Notices
Old 5th October 2007, 01:31 AM   (permalink (permalink))
I still cant get it working, I think the problem is the Connector which I still cant contact dipmicro about. I will just buy new ones at jameco.
Krumlink is offline
Old 5th October 2007, 01:42 AM   (permalink (permalink))
I found teh error! It is the crappy connector! It isnt biting into the wire, even after I put it into a vice grip and bench press. Does anybody want to sell/give me a working Cable? I will pay for shipping etc.
Now for the formal appology:
Dear Electro-tech-online forum members:
I hearby appologize for my intense, rude, unethical and completely immature behavior. I hope that one day we can put all this aside and forget about the mistakes and things better left not said. I hope that this also rekindles friendships and to people who I have offended, that we may become friends, and hopefully get along very well. I do not mean anything on this forum, only because you are the true friends I have. At school, nobody even knows what a resistor is. The members on here (most) understand the things that makes my world go around. I can get frustrated very easily, not with my friends on here, only because of school, and the people in my environment. At my age, I am learning things that I would otherwise never have even understood the simple equation of ohm's law, or what a resistor is. I just hope that you can understand my position and forgive me for my evils and troubles that I have caused to many.
Thank you.
Krumlink is offline
Old 5th October 2007, 01:57 AM   (permalink (permalink))
Thank you accepted, glad you're getting the hang of programming microcontrollers. You will someday be the master of 10,000 transistors (Just a guess how many inside a small PIC...)
Sometimes all the cable needs is a little squeeze. It's a crimp cable and each wire is doubled so a single poor crimp should not hurt. (use both pairs when building your target PCB)
I offered you an Inchworm PCB but you probably don't need one. Can I offer you another PCB? I can put a couple of 10pin ICD connectors in the bag...
Bill
Smart Kits build Smart People
Old 5th October 2007, 02:11 AM   (permalink (permalink))
Sure bill!
My teacher at school is trying to set up a C++ class (he programmed Car chips for a while) for our HS, and I was helping him. He also knows C, so I think He would Like that as a gift. His wife also works at the HS, and I would stay after school for hours talking to her. She has a box (about that big ) of GALs. It is rediclous. Every month she orders hundreds of them, and puts the old ones in a box or gives them to students. I also showed her my binary clock (she teaches digital logic for 7 years now) and she could not wrap her head around it. If I gave him this PCB and gave him a list of stuff to get for it, he would definately love to have the PCB board and I could have the Female Sockets. The problem with the one that I got was that it had shattered into 6 peices. The arms broke off the part with the metal tabs, so it would just fall apart .
When I get it, I will make sure to cut the wire a bit to give it a hole to put it in, and cut the wire inbetween so it can get it easier. If you want me to pay for shipping, I can.
Thanks so much!
Krumlink is offline
Old 5th October 2007, 02:36 AM   (permalink (permalink))
You need to take Bill up on his offer of a board and build it up for yourself. If you do not the petty god of pic programming will see that you do not have a spare. Then he/she/it will introduce a flaw/bug some place and you will not know if the problem is in you target or your Inchworm. If you build the 2nd inchworm you can just swap one for the other and determine if it is the inchworm or the target.
If you ever work on a multi pic or pic to pic communication a 2nd inchworm can come in very handy.
EDIT:::
Does it blink??
Challange: Modify the code to blink two. But have one off when the other is on. Give it a try and post the code when you get stumped.
3v0 is online now
Old 5th October 2007, 02:39 AM   (permalink (permalink))
That sound's like a good idea actually. I have the Resistors DIP sockets, but not the caps, ST232 16F877 (I have the A version, but I dont know how to program it ) or the other misc sockets. I am restocking my stuff soon here.
Krumlink is offline
Old 5th October 2007, 03:14 AM   (permalink (permalink))
This a good chance to get you feet wet with the inchworm.
When you have the 16F877A hooked up correctly to the Inchworm.
You download the right HEX file for the 16F877A from Bill's site. Unzip if ziped. Start MPLAB, import the HEX file, set the DEVICE type. Can not recall if you need to set config bits in the interface or if they are in the hex file.
Hit program. Done. You now have a inchworm PIC.
Also I have a simple layout for target board with sockets for 3 or 4 different pin count pics including the 18 28 and 40. Think the other is 8 pin but do not know if I put a 20 pin socket on it.
I know you are working on etching boards. This is an easy board in that there are just the sockets, caps and optional resonators. If you are interested I will post the Eagel files of if you want an image you can print.
3v0 is online now
Old 5th October 2007, 10:58 AM   (permalink (permalink))
You can post the image or whatever you want to do. I am going to try and program a 16F later today.
I smashed down on the header and I got it to all clip on to the wire, but I broke off an arm to the strain relief I am going to epoxy it today and make sure that badboy wont come apart again!
I had ordered a additional socket (for the other end of the ribbon cable) and that one broke (from my kit) that has already been discused.
Can I use a 16F887?
Krumlink is offline
Old 5th October 2007, 11:40 AM   (permalink (permalink))
Put some masking tape over the holes that the pins go in when you epoxy the cable.
Not sure what you mean by
Can I use a 16F887?
You can not program it with the code from Bill's poster. The 16F877 is close but you still need to figure out a new CONFIG value and change the include statement.
Is it correct that you would like to try etching the board from the last post?
Is it correct that you have not used Eagle?
3v0 is online now
Old 28th October 2007, 12:20 AM   (permalink (permalink))
Bill sent me some headers and connectors with the junebug pcb, so when I get them I will start again.
Krumlink is offline
Capacitor Charge/Discharge question ThermalRunaway General Electronics Chat 25 12th August 2008 04:48 PM
Basic Transmission question CamNuge General Electronics Chat 2 8th March 2006 10:08 PM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 11:54 AM
Data Logging question with high speed!!!! cubdh23 General Electronics Chat 4 16th August 2004 06:33 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 06:21 PM
