Old 27th October 2007, 02:43 AM   (permalink)
Default pulse generator
newbuddy here looking for a way to build a pulse generator to control a hydraulic cylinder . ineed to use a 10k pot to control the speed or( pulse ) to coil of the valve (output pluse max 33hz)
danno is offline
Old 27th October 2007, 01:19 PM   (permalink)
Please provide more information.
Screen name: Aloone_Jonez
Hero999 is online now
Old 27th October 2007, 04:07 PM   (permalink)
thanks hero999,
this unit source is 12vdc
could not find a 10k pot nor a coil in the SWcad 111 to draw and test the circuit . all though i can read circuits i've never tried to draw them
danno is offline
Old 27th October 2007, 04:21 PM   (permalink)
That still isn't enough information.
Current?
Duty cycle?
Ever thought of using an astable 555 timer?
Old 27th October 2007, 10:50 PM   (permalink)
I'll have to get back the coil i need ,it is at my brother house
thanks again Hero999
danno is offline
Old 28th October 2007, 09:46 AM   (permalink)
I suppose you have a proportional hydraulic valve.
That valve will be powered by a PWM circuit controlled by the 10k potmeter.
The faster the pulses out of the PWM, the faster the cylinder will go.
How is the direction of the cylinder controlled?
Do you have another valve for direction, or does the speed valve also control direction?
In other words how does the hydraulic circuit looks like?
From my maintenance experience I should tell you:
Buy existing electronic modules from a well-known factory e.g. Wandfluh.
mcs51mc is offline
Old 31st October 2007, 02:16 AM   (permalink)
It has two micro switches on the joystick to a foward and reverse valve.
this is where the 10k pot is located also
i called my brother , and he said the output volt read 8 vdc , his ampmeter only reads 0 to 20 amps and dose not read low enough
I'll have go out with my meter to check it
what i'm not is a typist
danno is offline
Old 31st October 2007, 08:49 PM   (permalink)
Don't get that
A valve is for me a hydraulic part, it can have one or two electric coils.
Can you make a sketch of both electric and hydraulic circuits, scan them and post them?
Please be a little more accurate when you describe something. Thanks for that
Better take a scoop with you
The power supply is 12Vdc right? You measure 8V over the coil. Or there is already a PWM involved somewhere or the pot meter divides the 12V power for the valves.
Back to the drawing board: What's the problem?
mcs51mc is offline
Old 31st October 2007, 11:07 PM   (permalink)
Draft2.asc
I hope i sent this right
danno is offline
5V pulse generator by using 12V DC supply? chrisliew Electronic Projects Design/Ideas/Reviews 1 13th July 2007 03:38 PM
pulse generator using NE564 hitwaterfish General Electronics Chat 13 25th March 2007 06:33 AM
Problem measuring pulse width - 12F683 TMR1, 8MHz jess Micro Controllers 18 5th February 2007 11:00 AM
Digital Pulse Generator and PIC Barry Micro Controllers 7 11th March 2004 07:58 PM
5V Pulse Generator Brocktune General Electronics Chat 3 4th November 2003 09:11 PM
