Old 8th October 2007, 11:53 AM   (permalink)
Default In build ADC
Hi
iam using In build ADC Atmega32 controller .
How to interface 0-10V signals to ADC input of the controller.
What ground I have to connect for sensor signal (-ve) either digital ground or
analog ground
What precautions I have to take while connecting analog signal to the micro
controllers(In build ADC ).
Regards
chandu
chandu13 is offline
Old 8th October 2007, 04:58 PM   (permalink)
If you use 5V for the Mega32 and as AREF too, then you have to use voltage divider on the ADC inputs to limit the max voltage on the input to be less than 5V at all time. If you use a fixed resistor and a variable resistor to ground as divider, then you can trim variable resistor to make the ADC gives 1000 counts when you inject a 10V DC signal. Your resolution is 10mV.
If the signal source is of high impedance, you will also need Opamp to buffer and scale the voltage down accordingly.
There is no analogue ground pin on the Mega32, just GND. You should connect the two ground pins to the input signal (-ve) and you cannot measure negative signal or non-ground referenced input.
L.Chung
eblc1388 is offline
Old 9th October 2007, 12:12 PM   (permalink)
Default short
Thanks for the reply
What ground I have to connect for sensor signal (-ve) and volatage divider
ground , either digital ground(controller) or analog ground (sensor).
If i want short analog ground and digital ground, how to short both
gounds together.
Regards
chandu
chandu13 is offline
Problem with multiple ADC using pic16f877 andyto Micro Controllers 15 24th September 2007 11:48 PM
16F877 Timer0 Interrupt Affecting ADC sebana Micro Controllers 13 12th September 2007 10:43 AM
Pickit 2 - Build or Not 2 Build art-666 Micro Controllers 2 6th February 2007 12:40 AM
SMPS power suply modify or build plss Raducu General Electronics Chat 12 9th February 2006 01:53 AM
Looking to build a counting device fogno Electronic Projects Design/Ideas/Reviews 4 22nd April 2004 11:40 PM
