Old 2nd October 2007, 08:51 PM   #1
Quan
Question Question about Inchworm+
Hi I have question for you...
I have inchworm+ it looks good when I plug it in it turn on even if switch is on or off...
Is this supposed to happen...
Thanks...
Old 2nd October 2007, 08:55 PM   #2
Quan
I plug ed in 9volt 1000milliamp adapter...
multimeter is broke I dont know what it is actually...
Is this ok...
Old 2nd October 2007, 09:22 PM   #3
Look at the schematics.
You will see that the switch controls power to the +5 (target power) on the ICSP connector. The LED is telling you that the Inchworm has power. It is OK.
3v0 is online now
Old 2nd October 2007, 09:32 PM   #4
Quan
Thanks...
I was nervous...
I look at schematic and see that it connects power to microcontroller...
How does target get 13 12 volt...
Old 2nd October 2007, 09:51 PM   #5
Wink
The inchworm assembly instruction do a good job of covering that in the text. The max232 chip converts 5V to about +15V. A series of diode drops are used to get it down to where VPP should be. The 2nd switch is used to select between 12V and 13V. Note that the white lettering on the PCB is backwards. The 12 and 13 are interchanged.
There has been several thread where people needed help getting theirs working. Most are for the non+ version but it may be a good idea to read them. I am still quite willing to help but that may be faster.
3v0 is online now
Old 2nd October 2007, 09:57 PM   #6
Quan
So 16F 12F gets 12V...
18F and dsPIC get 13V...
Am I right...
Old 2nd October 2007, 11:32 PM   #7
Am I right...
It is the other way around. From the assembly instructions...
...and U3 a RS232
level converter with built in switched capacitor voltage doublers.
VPP > 12V is generated from 5V using the ST232s’ (MAX232) own
internal voltage doublers. Diode D5 and capacitor C6 act as part of a
voltage multiplier circuit. In a lossless circuit there would be
approximately 15V at the cathode of D5 but because of voltage drops
both internally to the ST232 and across D5 (approx 0.7V) the voltage is
actually closer to 14V. D6 rectifies and C12 filters the voltage down to approx 13.5 VDC, Q4 will reduce
VPP by another 0.6V. S1/J1 on the Inchworm+ will allow for setting a slightly lower VPP (using D7 as a
0.7V drop) for dsPICs & 18F PICs
3v0 is online now
Old 3rd October 2007, 02:45 AM   #8
Quan
Ok...
So I connect the 10 pin header to target chip and program and it doesnt need its own power source?
Inchworm+ provides the power for it?
On my inchworm, the voltage is correct by the switch...
What program should I write first...
Old 3rd October 2007, 02:48 AM   #9
Quan
I find program... Called Hello World for inchworm ICD2...
I am use 16F628A I folo directions of sheet?
I am excited... Cant wait to program...
Krumlink is my email buddy from michigan, I from west coast...
He says sorry, he was mad... I help him out...
He is doing this project along with me...
Thanks...
Old 3rd October 2007, 03:20 AM   #10
Quan
I wrote the code in and follow directions...
This pop up under MPLAB IDE 2
Auto-connect not enabled - Not connecting (Try enabling auto-connect on the ICD2 settings pages.)
ICDWarn0034: Please ensure that your system's serial FIFO buffers are disabled.
Connecting to MPLAB ICD 2
ICDWarn0054:  MPLAB IDE has lost communications with the MPLAB ICD 2.  Would you like to attempt to reconnect?
...Connected
Setting Vdd source to MPLAB ICD 2
ICDWarn0020: Invalid target device id (expected=0x83, read=0x0)
...Reading ICD Product ID
Running ICD Self Test
...Passed
ICD0021: Unable to connect with MPLAB ICD 2
MPLAB ICD 2 Ready
What to do?
Old 3rd October 2007, 03:36 AM   #11
Quan
I have fixed it...
It reccognized it...
IT says this now:
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\MCC18\mpasm\mpasmwin.exe" /q /p16F628A "Hello World.asm" /l"Hello World.lst" /e"Hello World.err"
Warning[205] C:\A MPLAB\HELLO WORLD.ASM 2 : Found directive in column 1. (list)
Warning[205] C:\A MPLAB\HELLO WORLD.ASM 3 : Found directive in column 1. (include)
Error[105]   C:\A MPLAB\HELLO WORLD.ASM 3 : Cannot open file (Include File "p16f628A.inc" not found)
Error[111]   C:\A MPLAB\HELLO WORLD.ASM 4 : Missing symbol
Warning[205] C:\A MPLAB\HELLO WORLD.ASM 5 : Found directive in column 1. (org)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 6 : Found opcode in column 1. (bsf)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 6 : Symbol not previously defined (STATUS)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 6 : Symbol not previously defined (RP0)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 7 : Found opcode in column 1. (movlw)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 8 : Found opcode in column 1. (movwf)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 8 : Symbol not previously defined (OPTION_REG)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 9 : Found opcode in column 1. (movlw)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 10 : Found opcode in column 1. (movwf)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 10 : Symbol not previously defined (TRISB)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 11 : Found opcode in column 1. (bcf)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 11 : Symbol not previously defined (STATUS)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 11 : Symbol not previously defined (RP0)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 12 : Found opcode in column 1. (movlw)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 13 : Found opcode in column 1. (xorwf)
Error[113]   C:\A MPLAB\HELLO WORLD.ASM 13 : Symbol not previously defined (PORTB)
Warning[203] C:\A MPLAB\HELLO WORLD.ASM 14 : Found opcode in column 1. (sleep)
Warning[205] C:\A MPLAB\HELLO WORLD.ASM 15 : Found directive in column 1. (end)
Halting build on first failure as requested.
BUILD FAILED: Tue Oct 02 22:33:49 2007
I need your help please...
Thanks...
Old 3rd October 2007, 03:52 AM   #12
You have to put tabs before almost all program lines except labels or comments.
Also make sure your FIFO buffers are off or it will give you connection errors.
Bill
Smart Kits build Smart People
Old 3rd October 2007, 03:57 AM   #13
Quan
how do i turn off fifo buffers...
It says this
Clean: Done.
Error[105]   C:\A MPLAB\HELLO WORLD.ASM 3 : Cannot open file (Include File "p16F628A.inc" not found)
BUILD FAILED: Tue Oct 02 22:54:35 2007
Old 3rd October 2007, 04:15 AM   #14
You have installed the C18 compiler and set the asm toolsuite path to point to the c18 assembler.
To fix this go into "Project/set language tool locations" click on the + next to "Microchip MPASM Toolsuite" then on + next to Executables and then on MPASM assembler. The path at the bottom will say something like C:\C18\.... Browse to the correct location - on my machine it is C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe.
It should now build correctly.
Pommie is offline
Old 3rd October 2007, 05:46 AM   #15
i thought something smelled fishy about this 'new' member...
monkeybiter is offline
inchworm, question
Capacitor Charge/Discharge question ThermalRunaway General Electronics Chat 25 12th August 2008 05:48 PM
Basic Transmission question CamNuge General Electronics Chat 2 8th March 2006 11:08 PM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 12:54 PM
Data Logging question with high speed!!!! cubdh23 General Electronics Chat 4 16th August 2004 07:33 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 07:21 PM
