Old 6th October 2007, 07:19 PM   #1
Default RS232 Converter
I have this code for some time but I can't get it to work, I can't simulate this code in Proteus, it is like it is not receiving any data and I can't find the error in the code, I hope someone can see it because I can't.
;RS232 9600 8N1 to Manchester 13888 converter.
;This program will receive standard RS232 (9600 baud, 1 start bit, 8 data bits, 1 stop bit),
;and will convert it into Manchester protocol (13888 baud, 1.5 start bits, 8 data bits, 1 ODD parity bit, 0.5 stop bits).
;PIC16f628a
;              |        |-(manchester out)
;       ground-|        |-5V
;              |        |-470R-LED1
;   (rs232 in)-|        |-470R-LED2
;              |        |-470R-LED3
;    ground-SW-|        |-470R-LED4
;SW=Normally Opened switch
#DEFINE	LED1Off		bcf	PORTB,LED1_PIN
#DEFINE	LED1On		bsf	PORTB,LED1_PIN
#DEFINE	LED2Off		bcf	PORTB,LED2_PIN
#DEFINE	LED2On		bsf	PORTB,LED2_PIN
#DEFINE	LED3Off		bcf	PORTB,LED3_PIN
#DEFINE	LED3On		bsf	PORTB,LED3_PIN
#DEFINE	LED4Off		bcf	PORTB,LED4_PIN
#DEFINE	LED4On		bsf	PORTB,LED4_PIN
		list P=16F628A, R=dec
#INCLUDE	P16F628A.INC
#DEFINE FUSESINHEX TRUE
;;pin5 and 14 are 5v and ground
RA0			equ	0		;pin17* (data out)
RB3			equ 	3		;pin9* (reset switch)
RB4			equ	4		;pin10*
RB5			equ	5		;pin11*
RB6			equ	6		;pin12*
RB7			equ	7		;pin13*
DATAOUT_PIN		equ	RA0		;pin 17
RESET_PIN		equ	RB3		;pin 9 (reset switch)
LED1_PIN		equ	RB7		;pin 13
LED2_PIN		equ	RB6		;pin 12
LED3_PIN		equ	RB5		;pin 11
LED4_PIN		equ	RB4		;pin 10
	__FUSES _BODEN_OFF & _BOREN_OFF & _CP_OFF & _DATA_CP_OFF & _PWRTE_OFF & _WDT_OFF & _LVP_OFF & _INTOSC_OSC_NOCLKOUT & _MCLRE_OFF
	cblock	0x20
		bytesent
		bitcount
		parity
		time1
	endc
        org     0x00            ;Reset Vector
	goto    setupchip
msg	dt	"RS232 to Manchester v0.2"
start
	LED1On
	LED3Off
	LED4Off
	btfsc	  RCSTA,OERR	;check for overun errors
	goto	  DEAL_OERR
	btfsc	  RCSTA,FERR	;check for framing errors
	goto	  DEAL_FERR
lookforbyte
	btfsS	  PORTB,RESET_PIN	;If you want the chip to start over again, press the switch
	GOTO	  setupchip
	BSF PORTA,DATAOUT_PIN
	btfss	  PIR1,RCIF	;BIT 5 INDICATES THAT A BYTE HAS BEEN RECEIVED IN THE RSR REG
	goto	  lookforbyte	;loop until a byte is found on the RS232 pin
sendbyte
	LED1Off
	LED2Off
	LED3Off
	LED4On
	movf	  RCREG,w	;Put the just received byte on W
	BCF		  PIR1,RCIF	;BIT 5 INDICATES THAT A BYTE HAS BEEN RECEIVED IN THE RSR REG
	call	  xmitbyte	;Call the manchester tx routine.
						;The manchester tx will delay less than the time necessary for
						;another byte to come on the RCREG.
	goto	  start
DEAL_OERR	;overun errors are fatal
	LED2On
	btfsc	  PORTB,RESET_PIN	;Since this is a fatal error, it will go out this loop only if you press the switch.
	GOTO	  DEAL_OERR
	movf	  RCREG,W
	movf	  RCREG,W
	call	  xmitbyte
	GOTO	  setupchip
DEAL_FERR	;framing errors will occur often
	LED3On
	movf	  RCREG,W	;We are discarding the byte when a frmaing error occur.
	goto	  start
sendcmdtest	;debugonly
	movlw	  0x03
	call	  xmitbyte
	movlw	  0xFD
	call	  xmitbyte
	movlw	  0x6E
	call	  xmitbyte
	movlw	  0x92
	call	  xmitbyte
	movlw	  0xFF
	call	  xmitbyte
	movlw	  0xFF
	call	  xmitbyte
	movlw	  0xFF
	call	  xmitbyte
	movlw	  0xFF
	call	  xmitbyte
	movlw	  0xFF
	call	  xmitbyte
	movlw	  0xFF
	call	  xmitbyte
	RETURN
setupchip
	banksel 	PORTA
	LED1Off
	LED2On
	LED3On
	LED4Off
	btfsS	  PORTB,RESET_PIN	;To avoid continous resets, it will continue only when the switch is already depressed.
	GOTO	  setupchip
	banksel	  CMCON
	movlw		  b'00000111'
	movwf		  CMCON
	banksel	  OPTION_REG
	movlw	  b'01111000'
	MOVWF	  OPTION_REG
	;OPTION_REG bits:
	;bit 7 RBPU: PORTB Pull-up Enable bit
		;1 = PORTB pull-ups are disabled
		;0 = PORTB pull-ups are enabled by individual port latch values
	;bit 6 INTEDG: Interrupt Edge Select bit
		;1 = Interrupt on rising edge of RB0/INT pin
		;0 = Interrupt on falling edge of RB0/INT pin
	;bit 5 T0CS: TMR0 Clock Source Select bit
		;1 = Transition on RA4/T0CKI pin
		;0 = Internal instruction cycle clock (CLKOUT)
	;bit 4 T0SE: TMR0 Source Edge Select bit
		;1 = Increment on high-to-low transition on RA4/T0CKI pin
		;0 = Increment on low-to-high transition on RA4/T0CKI pin
	;bit 3 PSA: Prescaler Assignment bit
		;1 = Prescaler is assigned to the WDT
		;0 = Prescaler is assigned to the Timer0 module
	;bit 2-0 PS2:PS0: Prescaler Rate Select bits
		;000 =	if assigned to TMR0 = 1:2
		;		if assigned to WDT = 1:1
	banksel	  PORTA
	clrf	  PORTA
	banksel	  TRISA
	movlw	  b'11111110'	;set PORTA: 0 (pin 17) output
	movwf	  TRISA
	movlw	  b'00001011'
	movwf	  TRISB		;RB1 is the RS232 receive pin
	call setupserial
	banksel	  PORTA
	LED1Off
	LED2Off
	LED3Off
	LED4Off
	goto	  start
setupserial
	;TXSTA bits:
	;bit 7 CSRC: Clock Source Select bit
		;Asynchronous mode
			;Don’t care
		;Synchronous mode
			;1 = Master mode (Clock generated internally from BRG)
			;0 = Slave mode (Clock from external source)
	;bit 6 TX9: 9-bit Transmit Enable bit
		;1 = Selects 9-bit transmission
		;0 = Selects 8-bit transmission
	;bit 5 TXEN: Transmit Enable bit(1)
		;1 = Transmit enabled
		;0 = Transmit disabled
	;bit 4 SYNC: USART Mode Select bit
		;1 = Synchronous mode
		;0 = Asynchronous mode
	;bit 3 Unimplemented: Read as ‘0’
	;bit 2 BRGH: High Baud Rate Select bit
		;Asynchronous mode
			;1 = High speed
			;0 = Low speed
		;Synchronous mode
			;Unused in this mode
	;bit 1 TRMT: Transmit Shift Register Status bit
		;1 = TSR empty
		;0 = TSR full
	;bit 0 TX9D: 9th bit of transmit data. Can be parity bit.
;RCSTA bits:
	;bit 7 SPEN: Serial Port Enable bit
		;(Configures RB1/RX/DT and RB2/TX/CK pins as serial port pins when bits TRISB<2:1> are set)
		;1 = Serial port enabled
		;0 = Serial port disabled
	;bit 6 RX9: 9-bit Receive Enable bit
		;1 = Selects 9-bit reception
		;0 = Selects 8-bit reception
	;bit 5 SREN: Single Receive Enable bit
		;Asynchronous mode:
			;Don’t care
		;Synchronous mode - master:
			;1 = Enables single receive
			;0 = Disables single receive
			;This bit is cleared after reception is complete.
		;Synchronous mode - slave:
	;bit 4 CREN: Continuous Receive Enable bit
		;Asynchronous mode:
			;1 = Enables continuous receive
			;0 = Disables continuous receive
		;Synchronous mode:
			;1 = Enables continuous receive until enable bit CREN is cleared (CREN overrides SREN)
	;bit 3 ADEN: Address Detect Enable bit
		;Asynchronous mode 9-bit (RX9 = 1):
			;1 = Enables address detection, enable interrupt and load of the receive buffer when RSR<8>
			;is set
			;0 = Disables address detection, all bytes are received, and ninth bit can be used as parity bit
		;Asynchronous mode 8-bit (RX9 = 0):
		;Synchronous mode
	;bit 2 FERR: Framing Error bit
		;1 = Framing error (Can be updated by reading RCREG register and receive next valid byte)
		;0 = No framing error
	;bit 1 OERR: Overrun Error bit
		;1 = Overrun error (Can be cleared by clearing bit CREN)
		;0 = No overrun error
	;bit 0 RX9D: 9th bit of received data (Can be parity bit)
	banksel	  SPBRG
	movlw	  25 ;SPBRG=25, BRGH=1 for 9600 baud, real baud will be 9615.385, error 0.160%
	movwf	  SPBRG
	banksel	  TXSTA
	clrf	  TXSTA
	movlw	  B'00100100'
	movwf	  TXSTA
	banksel	  RCSTA
	clrf	  RCSTA
	movlw	  B'10010000'
	movwf	  RCSTA
	movf	  RCREG,W
	clrf	  RCSTA
	movlw	  B'10010000'
	movwf	  RCSTA
	return
pausa8bit:			;W should be loaded with a delay value before calling this routine
				;T = 3w+2
	MOVWF time1		;(1 cycle)
delay8bit:
	DECFSZ time1, F		;(1 cycle)
	GOTO delay8bit		;(2 cycles)
	RETLW 0				;(2 cycles)
;-----------------   ASYNCHRONOUS TRANSMIT SUBROUTINE   -----------------
; The byte to be sent needs to be loaded on W before this routine is called.          *
; The byte to be sent will then be loaded on the bytesent register                    *
; This manchester tx routine manchester simulates 13888 baud rate, 1 bit = 72us       *
; Asynchronous tx sequence:                                                           *
; 1. Start Bit = Logic 1 for 72 plus logic 0 for 36 us (Total 108 us, 1.5 bits)       *
; 2. 8 data bits = 2 bit cell of 36us each where the 1st is opposite of the 2nd and   *
;    the second contains the real value of the bit to be sent. The data is sent LSB to*
;    MSB until the entire byte is sent.                                               *
; 3. Parity Bit = 2 bit cells of 36us each, where the 2nd bit cell contains the real  *
;    value of the parity bit. The parity is ODD. This means the total number of 1's   *
;    considering the 8 data bits and the parity bit needs to be ODD. So if you have,  *
;    let's say, 4 one's in the 8 data bits, the parity will be 1 so you have an ODD   *
;    number of one's in the total. If the number of one's in the 8 data bits is       *
;    already ODD (1, 3, 5 or 7), the parity bit will be 0.                            *
; 4. Stop Bit = Logic zero for 36us                                                   *
;Below an example:        *
;     BYTE = 41h = 01000001b, Parity=ODD                                              *
;   | --_ | _- | -_ | -_ | -_ | -_ | -_ | _- | -_ | _- | _ |                          *
;     110   01   10   10   10   10   10   01   10   01   0                            *
;    START   1    0    0    0    0    0    1    0    P   STOP                         *
;           LSB                                MSB                                    *
xmitbyte
	MOVWF	  bytesent
	BSF parity,0		;(1 cycle) Parity bit starts in "1" for ODD parity
	MOVLW 0x08			;(1 cycle) Porque son 8 bits de datos
	MOVWF bitcount			;(1 cycle)
;*****************BEGINNING START BIT***********************
	BSF PORTA,DATAOUT_PIN			;(1 cycle) Data Out = 1.  The start bit needs 108us high and 36us low.
									;This means it will be high for 3 bit cell (1.5 bits) and low for 1 bit cell (0.5 bits)
	MOVLW 0x16			;I need 72us en total. 72-10=62=3w+2
	CALL pausa8bit			;(2 cycles) T = 3w+2
	                                ;I need 72us en total. 72-4=68=3w+2
	                                ;(1 cycle) =>3w=66, w=22
	BCF PORTA,DATAOUT_PIN			;(1 cycles) Data Out = 0. This is the second bit cell of the second start bit
	MOVLW 0x09			;(1 cycle). I need 36. 36 - 7 = 29
					;29=3w+2 => 27=3w, w=9
;***************END OF START BIT******************************
;***************BEGINNING TX OF 8 DATA BITS **************
byteloop:	;LSB first, each bit composed of 2 bit cells, second bit cell has the real value of each bit.
		RRF bytesent,1		;(1 cycle)   ++++++++++++++++++++++++++++++++++++++++++++++
		COMF STATUS, W		;(1 cycle)   +STATUS: GPWUF  --  PA0  /TO  /PD  Z  DC  C  +
		ANDLW 0x01		;(1 cycle)   +        b7     b6  b5   b4   b3   b2 b1  b0 +
		MOVWF PORTA		;(1 cycle) 1st bit cell (36us)
		XORWF parity,F		;(1 cycle)
		NOP			;(1 cycle)
		NOP			;(1 cycle)
		MOVLW 0x09		;(1 cycle) 36-7=29 = 3w+2
					;=>27 = 3w, w=9
		CALL pausa8bit		;(2 cycle)
		COMF PORTA,F		;(1 cycle) 2nd bit cell (36us)
		MOVLW 0x08		;(1 cycle). I need 36. 36-10=26=3w+2
					;=>3w=24, w=8
		DECFSZ bitcount,F		;(1 cycle)
		GOTO byteloop			;(2 cycle)
;***************END OF TX OF 8 DATA BITS **************
;***************BEGINNING TX OF 1 PARITY BIT************
	NOP				;(1 cycle). I need 36. 36-33=3= 3 NOP
	NOP				;(1 cycle)
	NOP				;(1 cycle)
	COMF parity,w                   ;(1cycle) first bitcell of parity
					;parity on W
	MOVWF PORTA			;(1 cycle). Data Out = Parity, 1st bit cell;----------------------------------
	MOVLW 0x0A			;(1 cycle). I need 36. 36-4=32=3w+2
					;=>3w=30, w=10
	COMF PORTA,F			;(1 cycle). Data Out = Parity, 2nd bit cell is the opposite of the 1st
					;=>3w=30, w=10
;***************END OF TX OF 1 PARITY BIT************
;****************BEGINNING OF THE STOP BIT*********************
	BCF PORTA,DATAOUT_PIN			;(1 cycle)  LOW STOP BIT
	NOP				;(1 cycle)
	NOP				;(1 cycle)
	MOVLW 0x0A		;(1 cycle). I need 36. 36-3=32=3w+2
	                                ;=>3w=30, w=10 (Stop bit has 36us)
	BSF PORTA,DATAOUT_PIN			;after the stop bit is sent, put the line in idle state
	return
;*****************END OF THE STOP BIT***********************
;=============================  THE END =================================
	end
e.chain is offline
converter, rs232
USB to RS232 Converter VictorPS General Electronics Chat 7 16th June 2007 04:59 AM
PS2 mini-din 6pin to RS232 DB-9 converter lucky162k General Electronics Chat 4 18th July 2005 02:46 PM
RS232 to invert TTL converter hani_a Micro Controllers 4 30th April 2004 10:36 AM
Current Loop to RS232 Converter Shaun22 Electronic Projects Design/Ideas/Reviews 3 12th January 2004 04:58 PM
RS232 or USB to Ethernet converter vonn Micro Controllers 3 11th December 2003 12:27 AM
