Old 10th October 2007, 06:27 AM   #1
Default convert int to char dspic30f
Hi
The mplab c30 compiler does not support itoa() function.
how do I change a hex number ie 0x55 to become a char '55' without using the printf().
kenobe is offline
Old 10th October 2007, 07:59 AM   #2
There is probably some easier way but this gets the job done,
	intVal=0x34;
	charout[0]=(intVal>>4)+0x30;
	charout[1]=intVal&0x0f+0x30;
Pommie is offline
Old 10th October 2007, 08:23 AM   #3
Hi Pommie
Thanks for your help.
but what I need is charout[0] = 55 , not charout[0]=5, charout[1]=5
kenobe is offline
Old 10th October 2007, 08:46 AM   #4
Isnt't that just
charout=(char)intVal;
or even,
charout=intVal&0xff;
Pommie is offline
Old 10th October 2007, 09:28 AM   #5
I tried that too, but mplab c30 compiler does not work with casting and masking ,so it still does not solve the problem.
kenobe is offline
Old 10th October 2007, 03:21 PM   #6
I found this hard to believe and so, I just tried the following,
#include <p30f2010.h>
unsigned int x;
unsigned char outchar;
int main(void){
	x = 0x45;
	outchar=(char)x;
	x = 0x45;
	outchar=x&0xff;
	x = 0x45;
	outchar=x;
	while(1);
It did exactly what I expected it to do.
Maybe you should post an example of what doesn't work.
Pommie is offline
char, convert, dspic30f, int
c++ convert argv[1] to a char array danielsmusic Chit-Chat 5 18th March 2006 02:09 PM
revew code please Seb Micro Controllers 1 22nd February 2005 02:15 PM
I2C Master write problem using SSP (here's code) Oznog Micro Controllers 1 16th October 2004 06:48 AM
HOW TO CONVERT HEXA TO DECIMAL FOR LCD, PLS HELP!!!!!!!! AUNG THANT Micro Controllers 3 10th April 2004 01:38 PM
PIC 16f84A and PowerTip Alphanumeric display 27 Micro Controllers 1 9th March 2004 03:19 PM
