Old 6th October 2007, 02:45 PM   (permalink)
Originally Posted by derrick826
thanks guys!
Eric.. if let's says in this case we are actually transmitting in ASCII characters.
i have an ultrasonic circuit which displays a measurement value on the 7 segment LED , example 192 which my register:
display_H = 00000001
display_T = 00001001
display_U = 00000010
You wouldn't have these binaries in your PIC registers?You would have HiReg = 0x0, LoReg = 0xC0 ... 00,,1100,0000
I use the comma's just for clarity.
has these 8-bit in binary
is there anyway which i can do to trasmit this 8-bit binaries to allow the PC to display 192 on the screen?
It depends upon the receiving program in the PC, they can written to accept binary data, convert to ASCII then display.
The usual way is to do the binary to ASCII conversion in the PIC program and transmit ASCII characters,
in that way you can use any PC terminal program.
Which one do you use?
EDIT: just seen Nigels post,, are you planning to use ALL 10 bits or just 8??
At this time the program 'right justifies' the value.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 6th October 2007, 02:47 PM   (permalink)
Convert them to ASCII first, then send them.
It's dead simple to do - just add 0x30 to the value - check my LCD tutorial routines, subroutine 'CharD' which does just that for LCD.
Nigel Goodwin is online now
Old 6th October 2007, 02:57 PM   (permalink)
alright Nigel! let me have a look
derrick826 is offline
Old 6th October 2007, 04:24 PM   (permalink)
As per our PM's
Simple example of OS Basic with asm conversion routines for your studies.
AllDigital
Define SIMULATION_WAITMS_VALUE = 1  'ignore sim delays
Define LCD_LINES = 4
Define LCD_CHARS = 16
Define LCD_BITS = 4
Define LCD_DREG = PORTD
Define LCD_DBIT = 0
Define LCD_RSREG = PORTE
Define LCD_RSBIT = 0
Define LCD_EREG = PORTE
Define LCD_EBIT = 2
Define LCD_RWREG = PORTE
Define LCD_RWBIT = 1
Define LCD_READ_BUSY_FLAG = 1
Dim ascbfr0 As Byte
Dim ascbfr1 As Byte
Dim ascbfr2 As Byte
Dim ascbfr3 As Byte
Dim ascbfr4 As Byte
Dim ascbfr5 As Byte
Dim ascbfr6 As Byte
Dim ascbfr7 As Byte
Dim b2avh As Byte
Dim b2avm As Byte
Dim b2avl As Byte
Dim hexval As Byte
Dim temp1 As Byte
Dim cntr1 As Byte
Dim cntr2 As Byte
Dim test0 As Byte
Dim test1 As Byte
Lcdinit
test0 = 0
b2avl = test0
hexval = test0
b2avm = 0
b2avl = test0
main:
test0 = test0 + 1
b2avl = test0
b2avm = 0
Gosub bin2asc5
Lcdcmdout LcdLine1Home
Lcdout ascbfr0, ascbfr1, ascbfr2,
Lcdout ascbfr3, ascbfr4, ascbfr5, ascbfr6, ascbfr7
Goto main
Gosub byte2asc3
Gosub showme
Gosub hex2asc
ascbfr5 = 0x20
Lcdcmdout LcdLine2Home
Gosub showme
test0 = test0 + 1
b2avl = test0
hexval = test0
Goto main
End
showme:
Lcdout ascbfr5, ascbfr6, ascbfr7
Return
'convert 24 bit bin to 8 asci in ascbfr0 to 7
'or
'b2avh,b2avm,b2avl
'leading spaces in bfr
bin2asc5:
ascbfr0 = 0
ascbfr1 = 0
ascbfr2 = 0
ascbfr3 = 0
ascbfr4 = 0
ascbfr5 = 0
ascbfr6 = 0
ascbfr7 = 0
ASM:        bcf status,rp0
ASM:        bcf status,irp
ASM:        movlw 16  '24  ' bits
ASM:        movwf cntr1
bitlp:  'shift msb into carry
ASM:        rlf b2avl,f
ASM:        rlf b2avm,f
'ASM:        rlf b2avh,f
ASM:        movlw ascbfr7  '0=msd 1st
ASM:        movwf fsr  'fsr=pointer to digits
ASM:        movlw 5  '0x8  'digits to do
ASM:        movwf cntr2
adjlp:
ASM:        rlf indf,f  'shift digit 1 bit left
ASM:        movlw 0x0a
ASM:        subwf indf,W  'check and adjust for overflow
ASM:        btfsc status,c
ASM:        movwf indf
ASM:        decf fsr,f  'incf=msd 1st next digit
ASM:        decfsz cntr2,f
Goto adjlp
ASM:        decfsz cntr1,f  'next bit
Goto bitlp
ASM:        movlw 0x30  'make asci
ASM:        iorwf ascbfr0,f
ASM:        iorwf ascbfr1,f
ASM:        iorwf ascbfr2,f
ASM:        iorwf ascbfr3,f
ASM:        iorwf ascbfr4,f
ASM:        iorwf ascbfr5,f
ASM:        iorwf ascbfr6,f
ASM:        iorwf ascbfr7,f
ASM:        movf ascbfr0,w  'blank leading zeros
ASM:        andlw 0x0f
ASM:        btfss status,z
Return
Return
ASM:        bcf ascbfr0,4  'make dig spc
ASM:        movf ascbfr1,w
ASM:        andlw 0x0f
ASM:        btfss status,z
Return
ASM:        bcf ascbfr1,4
ASM:        movf ascbfr2,w
ASM:        andlw 0x0f
ASM:        btfss status,z
Return
ASM:        bcf ascbfr2,4
ASM:        movf ascbfr3,w
ASM:        andlw 0x0f
ASM:        btfss status,z
Return
ASM:        bcf ascbfr3,4
ASM:        movf ascbfr4,w
ASM:        andlw 0x0f
ASM:        btfss status,z
Return
ASM:        bcf ascbfr4,4
ASM:        movf ascbfr5,w
ASM:        andlw 0x0f
ASM:        btfss status,z
Return
ASM:        nop
Return
hex2asc:
ASM:        movf hexval,w
Gosub hex1
ASM:        movwf ascbfr7
ASM:        swapf hexval,w
Gosub hex1
ASM:        movwf ascbfr6
Return
hex1:
ASM:        andlw 0x0f
ASM:        addlw 0x30
ASM:        movwf temp1
ASM:        movlw 0x3a
ASM:        subwf temp1,w
ASM:        btfss status,c
Goto hex2
ASM:        movf temp1,W
ASM:        addlw 0x7
Return
hex2:
ASM:        movf temp1,W
Return
'leading zero's displayed
byte2asc3:
ASM:        movlw 0x0
ASM:        movwf ascbfr5
ASM:        movwf ascbfr6
ASM:        movwf ascbfr7
ASM:        bcf status,rp0
ASM:        bcf status,rp1
ASM:        bcf status,irp
ASM:        movlw 0x8
ASM:        movwf cntr1
binlp1:
ASM:        rlf b2avl,f
ASM:        movlw ascbfr7
ASM:        movwf fsr
ASM:        movlw 0x3
ASM:        movwf cntr2
binlp2:
ASM:        rlf indf,f
ASM:        movlw 0x0a
ASM:        subwf indf,w
ASM:        btfsc status,c
ASM:        movwf indf
ASM:        decf fsr,f
ASM:        decfsz cntr2,f
Goto binlp2
ASM:        decfsz cntr1,f
Goto binlp1
ASM:        movlw 0x30
Return
Eric
PIC tutorials:
Old 8th October 2007, 01:11 PM   (permalink)
Hi there Eric.. i have tried the codes for data transmission to the PC via the serial cable and it works... thanks for your help and the PIC simulator IDE really helps..
may i know what can the tools (from PIC simulatior IDE) software UART simulation interface and the PC's serial port terminal do? When i simulate the sample coding you provided me in the previous post.. there are no results on both the tools
Are the tools (software UART simulation interface and the PC's serial port terminal ) related to the hardware UART simulation?
Old 8th October 2007, 02:10 PM   (permalink)
Its the 'hardware UART simulation tool when testing the PIC sim internal UART programs, NOT the software or PC.
The software simulator is when you write a program that uses PIC bit switching for the "uart" and not the PIC's internal UART
The PC's 'serial port terminal' is a utility program for using the PC's RS232, its not interlinked with the OS sim pins.
Does this help?
Eric
PIC tutorials:
Old 8th October 2007, 02:28 PM   (permalink)
yea i think this answers the questions.. thanks eric!
Capturing serial data using PIC24 nick2412 Micro Controllers 3 12th March 2007 10:32 PM
Need help badly on Inchworm and MPLAB thushy Micro Controllers 14 11th March 2007 07:05 PM
Need some help with a code provided by ATMEL ikalogic Micro Controllers 1 23rd January 2007 03:46 PM
Serial Data Logging Software Monkeyman87 Micro Controllers 8 12th October 2004 04:32 PM
An error in pic16f84a, why? Zener_Diode Micro Controllers 6 11th April 2004 03:55 AM
