Old 18th September 2003, 07:26 PM   #1
Default DS1820 slave, 16F877 master, picbasic pro, any info?
Hello everyone, I have recently purchased a LAB-X1 (formerly called the PIC-X1) experimenters board. I have one DS1820 Digital Thermometer chip up and running on the LABX1 to read the DS1820 1-wire temperature sensor and display the temperature on the LCD. It works fine but now I would like to add some code to have it function as a thermostat to control a relay. I have read the data sheet for the DS1820 and can not make any sense of it at all. I'm a hobbyist and learning from example seems to be the best way for me. Is there any sample code posted on the net anywhere that shows how to do that? I'm using the picbasic pro compiler with an epic programmer and I'm using the 16F877 micro. Can anyone help me out here or point me in the right direction? Thanks...................jessey
jessey is offline
Old 18th September 2003, 08:33 PM   #2
Find rentron.com there I saw some codes regarding one wire temp sensor some times ago.
hope this helps
SuRgE
Definition of Time :
It Is Just What A Clock Reads
By Albert Einstine
Surge is offline
Old 19th September 2003, 08:43 AM   #3
Here is a code lisiting of a macro which I insert if I want to use a DS1821 thermostat. I had last used it on a PIC16F877 and it seems to work quite well. The variables TEMP_HIGH and TEMP_LOW are the high and low settings of the thermostat in degrees C. MODESEL is a multi-pupose file register I use to store flag bits, one of which is the PR_DET (presence detect flag).
The code initializes the DS1821 by lowering the VDD pin and apllying 16 pulses to the DQ pin. This transforms the DS1821 to one-wire protocol mode. The thermostat values are loaded and then the DS1821 is converted back to thermostat mode.
INIT_DS1821 MACRO
         LOCAL    INIT_START,INIT_END,INIT_LOOP
         CALL     ONE_WIRE_ENABLE
INIT_START:
         CALL     ONE_WIRE_RESET
         BTFSS    MODESEL,PR_DET
         GOTO     INIT_END
         MOVLW    H'01'
         MOVWF    SHFT_BYT
         CALL     ONE_WIRE_TX_BYTE
         MOVLW    TEMP_HIGH
         MOVWF    SHFT_BYT
         CALL     ONE_WIRE_RESET
         GOTO     INIT_END
         MOVLW    H'02'
         MOVWF    SHFT_BYT
         MOVLW    TEMP_LOW
         MOVWF    SHFT_BYT
         CALL     ONE_WIRE_RESET
         GOTO     INIT_END
         MOVLW    H'0C'
         MOVWF    SHFT_BYT
         MOVLW    B'00000100'
         MOVWF    SHFT_BYT
         CLRF     TEMP1
         CLRF     TEMP2
INIT_LOOP:
         CLRWDT
         NOOP
         DECFSZ   TEMP1,F
         GOTO     INIT_LOOP
         DECFSZ   TEMP2,F
         GOTO     INIT_LOOP
         GOTO     INIT_END
ONE_WIRE_ENABLE:
         BANKSEL  TRISA
         BCF      DQ_TRIS         ; 1 = i/p, 0 = o/p
         BCF      VDD_TRIS        ; 1 = i/p, 0 = o/p
         BANKSEL  PORTA
         NOOP
         BSF      DQ_PORT
         NOOP
         NOOP
         BCF      VDD_PORT
         CLRF     TEMP1
ENABLE_LOOP1:
         CLRWDT
         DECFSZ   TEMP1,F
         GOTO     ENABLE_LOOP1
         MOVLW    D'16'
         MOVWF    TEMP1
ENABLE_LOOP2:
         NOOP
         NOOP
         BCF      DQ_PORT
         CLRWDT
         NOOP
         NOOP
         BSF      DQ_PORT
         DECFSZ   TEMP1,F
         GOTO     ENABLE_LOOP2
         NOOP
         NOOP
         NOOP
         NOOP
         BSF      VDD_PORT
ENABLE_LOOP3:
         CLRWDT
         DECFSZ   TEMP1,F
         GOTO     ENABLE_LOOP3
         RETURN
ONE_WIRE_RESET:
         BSF      VDD_PORT
         MOVLW    3
         MOVWF    TEMP2
         CLRF     TEMP1
         BANKSEL  TRISA
         BANKSEL  PORTA
         BCF      DQ_PORT
RESET_LOOP1:
         CLRWDT
         DECFSZ   TEMP1,F
         GOTO     RESET_LOOP1
         DECFSZ   TEMP2,F
         GOTO     RESET_LOOP1
         BANKSEL  TRISA
         BSF      DQ_TRIS         ; 1 = i/p, 0 = o/p
         BANKSEL  PORTA
         BCF      MODESEL,PR_DET
RESET_LOOP2:
         BTFSC    PR_PORT
         GOTO     CHK_PRESENCE
         CLRWDT
         DECFSZ   TEMP1,F
         GOTO     RESET_LOOP2
         RETURN
CHK_PRESENCE:
         MOVLW    8
         MOVWF    TEMP2
         CLRF     TEMP1
RESET_LOOP3:
         BTFSS    PR_PORT
         BSF      MODESEL,PR_DET
         CLRWDT
         DECFSZ   TEMP1,F
         GOTO     RESET_LOOP3
         DECFSZ   TEMP2,F
         GOTO     RESET_LOOP3
         RETURN
SLOT_1:
         MOVLW    D'8'
         MOVWF    TEMP1
         MOVLW    D'90'
         MOVWF    TEMP2
         GOTO     SLOT_TIME
SLOT_0:
         MOVLW    D'90'
         MOVWF    TEMP1
         MOVLW    D'8'
         MOVWF    TEMP2
         GOTO     SLOT_TIME
SLOT_TIME:
         BCF      DQ_PORT
SLOT_LOW:
         NOOP
         DECFSZ   TEMP1,F
         GOTO     SLOT_LOW
         BSF      DQ_PORT
SLOT_HIGH:
         NOOP
         DECFSZ   TEMP2,F
         GOTO     SLOT_HIGH
         RETURN
ONE_WIRE_TX_BYTE:
         BANKSEL  TRISA
         BANKSEL  PORTA
         MOVLW    8
         MOVWF    SHFT_CNT
ONE_WIRE_TX_BYTE2:
         BTFSS    SHFT_BYT,0
         CALL     SLOT_0
         BTFSC    SHFT_BYT,0
         CALL     SLOT_1
         RRF      SHFT_BYT,F
         DECFSZ   SHFT_CNT,F
         GOTO     ONE_WIRE_TX_BYTE2
         RETURN
INIT_END:
         BSF      DQ_PORT
         BSF      VDD_PORT
         BANKSEL  TRISA
         BANKSEL  PORTA
         ENDM
motion is offline
Old 23rd September 2003, 05:01 PM   #4
I found this russian website that accomplishes what you need using PicBasic Pro.
http://www.elin.ru/1-Wire/08.htm
Attached is what I had obtained from the site:
motion is offline
Old 25th September 2003, 06:27 AM   #5
Thanks Motion, I looked at the file you found on the Russian site and it is exactly the same program that came in the example code that was provided with the LABX 1 experimenters board's software that I purchased. This code does nothing more than to display the temperature on the LCD. What I'm looking for is an example code that would use one of the pins of the 16F877 as an output that would turn on and off a heater. Some code that will show me how to change the TH and the TL settings, if that's what sets the temperature for the heater to turn on and off at. I don't understand the data sheet and need to see working code in order to begin to understand how to write the code and to change it for what I want. I'll keep looking and appreciate your help.
Also thanks for suggesting rentron.com Surge, I checked it out and the same thing there. They only show code to display the temperature as well.
Thanks..........jessey
jessey is offline
Old 25th September 2003, 08:21 AM   #6
If you are able to display the temp, I think it would be easy to compare the displayed temperature to a setpoint and set/clear an output pin on the PIC, wouldn't it?
There wouldn't be any need to to switch the DS1820 to thermostat mode. Just use the temperature, compare it to values stored in the PIC and set/clear an output pin.
motion is offline
