| I found this TV-B-Gone project I want to build, but the source is in C, an uses the GCC compiler. http://www.ladyada.net/make/tvbgone/download.html I don't know much about C, or how to use the compiler, but tried a few times to get it to build the hex file, but just get errors. So, basically have no idea what I'm doing. There are four files in the source ZIP. So far, I've only programmed in assembly, so haven't had to learn about C or BASIC compilers, so I need a quick walk through the process of making a hex file from C. Or if you are feeling generous, just compile the hex for me (although I should learn this stuff sometime). I'll have to order the Tiny85 (needs the 8k flash), and an 8 mhz crystal, so have about two weeks to get the program ready to burn. Also going to do my own PCB. Their's is in Eagle and two sided, also seems a little larger than needed. I want it a little smaller and descreet. I think the ISP header was the reason they went with a 2-sided board, it's an 8 pin chip, so a socket will be fine. The use 4 IR LEDs, but 2x60 degree should work just as well. | |
| I've never used the GCC compiler, I've only ever programmed AVR's in ASM, but I might be able to help if no one else can. What kind of errors are you getting?
| Ordered the parts from Digikey, should be here next week sometime. Got enough for 4 (usually gadgets like this attack the build-me-one people). I think I got the source complied, but won't be sure until I try to burn. I tried WinAVR, got a few errors (no idea what they mean, but didn't seem fatal). The hex file is 23k, which is huge compared to anything I've done before in assembly. The Tiny85 has 8k, so a little concerned if it'll fit. Don't know what all is in a hex file, thought it was straight binary program. Need to get some PCBs ready, shouldn't take long. | |
| You could also just hit printscreen and show a screen capture.
| I think it's okay. I loaded the hex file into AVR Studio, and it disassembled it. I couldn't simulate it, but the program looked like it might work. Have to read the docs someday. Can't rely on luck forever. Didn't even know you could disassemble a hex file. Did a PCB (well 4 actually), but think this last one will be the one to etch. Not real happy about running traces between pins, but not as much as doing a double-sided board... | |
| Did you try asking on the Atmel support forums with the hex file problem that you have? | |
Considering the price people pay for these gadgets, and the cost to build this one, seemed like something other people might build. There have been several threads in the past, asking about long-range TV gadgets. This one claims over 100 ft (30m). I didn't check the kit price, I have everything except the Tiny85 ($2.77) and resonator. | ||
| Files converted to ASM from raw binary are often horribly unreadable becaus ethe label register and variable names don't stick. With C programs some extra debug information can be stored but it's not usual.
| Well, got the PCB etched, drill, and stuffed this morning. Digikey and UPS expect delivery on monday. With any luck, UPS will leave the package at the door if I have to work late. Just need to solder in the resonator and program the chip. | |
| It works!!! Yeah, got a little carried away with the hot glue. Didn't have a case, a 2xAA battery holder. Thinking about doing another anyway. Going to loose the socket and lay the components flat, try a 3v lithium coin cell. Don't think the battery will last long, but think it'll be good enough to run through the codes a few times. Not sure about the range, but works the entire length of my house. Sitting in the same room, don't even need to point at the TV. Pretty cool gadget for having to buy maybe $5 worth of parts. | |
| nice job minus the glue hehe | |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Development tools for ARM7 | Halo | Micro Controllers | 2 | 12th April 2007 09:50 PM |
| Regarding the CCS Compiler | 3v0 | Micro Controllers | 5 | 24th March 2007 10:22 PM |
| Help, CCS PIC-C Compiler... | Kenton | Micro Controllers | 17 | 3rd April 2006 12:48 AM |
| Atmel AVR free compiler and support free forum | mramos1 | Micro Controllers | 3 | 24th October 2005 09:00 AM |
