| I am starting to learn how to use the PIC16F818 and I would like to build a battery tester. I figured this would be a relatively easy project that I can use. Powering the PIC itself I understand. What I'm not sure will work is the A/D converter. The batteries I have to test have 9V when fully charged (Measured with Multimeter). However, from what I understand, only a maximum voltage can be applied to any of the PIC pins. I was planning on hooking up the test points to a voltage divider so if a fully charged 9V battery is tested, only 4.5V are applied to the A/D converter of the PIC. Then I would compensate for this difference of 4.5 from the reference voltage of 5V from within the code Then depending on the actually voltage of the test battery certain LEDs would light up. Would this be viable way of doing this circuit? I can attach a picture of the circuit I drew out if it would help. Any feedback would be appreciated. | |
| Yes, this is a viable way. Seems as if you got it all down. Just use a regulator be it external or internal as your reference. So my question is, why do you ask permission from others? 99.999% of everything I do in electronics is to "Find out". I have long since realized that my bread is dying out with an ever increasing rate. | |
| Battery Tester | pwollner | Electronic Projects Design/Ideas/Reviews | 2 | 17th February 2004 08:37 AM |
| 9v pp3 battery question | carlosthejackle2001 | General Electronics Chat | 3 | 14th February 2004 11:03 PM |
| Battery Capacity Load Tester | rjr10234 | Electronic Projects Design/Ideas/Reviews | 5 | 3rd January 2004 12:45 PM |
| Last question for NiMH battery charger | eyevancsu | Electronic Projects Design/Ideas/Reviews | 8 | 1st May 2003 04:04 AM |
| Question regarding MAX713,712 battery charger controller... | eyevancsu | General Electronics Chat | 3 | 23rd April 2003 10:02 PM |
