds 16-bit
adnan012 is offline
Old 2nd November 2007, 03:27 PM   (permalink)
My Controller May Contain From 03e8 (1000) To 07d0(07d0)
In that case you require a 16bit binary conversion, which will give 5 bcd digits, just drop the MSD and the add 0x30 to the bcd digits to form the ascii characters.
As suggested there are lots of 16bit routines on the web,, if you get a problem come back.
Eric
PIC tutorials:
Old 2nd November 2007, 03:32 PM   (permalink)
Thanks A Lot
adnan012 is offline
Old 2nd November 2007, 03:39 PM   (permalink)
IS THIS CODE WILL WORK FOR ME
http://www.8052.com/codelib/bintoasc.asm
adnan012 is offline
Old 2nd November 2007, 04:06 PM   (permalink)
From the description, its what you need. I dont use the 80xx series of MCU's
>>> Purpose: Routine to convert a 16bit binary number in ASCII
Eric
PIC tutorials:
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
Is this display burned out? (Sony MD LCD Display) Amphr_Moth General Electronics Chat 4 28th October 2007 07:47 PM
calculator chinmay7 Micro Controllers 1 14th October 2007 01:45 PM
PIC16F628A LCD problems. HerbertMunch Micro Controllers 17 2nd October 2007 10:20 AM
LCD Troubles Kyle-s4h Micro Controllers 13 11th September 2007 01:30 PM
