| In JDM programmers the two transistors they used BC547 in mostly. I made the same circuit with 2N2222 transistor but it didn’t work. But the programming software detects the programmer. But I cannot read the PIC & program the PIC. | |
| Do you have a 'scope so that you can check what is happening ? Perhaps you have the 2N2222 in the wrong way around. | |
| oops I don't have a scope. I have checked twice the base collector & emitter of 2N2222 & they seems to be ok. I haven't see a programmer that build with 2N2222 all JDM types using BC547. I want to clarify whats the different between them. Our town is far away until I go there I have to bare with this 2N 2222. | |
| All it requires is a general purpose silicon transistor of the correct polarity, pretty well anything will work, it's only used as a simple switch. As suggested, you may be connectng it the wrong way?. | |
| OK guys I'll take a look again & tell where is wrong.Thanks for your ideas. | |
| The suggestion is not, i fear, for connecting in wrong way please--(in lighter sense) the author FENG himself was clarifying at his site how not to connect.
| Hi I replaced my 2N2222 to BC 547 & it worked for 84A & 628A through ICSP connector. But when I try to program 877A it won't program through ICSP connector. Note: I didn't use the PGM pin only using the standard 5 pins that is Vdd, Vss, PGD, PGC, MCLR Also in 877A has two VDD & two VSS pins each.I use only one VDD & one VSS. I'm using ICPROG 1.05 & winpic. | |
| An optoisolator replacement for 2n2222 | William At MyBlueRoom | General Electronics Chat | 2 | 14th May 2006 05:51 AM |
| is the pn2222 transistor the same as a 2n2222 transistor? | colin886 | Datasheet/Parts Requests | 2 | 6th January 2006 06:41 AM |
| Help needed - transistors not working | Jackboy | Electronic Projects Design/Ideas/Reviews | 5 | 26th February 2004 07:50 AM |
