Haw I write a rutine in MPASM to generate user defined charcters on a alfanumeric LCD, i find a similary example but is write in C++ and i dont undersant..nothing....Can you help me?
Perhaps you need these: http://winpicprog.co.uk/pic_tutorial3.htm http://winpicprog.co.uk/pic_tutorial_lcd_board.htm
Superman returns..
I read this tutorial, and he is not what i want
Purpose: - Load a user-defined character definition into the HD44780 character generator memory. Quick explanation on how to implement user-defined characters: First you will need to make a pixel definition for the characters you want to use. Below is the pixel definition for an underlined '0' (char code 0x30) based on a 5x7 dots character definition: | bits | byte row | 76543210 | value ------------------------ 000 | xxx | 0x0E 001 | x x | 0x11 010 | x xx | 0x13 011 | x x x | 0x15 100 | xx x | 0x19 101 | x x | 0x11 110 | xxx | 0x0E 111 | xxxxx | 0x1F |
:P Misunderstood.
I've never tried this, but is the datasheet of HD44780 helpful enough?
Superman returns..
i need a part of a code to understand how make this with mpasm
I think the datasheet states clear enough.
Set DDRAM address, CGRAM address and followed by CGRAM data.
Superman returns..
Read the EPE LCD articles mentioned on my site.
i dont understand very good, practicaly can you give me an concrete example?
this is the problem, idont known how to write this in mpasm
If you can't write anything, how do you expect to do anything at all with a PIC?.
http://www.electronics-lab.com/forum...?topic=12543.0
Superman returns..
Attached is a Oshonsoft Basic program and its asm listing output. You should be able to figure out how defined characters are created and used. Hope this helps. EDITED: its best to download the *.asm to view off line, else there is no formatting!
Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 11:22 AM. |
It goes like this,
MOVLW B'01000000' ;USER GRAPHIC 0 CALL COMMAND ;SENT TO LCD AS COMMAND MOVLW B'00000000' ;PIXEL DATA 1 OF 7 CALL DISPLAY ;SENT TO LCD AS DATA Then to actualy print the user graphic MOVLW .0 ;USER GRAPHIC POINTER CALL DISPLAY ;SENT TO LCD AS DATA |
| Lcd alfanumeric | ady689 | Micro Controllers | 3 | 3rd October 2007 01:27 AM |
| PIC16F628A LCD problems. | HerbertMunch | Micro Controllers | 17 | 2nd October 2007 09:19 AM |
| LCD Troubles | Kyle-s4h | Micro Controllers | 13 | 11th September 2007 12:30 PM |
| User defined Time period 16f628 | jagrolet | Micro Controllers | 4 | 5th September 2006 07:37 PM |
| An error in pic16f84a, why? | Zener_Diode | Micro Controllers | 6 | 11th April 2004 02:55 AM |
