Old 23rd October 2007, 08:17 PM   (permalink)
Default 8051
hi guys, i m very new to microcontrollers..........i have been doin my research on 8051 for so long and finally i have got the rite project to put my hands on.......i have understood nearly everything abt 8051 except one small thing..............i m working on this stepper motor circuit....this circuit shows a programmer with 6 pins.............now what type of programmer cable ( plz if you could give me a link where in i can see the details of this programmer cable as well)and ISP software should i use there with 8051.......i would use be using keil microvision for the assembler program.....plz help
ps:this doubt arised because i had seen most programmer cable having 9 pins....neva heard of a 6 pin programmer
mohsinans is offline
Old 24th October 2007, 01:32 AM   (permalink)
Maybe give us a link to the circuit you are asking about, then perhaps we can guide you.
Brevor is offline
Old 24th October 2007, 12:30 PM   (permalink)
i have given the required info on the previous post........jus let me know what type of serial port connector do we genrally use for 8051.........i studied on a site that u need a 9 pin connector.....but the circuit that i have has 6 pins in the connector..........so is there any connector/ programmer that has 6 pins at one end or is the circuit wrong....plz help......
Old 24th October 2007, 12:46 PM   (permalink)
So what would be the point of posting a link to your hard drive?.
Old 24th October 2007, 12:52 PM   (permalink)
i m sorry my mistake........i had not saved the site...so cant load the link......but tell me what connector/controller cable do we need for a 8051........and its pin configuration and the pins of the 8051 that are to be attached to it
Old 24th October 2007, 01:02 PM   (permalink)
ok i read something abt a RS232 and DB9(9pins) and also abt DEC MMJ(6 pin)
now the circuit that i m using shows that few of the pins of 8051 go to a controller and the controller has 6 pins.......so does that mean that i buy a rs232db9 to DECMMJ connector and connect the decmmj pin to my microcontroller and rs232db9 end to my PC...........m i right?????
and by the way i have a rs232db9 to rs232db25 connector wire from an old modem.....is there any way to convert that rs232db25 end to an DECMMJ port so that i dont need to buy any thing
Old 24th October 2007, 01:19 PM   (permalink)
http://www.mytutorialcafe.com/Microc...089s51%202.htm
now take a look at this circuit.........
the header of 6 pins is supposed to be connected to the programmer.........now jus tell me what all componenets do i need for the those 6 pins to be connected to my PC. the same link tell me abt AT89s.........would connecting this 25 pin thing to my PC help me to program the 8051 directly or do i need something else also.........plz reply
Old 24th October 2007, 01:39 PM   (permalink)
Presumably you need a programmer?, the socket on the target obviously needs to match that on the programmer.
Old 25th October 2007, 03:32 AM   (permalink)
It is the link at the upper right of the page under programmer, it's called
the ISP 89s.
http://www.mytutorialcafe.com/Microc...er%2089S51.htm
Brevor is offline
Old 26th October 2007, 12:18 PM   (permalink)
if he's taking about a 6 pin ISP, maybe he's talking about the one on my site
http://ikalogic.com/isp.php
if you want to build a programmer this one is simpe, many visitors built it.. wait, wait, wait... i think i recall your name mohsinans.. you left me a mail before right?
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 26th October 2007, 09:27 PM   (permalink)
hey ibrahim....i luv you for clearing my doubts but tell me one thin.....the following link.....
also has a similar type of programmer but it shows that the end has to be connected to db 25 male.......how is that possible coz the parallel port in my PC has a male connector, so wudnt i need a female connector at the end of the wire..........
ans what abt ur circuit....does that also need a male connector at the end of the wire.......
and the IC that is show in the PICTURES of ur website connected to the db 25........which is that IC...would we need to remove that IC and place the 74ls08 there......plz clear these doubts....thank you
Old 26th October 2007, 10:08 PM   (permalink)
hey i asked a wrong doubt to you.....my PC has a female db 25.....but do clear my doubts abt that IC replacemment...thank you
hyperterminal communication w/ 8051 spyghost Micro Controllers 8 22nd May 2008 11:54 AM
8051 Microcontroller (Urgent Help) UAE_Engineer Micro Controllers 5 22nd March 2007 12:13 PM
Could I get away with this? (8051 + AM29F010B) mstechca Micro Controllers 0 9th March 2006 03:05 AM
interfacing 16*16 matrix display with 8051 pmphilip Micro Controllers 0 1st February 2005 04:47 AM
8051 "data" storage within program memory - how? L0D|Mr_B Micro Controllers 1 11th January 2004 03:56 PM
