| Can anyone suggest what is the best programmer for PIC16F877? I am not good in prgramming that's why I am looking for a software that has similar language with visual C++. I am kinda new with microcontrollers and I wanted to use this PIC as an ADC with 3 inputs. Also, can i get the software for free? Thank You very much!!! | |
| I would suggest an ICD2 clone, like the Inchworm or Inchworm+ (search on here for them). C++ and Visual languages don't really have any place with microcontrollers, and C compilers are expensive - although most provide limited demo versions. Assembler is free though, and my tutorials show pretty well what you want. If you want to use C, I would suggest moving to the higher spec 18F series, where they provide a free C compiler, although if you pay for it you get better optimisation. | |
| There is also the free HiTech C compiler for the 16F series pics. Mike. | |
| <==== Raising hand to vouch for PICKit2 programmer. | |
| A good programmer supports majority of PICS & DEBUGGING features & some are programming voltages controllable & full support from the external power supply. Before I build a good PIC programmer this is what I had in the first time. It’s called micro JDM programmer. Only take 5 mins to build. For 877 it worked fine. It depends upon the serial port voltages & also note that in some laptops it won’t work but in most desktop PC’s it worked. http://www.semis.demon.co.uk/uJDM/uJDMmain.htm | |
| What is the best programmer for pic16f877a. i need a circuit diagram. | |
http://www.hamradioindia.org/circuits/feng.php http://www.semis.demon.co.uk/uJDM/uJDMmain.htm Those are simple programmers but very easy to build. On my site are two more advanced programmer / debuggers for the PIC. As Nigel mentioned one is the Inchworm which is an ICD2 compatible and RS232 based and the new one Junebug is a USB based PICkit 2 compatible. Both support MPLAB (Microchips all in one development environment). The "catch" is you need a preprogrammed PIC to use either of them. The dirt simple programmer from Lothar Stolz's site could be used to get the firmware loaded initially. ![]() Last edited by blueroomelectronics; 30th October 2007 at 02:26 PM. | ||
| thank u!!!!!!!! | |
| I need to know the pin configuration in pic 16f877 in 16f84a programmer......... | |
| I looked at the JDM programmer and it will only work with RS232 ports with at least a +/- 12V swing. This is only common on PCs with internal RS232 ports. This is a HVP programmer design, the Stolz simple version is a LVP design, not all PICs support LVP and it has limited usefulness. Last edited by blueroomelectronics; 30th October 2007 at 02:41 PM. | |
| I mean .. this circuit for Pic16f84a ......... so what are the pins which are used in pic 16f877 in this circuit? | |
| Need help with Intel Assembly Language and PIC16F877 | avinsinanan | Micro Controllers | 10 | 4th March 2008 11:02 AM |
| Need help on ADXRS150EB with PIC16F877 | bahreen | Electronic Projects Design/Ideas/Reviews | 7 | 3rd December 2007 05:16 PM |
| Line Detection Robot using PIC16F877 | helmyshahryl | Micro Controllers | 0 | 28th August 2007 02:54 AM |
| some newbie's questions concerning pic16f877.. | kimhsieh2 | Micro Controllers | 4 | 12th January 2004 11:53 PM |
| Help in programming PIC16F877..... | Azhar Ali chohan | Micro Controllers | 3 | 24th June 2003 12:08 PM |
