Old 3rd October 2007, 09:36 PM   (permalink)
Quan
Nope it still diddnt work...
What else to do?
Old 3rd October 2007, 10:15 PM   (permalink)
I googled and found some info but it only seems to apply to
Microsoft Windows XP Embedded SP2
But it goes like this:
Device Manager
When you open the COM port properties in Device Manager, and then click Advanced on the Port Settings tab, you may receive the following error message:
You must have write privileges in the registry for this device in order to modify the devices advanced settings.
This behavior occurs because there are three missing registry subkeys from the following registry key:
HKEY_LOCAL_MACHINE\system\currentcontrolset\enum\a cpi\pnp0501\2
The missing keys are:
  • RxFIFO
  • TxFIFO
  • ForceFifoEnable
If you choose to mess with the registry be sure to back it up first.
Will do a bit more checking to see if I can find this for HOME or PRO. Which are you using ?
3v0 is online now
Old 3rd October 2007, 10:18 PM   (permalink)
This seems like a better bet:
"Group Policy" editor.
Try it this way:
Go to Start\Run: Type in: gpedit.msc
This will open GP editor.. in the left pane, look in User Configuration \ Administrative Templates \ System\...
In the right pane, look for the key "Prevent access to registry editing tools"
Make sure it's set to "Not Configured"
(If you need to alter it, double click the key and select the appropriate setting).
If this doesn't work, then I suggest you post a HijackThis log in the "Applications and Security" forum so one of the guys there to see what the problem might be regarding possible malware etc.
Good luck....
Edit: Just tried the above on my machine...if I enable the key, I get exactly the same "Registry editing has been disabled by your administrator" message when trying to run regedit. Set it to "Not Configured" ...and bingo..regedit works ok.
(I use XP Pro by the way)..
3v0 is online now
Old 4th October 2007, 12:54 AM   (permalink)
Quan
no, It still isnt working...
WHY!!!
I cant even open gpedit.msc...
Old 4th October 2007, 12:59 AM   (permalink)
Quan
It Works On My Other Computer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
Old 4th October 2007, 01:06 AM   (permalink)
WHY!!!
Why do you expect it to work you still have not fixed the problem with XP??
OK I followed the instructions. You run gpedit.msc
That is you cllick on run from the start menu then type in gpedit.msc
Not sure how how tried to open it. Maybe you got it right but could not tell from your post.
I see that you are having better luck on another computer. Chances are you will hit another snag. Just be cool about it... please
If you choose to go on to be an engineer or scientist you will run into things that do not work on a daily (some times seems hourly) basis. The drama just eats up time and raises the blood pressue.
3v0 is online now
Old 4th October 2007, 01:13 AM   (permalink)
Quan
My other computer has about 1 gig of total software and no internet, so it is a perfect canidate for C programming
I am going to program upstairs, because I have had way better chances upstairs.
Old 4th October 2007, 02:00 AM   (permalink)
Quan
Ok I have everything working, but I am recieving this error over and over:
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\user\My Documents\MPLABIDE\Hello World.asm.mcs".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p16F628A "Hello World.asm" /l"Hello World.lst" /e"Hello World.err"
Error[105]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 3 : Cannot open file (Include File "p 16F628A.inc" not found)
Error[111]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 4 : Missing symbol
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 6 : Symbol not previously defined (STATUS)
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 6 : Symbol not previously defined (RP0)
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 8 : Symbol not previously defined (OPTION_REG)
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 10 : Symbol not previously defined (TRISB)
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 11 : Symbol not previously defined (STATUS)
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 11 : Symbol not previously defined (RP0)
Error[113]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 12 : Symbol not previously defined (PORTB)
Error[173]   C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM 15 : Source file path exceeds 62 characters (C:\DOCUMENTS AND SETTINGS\USER\MY DOCUMENTS\MPLABIDE\HELLO WORLD.ASM)
Halting build on first failure as requested.
BUILD FAILED: Wed Oct 03 21:56:05 2007
What should I do?
Old 4th October 2007, 02:20 AM   (permalink)
Quan
Well, I made good progress today...
1. Hooked up my HP laserjet 4 that I got for free (they have 3 others that I can have)
2. Connected Inchworm+ up to my other computer
3. Disabled FIFO buffers
4. Other little tasks.
Cant wait until tomorrow to see where I get
Old 4th October 2007, 02:55 AM   (permalink)
Smile
Line by line
It is about to remove files from any previous build
Clean: Done.
It is about to assemble "Hello World.asm"
for the p16F628A
the list file is "Hello World.lst"
errors go to file "Hello World.err"
It failed because it could not find the include file "p 16F628A.inc"
From Bill's Poster the 16F628A code
;*** WDT reset toggles RB0
  list p=16F628A
  include <p16F628A.inc>
  __CONFIG 0x3F34
Good bet you have
include <p 16F628A.inc>
You need to pay close attention.
Computers do EXACTLY what you tell them.
If you screw up by one space they crap out.
3v0 is online now
Old 4th October 2007, 11:16 AM   (permalink)
Quan
I did have that!
I fixed the code and it WORKS!
I just gotta create a shorter directory and IT IS ALIVE!!!
Old 4th October 2007, 11:38 AM   (permalink)
That allows it to build.
Does it program and blink the LED ?
3v0 is online now
Old 4th October 2007, 09:49 PM   (permalink)
No, I keep getting the error that it doesnt have a valid target Device.
Sorry about blowing up, it appeared that the problem was human error
Krumlink is offline
Old 4th October 2007, 10:15 PM   (permalink)
Here is my code:
  list p=16F628A
  __CONFIG 0x3F34
	org			0
	bsf			STATUS, RP0
	movlw		b'00001110'
	movwf		OPTION_REG
	movlw		b'11111110'
	movwf		TRISB
	bcf			STATUS, RP0
	xorwf		PORTB, f
	sleep
	end
And the MPLAB history of what I have done
Connecting to MPLAB ICD 2
ICD0019: Communications:  Failed to open port: (Windows::GetLastError() = 0x2, 'The system cannot find the file specified.
ICD0021: Unable to connect with MPLAB ICD 2
MPLAB ICD 2 Ready
ICDWarn0034: Please ensure that your system's serial FIFO buffers are disabled.
...Connected
Setting Vdd source to MPLAB ICD 2
ICDWarn0020: Invalid target device id (expected=0x83, read=0x0)
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
Programming Target...
ICDWarn0052: MPLAB ICD 2 cannot validate a target device. Please make sure that the target device is connected and properly powered. Select "OK" to continue, or "CANCEL" to abort the operation
...Validating configuration fields
...Erasing Part
...Programming Program Memory (0x0 - 0x7)
Verifying...
...Program Memory
ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x1683, Val Read = 0x0)
ICD0275:  Programming failed.
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
ICDWarn0054:  MPLAB IDE has lost communications with the MPLAB ICD 2.  Would you like to attempt to reconnect?
...Connected
...Passed
ICD0082: Failed MPLAB ICD 2 operation
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
Reading...
ICDWarn0038:  When using auto-calculate write range, reads cover the entire memory range. Do you wish to continue?
...EEPROM
...Program Memory (0x0 - 0x7FF)
.. Config Memory
...User ID Memory
...Read Succeeded
MPLAB ICD 2 Ready
...Erasing Part
...Programming EEPROM Memory
...Programming Program Memory (0x0 - 0x7FF)
...Programming User IDs
Verifying...
...Program Memory
...EEPROM
...User ID Memory
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
...Programming succeeded
04-Oct-2007, 17:18:01
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
...EEPROM
...User ID Memory
...Verify Succeeded
.. Config Memory
...Verify Succeeded
04-Oct-2007, 17:25:49
MPLAB ICD 2 Ready
Reading...
...EEPROM
.. Config Memory
...User ID Memory
...Read Succeeded
MPLAB ICD 2 Ready
Reading...
...EEPROM
...Read Succeeded
MPLAB ICD 2 Ready
Blank Checking...
...Program Memory
ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3FFF, Val Read = 0x0)
...Device not blank
MPLAB ICD 2 Ready
Erasing Target Device...
...Erase Succeeded
MPLAB ICD 2 Ready
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
ICD0200: Operation Aborted (Warning 51).
MPLAB ICD 2 Ready
Hoped that helps
Krumlink is offline
Old 4th October 2007, 11:51 PM   (permalink)
This msg is telling you that the ICD2 is not able to read the target chips device ID. It is a show stopper.
You will not be able to program the chip till you get that fixed.
The problem is either the way you have the ICD2 hooked to the target or
the Inchworm itself. Most often it is the first. What are you doing for a
programming cable since you had a broken connector in your kit?
We need to see your schematic.
If you are using the schematic from Bill's poster you should tripple
check each and every connection. Use a Ohm meter,
Till you get a device ID other then zero the code does not matter.
EDIT:
Perhaps an actual apology to the people you barked at would be in order?
3v0 is online now
Capacitor Charge/Discharge question ThermalRunaway General Electronics Chat 25 12th August 2008 04:48 PM
Basic Transmission question CamNuge General Electronics Chat 2 8th March 2006 10:08 PM
High speed data logging question cubdh23 Micro Controllers 3 19th August 2004 11:54 AM
Data Logging question with high speed!!!! cubdh23 General Electronics Chat 4 16th August 2004 06:33 PM
PBX question waqar Electronic Projects Design/Ideas/Reviews 0 30th March 2003 06:21 PM
